Old 08-15-2012, 03:51 PM   #1
TyUSMC0814
TyUSMC0814 is an unknown quantity at this point
KA Clutch replacement, need help! KA24de
I have a new full clutch kit. The only problem is I don't know how to disconnect my driveshaft or where exactly the tranny mounts are. I have all the tools I would ever need. And a lift if need be but I've never done anything drivetrain wise. I just would like some instruction and pictures if possible. I'm not incompetent and usually when I look around the area I'm working, I'll find stuff. Any help please?
TyUSMC0814 is offline   Reply With Quote
Old 08-15-2012, 04:00 PM   #2
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Yeah. I don't even know where to start with the flaming
Old 08-15-2012, 04:03 PM   #3
Grocery Cart
Grocery Cart's Avatar
Grocery Cart is an unknown quantity at this point
Just search man.
There's dozens upon dozens of write ups on this.
Posting this question is literally asking to get kicked in the nuts by these guys.
Grocery Cart is offline   Reply With Quote
Old 08-15-2012, 04:37 PM   #4
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
I'll bite:
1. Unbolt the 4 14mm bolts holding the driveshaft to the diff
2. unbolt the 2 17mm driveshaft carrier bracket bolts & pull the driveshaft from out of the trans
3. drain tranny oil
4. unbolt 4 17mm bolts on the tranny crossmember (while supporting trans with a jack)
5. lower the jack under the tranny so the whole engine/tranny tilts backwards
6. unplug wiring from tranny sensors, remove shift lever
7. use a whole bunch of extensions & a 14mm socket to reach the bellhousing bolts & loosen. be careful not to let the starter fall out of the tranny (you should probably disconnect the starter wiring, or at least the battery)
8. pull trans off the engine
9. remove pressure plate & clutch disc
10. inspect flywheel for hot spots & glazing (should probably remove flywheel & have it resurfaced)
11. replace pilot bushing, throwout bearing, clean up bellhousing
12. line up clutch disc with alignment tool
13. torque down pressure plate in a star pattern
14. put everything back together
96Turbo is offline   Reply With Quote
Old 08-15-2012, 05:38 PM   #5
TyUSMC0814
You're amazing, thank you.
Old 08-15-2012, 06:17 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Driftopia Tech Blog » Blog Archive » Installing a SR20DET Lightweight Flywheel and Clutch into the CA18DET.
http://www.nicoclub.com/archives/240...heel-swap.html
Just dont torque the SR flywheel that much and step torque it up. Torque them up to 40 lbs in a star pattern, then 70, then I usually torque mind up to about 95 ft lbs, while using red lochtite.
CLICK HERE!!!
clutch, clutch 5 speed swap, ka24de, s14, transmission
