Old 10-13-2012, 05:28 PM   #1
Volchok
Volchok's Avatar
Volchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to behold
Send a message via Yahoo to Volchok
1992 s13 FD legal track car $8900 OBO.
It is a bitter sweet day for me as I put my pride and joy up for sale...
Over $30k invested and over 500 hours of labor...
I used this car for several seasons of Vegas Drift Pro Am series and can no longer afford to drift. I am getting older and it is time to move on and be more responsible, stop blowing $1k a day for fun... I hate looking at it every day in the garage, knowing it isn't being used and abused like it should be...Right now I am trying to sell the car as a whole, not part it out. No point is PM's or questions about individual parts. If it doesn't sell as is, I will repost with parts pricing at a later date.
Must be a good loving home with intentions to drift the s**t out of the car, not hard park it.
1992 Nissan 240SX - clean title in hand
ENGINE
Apex'i Power FC DJetro for s13 SR20DET with all sensors and commander - Tuned by DDS performance - 336 hp at 18 psi - 355 hp at 20 psi
SR20DET - freshly rebuilt bottom end from Get Nuts Labs
rebuilt top end from DDS Performance
Built SR20DET
S15 pistons
Apexi 1.1 mm metal Head Gasket
Brian Crower Stage 2 264 cams
Peak Performance Valve Springs
ARP Studs
new seals, spark plugs, bearings, water and oil pump
Circuit Sports Anodized blue pulley kit
Nismo Motor Mounts
Greddy Large Oil Pan
Full Race twin scroll T3 manifold, dual wastegates
2 x 38 mm Tial MVS wastegates Blue with Full Race Logo
Tial Q BOV blue with Full Race logo
Full Race SR20 RWD Downpipe for twinscroll T3 dual wastegate
Custom intake manifold with 90mm throttle body
Custom exhaust from DDS Performance
Custom front bash bar from DDS Performace
Garrett GT3071R turbo t3 .78 AR twin scroll housing 3" v band
Koyo Radiator with dual Flexalite Fans
4" Full Race Intercooler
Custom V-Mount intercooler/radiator setup done by Forrest Wang - Get Nuts Labs
custom front wheel well tubs done by Forrest Wang - Get Nuts Labs
Full Race custom oil catch can
Get Nuts labs custom coolant reservoir
Get Nuts labs custom power steering resivoir
Greddy Water Temp Adapter
RC engineering 1000cc injectors
Sard Fuel Pressure Regulator
Sard Fuel rail
HKS Fuel Rail Adapter
Tomei Fuel Pump
Earls Fuel Lines
**all lines and hoses are AN fittings with black Prolite or Steel braided hose, there is not a single rubber hose or hose clamp on the entire car.
Summit racing battery relocation kit
Taylor Master battery disconnect switch
Full Painless wiring harness and Painless switch - wired by Garage Vegas
Greddy oil cooler with fan
Greedy oil filter relocation kit
Earl's power steering cooler with steel braided high pressure lines
Gauges
Defi Blue Racer:
- Oil Temperature
- Oil Pressure
- Water Temperature
AEM UEGO Wideband
SBC i-color boost controller with Fuel pressure sensor - amazing boost controller
Cobalt Blue Tachometer
Cobalt Blue Volt meter
Cobalt Blue electronic fuel gauge
SUSPENSION/DRIVETRAIN
Stance Gr+ coilovers
Kaaz 2 way LSD - always used Torco fluid and modifier
SPL transmisison mount
competition Clutch twin disc carbon composite clutch with lightweight flywheel
SR20DET transmission (spare transmission included)
Rebuilt steering rack
Rack & Pinion Bushings
Circuit Sports Steering column spacer
Battle Version Tension rods
Tein Inner Tie Rods
Tein Outer tie Rods
Battle Version Rear Upper Control Arm
Battle Version Traction Rods
Battle Version Toe Arm
B & M Short Shifter
Circuit Sports Subframe Bushings
Energy Suspension end link and sway bar bushings
Get Nuts Labs custom steering angle kit with tie rod spacers
Hydraulic e-brake
INTERIOR
Bride Super Low FG Rails
Sparco Black Suede Monza Wheel with blue anodized hub
NRG Qucik Release Hub Gen 2.5
Sparco Pro 2000 Seats
Sparco 3" Harness Pads
Corbeau 5 Point Harness
