04-09-2012, 09:05 PM | #1 |
S13 KA24DE Complete engine part-out (head, block, IM, clutch setup, etc)
Well, i've decided to part-out my extra dual cam KA i have. Engine had 190k miles when pulled, ran great with no problems. Had intentions to build, which is why i had head work done, but decided to go another route. Again this engine is out a my 1993 240sx, was automatic but 5 speed swaped, if that matters. Pics will be up soon when i get some free time to capture them. here is the part list:
Head: $60. Bare head that includes: Cam caps, and all valvetrain components. Was recently resurfaced and hot tanked at Carquest automotive in Brandon, Florida. Cost me $75 to have that done. Have the receipt to prove. SOLD Exhaust and intake camshafts: $40. SOLD Valve cover: $20. Upper timing cover: $10 SOLD Lower timing cover/oil pump: $20. great shape. installed a brand new front main seal aswell as oil pickup tube gasket. Oil pan: $20 has NO dents at all, car had stock suspension so it never scraped. Upper timing chain tensioner: $5 brand new. SOLD Upper timing chain: $10. this is the double row chain that goes on the camshafts. SOLD Upper timing chain sprocket: $20. sprocket the bolts onto the head, which links the block timing with head. PENDING lower timing chain tensioner: $10 tensioner is in great shape. Lower timing chain guide: $5. this is the guide that is parallel with the lower guide. also is mint shape. Upper timing chain guide: $FREE with any purchase. this is the guide thats on the right side of the chain, not the top guide near the valve cover. SOLD Intake manifold: $30. Has EGR deleted, fuel canister and other emissions vacuum lines removed completly, and does not have butterfly valves (which is wierd since it's a S13 manifold). comes with the IACV, and fresh upper and lower gaskets which were just replaced. PENDING Throttle body: $10 Fuel rail with injectors: $30. comes with all 4 270cc injectors, caps and screws, fuel pressure regluator, and a brand new injector o-ring kit. SOLD bare block: $50. will come bare. meaning no pistons, crank, crank girdle, etc. PENDING Pistons with rods: $15 each (piston+rod combo) or $50 for all 4. usual grime but no burns/chips/AIDS lol anything like that. all have good bearings. SOLD Crank: $40. great condition. not warped or anything like that. ran great when it was in the car. SOLD crank pulley: $10. no chips or anything. SOLD Crank pulley bolt: $5. not stripped or anything. mint PENDING 5 speed flywheel bolts: $20. all 6. great condition. SOLD pressure plate to flywheel bolts: $10 for all 6.SOLD OEM flywheel: $20. good condition. could use a resurface but isn't nessesary.SOLD exedy OEM clutch disc: $20. lots of life left.SOLD OEM flywheel. $20. good condition. no hot spots/glazing or anything. SOLD Alternator: $30. worked great while in car. never whined or nothing like that. thats all the parts i can remember at the moment, like i said it's a complete motor so not missing anything. if you need something you don't see listed just ask me and i'll probably have it. some stuff i am keeping though. Shipping prices will vary, if any parts need be shipped, tell me your area code and ill figure out pricing. you ARE paying for shipping though. can also do local pick up. I'm located in brandon, florida. like i said the motor was running great when pulled, just going another route and figure i can use the cash. yeah my first post is a for sale thread, i only look at threads when i'm on zilvia. i am not a very common poster which is obvious. post on here, or pm me if interested in any parts. thanks. Last edited by InFamous Kutz; 05-11-2012 at 11:57 PM.. Reason: THINGS SOLD |
240sx, drifting, dual cam, ka-t, ka24de part out |
