Old 05-25-2012, 11:58 AM   #1
SlammedPurpleS13
SlammedPurpleS13 is an unknown quantity at this point
s13 My s13silvia is bogging down at 4000 rpm in all gears????
I recently bought a 1990 s13 silvia and it is bogging down at 4000 rpm in all gears. Ive searched google and found that it could possibly be the MAF or a clogged fuel filter or even a clogged cat. I need some help targeting the problem so I can get out and kill some porsches. please help me if you have any answers...
SlammedPurpleS13 is offline   Reply With Quote
Old 05-25-2012, 12:01 PM   #2
Edwin562
Edwin562's Avatar
Originally Posted by SlammedPurpleS13 View Post
I recently bought a 1990 s13 silvia and it is bogging down at 4000 rpm in all gears. Ive searched google and found that it could possibly be the MAF or a clogged fuel filter or even a clogged cat. I need some help targeting the problem so I can get out and kill some porches. please help me if you have any answers...
This is the only reason why i will not help.
Old 05-25-2012, 01:14 PM   #3
ultimateirving
ultimateirving's Avatar
does it start to bog like as in it its about to die?
or does it break and kinda buck around like its trying to go but cant?
and try not to kill porches... im sure the homeowners would disapprove.
Z32 with lq4 swap
Old 05-26-2012, 11:35 AM   #4
SlammedPurpleS13
Its trying to go but cant, its almost like its not getting enough fuel. it bucks and backfires..
Old 05-26-2012, 12:10 PM   #5
cotbu
cotbu's Avatar
4k bog down is usually fuel, correct there. We need to know what afr it happens and is timing correct, base timing with a light. Not cas in the middle! That can be 20-30deg.
It may also be a boostleak, so get to checking, not with brake cleaner etc. pressurize intercooler pipes! Also TPS voltage could be a suspect as well. So you can see that there are many things to check and still be something else, like a leaky injector.
I know a porch you can kill! I need to rebuild it anyway, thinking... solid paneling for the floor!
Old 05-28-2012, 11:06 AM   #6
SlammedPurpleS13
Thanks for your help, I will check these possibilities.
Old 05-28-2012, 05:54 PM   #7
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Is it a ka? I had this problem with mine, the lower timing chain was a tooth off so it wouldn't time correctly. My resulting timing was either so low that it wouldn't run or so high that it would set off the knock sensor at 4k and it wouldn't rev any higher.
pacotaco345 is offline   Reply With Quote
Old 05-30-2012, 05:20 PM   #8
SlammedPurpleS13
It's a red top sr. Thanks I'll check the timing.
Old 06-02-2012, 05:08 AM   #9
Nesser
Nesser's Avatar
Nesser is an unknown quantity at this point
Had a similar problem with my 240. My problem was a dirty MAF. You can go to Autozone and buy some MAF cleaner to see if this is your problem also. Second thing might be the EGR
Nesser is offline   Reply With Quote
Old 08-17-2012, 12:04 PM   #10
illest420
illest420 is an unknown quantity at this point
boost leak ?????????
sounds like ur leaking boost
illest420 is offline   Reply With Quote
1990, bogging, s13, silvia