Blue JDM Dildo shift knob
MOMO Pedal Kit
MOMO Floor Mats - steel
Full Race 6 Point Cage - built by Forrest Wang
BRAKES
Circuit Sports Front Rotors
Circuit Sports rear Rotors
Front and rear Steel braided lines
5 Lug Conversion
Z 32 Front brakes Brakes
Z 32 Rear brakes
Z32 Steel Brake lines
Hawk Racing Pads front and rear
EXTERIOR
Origin 30 mm front over fenders
50 mm origin rear over fenders
Carbon fiber hood with hood vent
Sparco anodized blue hood pics
Uras knockoff body kit
Paint and body work done by Spring Mountain Autobosdy
Engine bay painted with House of Color silver flake done at Garave Vegas
H4 Headlight Conversion
HID Headlights 8000k
Enkei RPF1 Rims white 17x9 - Front
Enkei RPF1 Rims white 17x10 - Rear
Extra set of Enkei RPF1's 4 x 17x10 rears
Currently has new Federal 595 245/40/17 on the rear
Brand new set of Federal 595 245/40/17 included
4 x 245/40/17 used tires
Toyo Proxes R1R front tires - well used
summit racing tow hooks
Also included:
GForce GF525 Racing driver suit in black - large
GForce G5 Gloves black
I think that about covers it. If I think of anything else I will add it.
THE BAD: the car does have a little battle damage, which is cosmetic only thus I never got around to fixing it.
right rear quarter panel and tail light has damage from wall contact and a small collison with Danny George at FD Las Vegas
front bumber is cracked
rear bumoper is cracked/damaged from said Crab Broker contact
I am asking $8900 OBO for everything listed - an amazing steal even in today's market, my loss is your gain.
Pics:
Volchok is offline   Reply With Quote
Old 10-13-2012, 06:49 PM   #2
Rescue56
Rescue56 is an unknown quantity at this point
Bump for a Local!
Rescue56 is offline   Reply With Quote
Old 10-13-2012, 07:48 PM   #3
Skyn
Skyn's Avatar
Skyn is an unknown quantity at this point
Double Bump GLWS Shawn
Skyn is offline   Reply With Quote
Old 10-29-2012, 01:38 AM   #4
04srt21
04srt21 is an unknown quantity at this point
bump if you still have it, car looks awsome.
04srt21 is offline   Reply With Quote
Old 10-29-2012, 06:29 AM   #5
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
where was this 4 months ago...
this is a great deal and a lot of car per coin.
glws
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 10-29-2012, 11:30 AM   #6
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Someone could easily get their career going with this
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 10-29-2012, 12:58 PM   #7
2005bluesti
2005bluesti is on the path to ruin2005bluesti is on the path to ruin
Do you have any videos of this thing in action???
2005bluesti is offline   Reply With Quote
Old 10-29-2012, 01:56 PM   #8
laxrider
laxrider is an unknown quantity at this point
Do you have any photos of current damage?
Highly interested.
laxrider is offline   Reply With Quote
Old 10-29-2012, 02:04 PM   #9
DRiFT.RAFF
DRiFT.RAFF is an unknown quantity at this point
dang i would love to see this thing in action
DRiFT.RAFF is offline   Reply With Quote
Old 10-29-2012, 02:50 PM   #10
tayloray
tayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura about
Bump for a good deal
tayloray is offline   Reply With Quote
Old 10-29-2012, 03:00 PM   #11
yellow_guy
yellow_guy is an unknown quantity at this point
trade for a 350z roadster?
http://zilvia.net/f/cars-sale/484586...t-cc-drft.html
yellow_guy is offline   Reply With Quote
Old 10-29-2012, 06:01 PM   #12
Volchok
Volchok's Avatar
still have car, motor is out as i was almost going to part out the car. Will go back in and I am going to drive at Nov 18th Vegas Drift event.
i can take pics of rear bumper/quarter panel damage, would think it would be of little concern to a serious buyer though. I have video, all I can post now is my facebook link with a short video here:
https://www.facebook.com/media/set/?...3743154&type=2
Not interested in trades, sorry.
