Old 06-18-2012, 11:42 PM   #1
89_SR20
89_SR20's Avatar
89_SR20 is an unknown quantity at this point
Exclamation Sr20 stalls and then wont start
So I started having a problem where under normal loads when the car is at operating temperatures the car would die at lights, highway or just idling in my driveway. I have checked body grounds. used throttle body cleaner and fuel injector cleaner, replaced my sparkplugs and had coils/fpr and injectors tested. Replaced the fuel filter and the fuel pump itself with a 350lph pump but it just keeps dying. Any help. Am I missing a wire ground out somewhere? Temp or O2 sensor?
89_SR20 is offline   Reply With Quote
Old 06-18-2012, 11:45 PM   #2
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
sounds like a coolant temp sensor problem.
JasianBlazin is offline   Reply With Quote
Old 06-18-2012, 11:50 PM   #3
89_SR20
89_SR20's Avatar
If it were the sensor would it be throwing a code? Its a 91 so I have to pull it from the ECU but I get Error Code 55, which to my understanding means no problems found
Old 06-19-2012, 12:03 AM   #4
Freakchakra
Freakchakra is an unknown quantity at this point
Have you checked your MAF?
Sent from my C771 using Tapatalk 2
Freakchakra is offline   Reply With Quote
Old 06-19-2012, 12:22 AM   #5
89_SR20
89_SR20's Avatar
Yeah MAF was the first thing I checked initially even when unplugging it the car will die and not restart
Old 06-21-2012, 11:35 AM   #6
89_SR20
89_SR20's Avatar
It died again after replacing the CTS so I got angry and started pulling on wires ( I know bad idea) but it solved the problem the fuse box wiring is screwed completely the tape and shrink wrap is off and exposed wiring all over the place. I didn't notice it before but thank you all for the help!
Old 06-22-2012, 03:14 PM   #7
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
coolant temp sensor!
zneubauer is offline   Reply With Quote
Old 06-22-2012, 03:31 PM   #8
cotbu
cotbu's Avatar
lack of air. open up the aicv.
If that fixes it, check timing, adjust blah blah blah!
redtop s13 180sx silvia, s13, sr20det
