Old 09-07-2012, 11:26 AM   #1
justin_bfn
justin_bfn's Avatar
justin_bfn is an unknown quantity at this point
s13 drive shaft issue
this just started about 3 weeks ago when i go to take off from a dead stop my shifter bounces up and down violently and they slower as i go faster and also when i take off i hearing a clanking coming from under the center console is my best guess. my first thought was carrier bearing so i replaced it and it helped but it still did it and now it does it as bad as it did in the first place. tranny mount and such and all good and tight. it still shifts fine and clutch is works fine. I'm at a lost for thought here. any help or suggestions?
justin_bfn is offline   Reply With Quote
Old 09-07-2012, 12:16 PM   #2
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Did you check your motor mounts?
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 09-07-2012, 04:10 PM   #3
justin_bfn
justin_bfn's Avatar
Yeah that and tranny mounts are solid, they're fine.
Old 09-07-2012, 04:42 PM   #4
chetos13
chetos13's Avatar
chetos13 is an unknown quantity at this point
Send a message via Yahoo to chetos13
Check the c clip on the shifter that holds it to the tranny
TEAM ELITE
chetos13 is offline   Reply With Quote
Old 09-07-2012, 05:23 PM   #5
booey13
Trader Rating: (91)
Solid as in how? Ive had "solid" poly tranny mounts crack on me.
Old 09-07-2012, 09:17 PM   #6
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
Is bearing carrier on tight? Mine wouldn't tighten all the way because threads were striped, reason why I got a 1piece less parts less problems
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
Old 09-10-2012, 10:05 AM   #7
justin_bfn
justin_bfn's Avatar
wheres that c clip? and solid as in they're tight. because its acting almost like the tranny mount is loose but its not at all. and yes the carrier bearing is tight
Old 09-10-2012, 10:46 AM   #8
colossals13
colossals13's Avatar
colossals13 is an unknown quantity at this point
I have the same exact issue with my s13, and i went the same route (replacing the center bearing) but it wasnt until I saw my friends dirveshaft months later, that I found out that the mounting mounting/support bracket has a bottom AND TOP piece, which secure the your driveshaft in place, keeping it from slaping the bottom of your car. (my car only has the bottom half of the bracket. Priced one from nissan was either $35 or $40 bucks for a new one.
colossals13 is offline   Reply With Quote
Old 09-10-2012, 03:08 PM   #9
justin_bfn
justin_bfn's Avatar
So its the bracket that goes around the carrier bearing? Or is it in a different spot.
Old 09-11-2012, 10:37 AM   #10
colossals13
Yes the bracket itself should be the problem. When you get your car in the air, inspect the center bearing it should be supported by a bracket on the bottom keeong it from falling and the 2nd half of the barcket onthe top to keep it from flopping around a slapping the car.
Old 09-11-2012, 10:40 AM   #11
colossals13
and this is the bracket.... based on the orientation of the picture.. the top is actually the bottom and vice versa for the other half. This is one instaaled on the driveshaft.
Old 09-11-2012, 10:41 AM   #12
colossals13
lol where the question mark is
Old 09-11-2012, 10:59 AM   #13
justin_bfn
justin_bfn's Avatar
Okay i'll have to check it out thanks. Is it possible that my drive shaft could have just come unbalanced?
Old 09-11-2012, 12:44 PM   #14
colossals13
I'm no driveshaft expert, but seeing as most driveshafts have their weights attached by rivets, or have them welded on; I highly doubt that its become unbalanced especially with it being an oem unmodified part. And I'm assuming that havent gone mudding, off-roading, or run over some huge object causing abnormal strees or impact to it...so yeah I'm sticking with the bracket.
Old 09-11-2012, 03:03 PM   #15
justin_bfn
justin_bfn's Avatar
Okay thanks for your help. So what if i just got a one piece shaft to quit dealing with it?