Old 10-30-2012, 05:34 AM   #13
fredsiny
fredsiny is an unknown quantity at this point
very interested whats your email or number
fredsiny is offline   Reply With Quote
Old 10-30-2012, 08:44 AM   #14
scels240
scels240's Avatar
scels240 is an unknown quantity at this point
Send a message via AIM to scels240 Send a message via Yahoo to scels240
Sick probe bro
Does it pass smog??
Haaaaaaa jk
Crazy deal glws
scels240 is offline   Reply With Quote
Old 10-30-2012, 06:14 PM   #15
jdms14kid
jdms14kid is an unknown quantity at this point
Please text me ASAP. 484.238.6345
jdms14kid is offline   Reply With Quote
Old 10-30-2012, 08:58 PM   #16
drifterjoey
drifterjoey's Avatar
drifterjoey is an unknown quantity at this point
Bump for legit car and owner. I will see you at the event on the 18th.
drifterjoey is offline   Reply With Quote
Old 10-30-2012, 09:23 PM   #17
GetSydWys
GetSydWys is an unknown quantity at this point
Bump! someone buy this carr! wish i had the $$$
GetSydWys is offline   Reply With Quote
Old 10-31-2012, 12:32 AM   #18
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
Holy sh*t! Bump
VinceDude is offline   Reply With Quote
Old 11-06-2012, 03:03 PM   #19
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
this is such a good deal, wish i had the cash for it
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 11-06-2012, 03:10 PM   #20
tdaffern
tdaffern's Avatar
tdaffern is an unknown quantity at this point
Wow amazing deal!! Glws
My build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Check out West Motors for all your automotive needs https://www.facebook.com/WestMotorsAz
tdaffern is offline   Reply With Quote
Old 11-06-2012, 04:25 PM   #21
Hailtothesilvia
Hailtothesilvia's Avatar
Hailtothesilvia is making a name for him/her selfHailtothesilvia is making a name for him/her self
Send a message via AIM to Hailtothesilvia
Stupid good deal. Holy crap. Free bump for you, sir.
TAOspeedwagon II
Hailtothesilvia is offline   Reply With Quote
Old 11-09-2012, 05:56 PM   #22
tdaffern
tdaffern's Avatar
One more free bump for you sir. Someone pick this up. KILLER price!!!
My build
Old 11-12-2012, 02:33 PM   #23
240s135
240s135 is an unknown quantity at this point
If this is still for sale please get in touch with me ASAP!
240s135 is offline   Reply With Quote
Old 11-12-2012, 09:59 PM   #24
Weedm
Weedm's Avatar
Weedm is an unknown quantity at this point
crackhead deal
Weedm is offline   Reply With Quote
Old 11-14-2012, 03:34 PM   #25
240s135
I am willing to pick up is this car still for sale or not?!??!?!?
Old 11-14-2012, 04:49 PM   #26
JDMtyteYO!
JDMtyteYO!'s Avatar
JDMtyteYO! is an unknown quantity at this point
I want!! Wanna sell the rolling shell? No drivetrain, ecu, harness, intercooler, rad, etc
JDMtyteYO! is offline   Reply With Quote
Old 11-17-2012, 05:29 PM   #27
240s135
Guess this isnt for sale anymore????????????
Old 11-17-2012, 08:25 PM   #28
jdo180
jdo180 is an unknown quantity at this point
screw off if its for sale ,,,,its mine
jdo180 is offline   Reply With Quote
Old 11-17-2012, 08:26 PM   #29
jdo180
jj ,,,not really
Old 11-17-2012, 08:52 PM   #30
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
damn some major bucks into this car aND GREATT PRICEE FREE BUMP GLWS
thizzen4 is offline   Reply With Quote
240 sx, 3071, enkei rpf1, full race, get nuts lab