Old 09-12-2012, 10:34 AM   #16
colossals13
Welp then that will completely kill the issue as well, and you wont have to deal with any further carrier bearing issues. Z1 Motorsports has one-piece aluminum driveshafts for $278 (0_o).... and thats th lowest you're gonna find directly from an aftermarket supplier. But with whatever you decide good luck man(;-)
Old 09-12-2012, 09:00 PM   #17
justin_bfn
justin_bfn's Avatar
Alright thank you
Old 09-13-2012, 10:56 PM   #18
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
Check your diff bolt next to the drive shaft. If u have an s14 your diff has bushings next to the drive, bolt could be loose or bushings are worned out. S13 has no bushings though
Old 09-14-2012, 09:09 AM   #19
justin_bfn
justin_bfn's Avatar
yeah its s13
Old 10-25-2012, 08:05 AM   #20
msserratt
msserratt is an unknown quantity at this point
Any updates!!
Any updates?? I'm having the same problem here..
msserratt is offline   Reply With Quote
Old 10-25-2012, 08:19 AM   #21
h2v7
h2v7 is an unknown quantity at this point
ok that looks as if its my prob too.
insted of that top piece would a one piece driveshaft fix this problem???
h2v7 is offline   Reply With Quote
Old 10-25-2012, 08:23 AM   #22
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
does it sound like clanking, or banging in the drive shaft tunnel?
Juantwo3 is offline   Reply With Quote
Old 10-26-2012, 12:59 AM   #23
240pimp
240pimp is an unknown quantity at this point
just did an s13 auto to manual swap, and there is a loud whirring or whining sound when slowing down coming from the drivetrain area,(seems the driveshaft area), and also when reaching a certain speed when accelerating. Similar to a harmonic vibration. I think its probably a shot carrier bearing since its off a 92 w high miles. Hoping someone can confirm this, but based on the responses above, I'm thinking its a shot carrier bearing.
93 Hatch w SR20
240pimp is offline   Reply With Quote
Old 10-28-2012, 10:23 AM   #24
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
mine would clunk and thunk off the line. the 6 puck clutch didnt help at all. replaced the driveshaft with a 1 piece last week and now its awesome. 1 thing to keep an eye on though, is that if you get any vibration with the new shaft, take it out and rotate 1/4 turn and see if the noise goes away. mine had to be rotated 180 degrees.
AsleepAltima is offline   Reply With Quote
Old 10-28-2012, 11:17 AM   #25
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
If you're pushing any sort of power go buy a drive shaft shop 1 piece drive shaft and call it a day. had this problem last summer with my SR. launched it and then every time i sped up the thing would clunk really bad. the carrier bearing or the mount, one of the two (i don't remember) went bad. I heard they don't like anything around 250 or so horse power. Plus it being old doesn't help. 1 piece steel or aluminum drive shaft and call it a day.
GL Chrillz is offline   Reply With Quote
Old 10-29-2012, 09:33 AM   #26
240pimp
Just got my 1 piece driveshaft from Z1 motorsports, woo hoo. Think I'll be installing that tonight.
to the OP: YOur shifter bounces up and down??!! how is that possible if its bolted to the crossmember. Is your clutch grabbing?
93 Hatch w SR20
Old 10-29-2012, 02:00 PM   #27
AsleepAltima
got mine last week. it was super noisy at first. unbolted it and spun it 180 and it shut off. very nice now. youre going to love it.
Old 11-01-2012, 09:42 AM   #28
justin_bfn
justin_bfn's Avatar
I should be getting a one piece next week i'll let you know if it should work
Old 11-01-2012, 09:59 AM   #29
h2v7
so when you take out this 1 piece and "rotate it"
you mean pull the yolk from the back of the tranny and spin the drive shaft then plug it back in?
Old 11-01-2012, 12:18 PM   #30
Mikester
Mikester's Avatar
Unbolt the driveshaft from the yoke on the diff (4 bolts), spin the yoke 180 degrees, bolt back up. Apparently, what it does is change the resonant frequency of the driveline. Source: The Driveshaft Shop | Driveshafts 101
That tidbit did fall under the "Jack Test" that is not for CV axle cars (like ours lol), but the principle is the same so far as rotating the shaft goes. Sounds wacky, and I don't fully understand it; but those guys know their sheit... and I now have a good idea why my alum shaft seems to be so noisy
240sx coupe, driveshaft, rb20det, s13
