Old 02-19-2012, 08:53 PM   #1
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
sr20det oil fedd line from block...leaking
Can the oil feed line bolt be accessed without having to remove the turbo and mani? And if i do have to remove the mani and turbo (dont want to cause of hard lines) do i need to replace the gaskets...there only 15k old. I just wanna get in there and see if its loose or what but i cant access it easily. It is getting progressively worse so i hoping its not the block cracking. I looked at it from where i can and its coming from the bottom of the bolt.
Thanks in advance
Nick
Info: Bottom mount s15 bb turbo
Te37 is offline   Reply With Quote
Old 02-20-2012, 01:17 AM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Yes you can get to it. You'll need to replace the copper washers on both sides.
Old 02-20-2012, 08:06 AM   #3
Te37
Te37's Avatar
Know that I looked at it I'm sure I can get to it if I remove a/c compressor, hot pipe, intake and oil dip stick.
Anyone have a size or part number for that washer?
Old 02-20-2012, 12:12 PM   #4
KiLLeR2001
Trader Rating: (46)
OEM Copper Crush Washers
15193-03E00 (larger)
15193-P9000 (smaller)
The smaller ones are used for the oil feed line. The larger ones are used for the coolant lines.
Old 02-20-2012, 12:29 PM   #5
Te37
Te37's Avatar
You da man....thanks
Old 02-22-2012, 12:03 PM   #6
Te37
Te37's Avatar
So here is what has happened.
-The car was leaking from the oil feed line from the block. Minimal leak.
-I then loosened the banjo bolt and tightened it up again. Huge leak.
-Today i replaced the crush washers, tightened banjo to 20ft/pounds. Minimal leak again.
Am i safe to say the hard line is bad? It seems to be leaking from right above the banjo bolt where the line gets a little smaller then goes to turbo. Cant really see that good in there.
For some reason i used braided lines for everything else and used this one hard line for the oil feed. :/
Old 02-22-2012, 12:12 PM   #7
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
wrap the threads in teflon tape. works the best
R@ddy is offline   Reply With Quote
Old 02-22-2012, 12:25 PM   #8
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
No...no...no... teflon tape is for pipe threads (tapered threads) the banjo bolt has parallel threads and seals with the crush washer...if you have changed the crush washers and its still leaking chances are the hard line is damaged.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 02-22-2012, 01:05 PM   #9
beatd
beatd is an unknown quantity at this point
^^ is correct. OP i'm in the same boat as you. I even tried a longer banjo bolt and it still leaks. i'm down to just blocking it off and running a new feed line. I'm waiting for the weather to break so i can get wrenching again i miss driving my s13.
beatd is offline   Reply With Quote
Old 02-23-2012, 01:51 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Or the block is stripped...hopefully not.
CLICK HERE!!!
Old 02-23-2012, 01:57 PM   #11
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
^ if its stripped it can be re-tapped. but the turbo has to come out.
Old 02-23-2012, 02:08 PM   #12
Te37
Te37's Avatar
So yesterday I removed the whole hard line and both banjo bolts. Hard line has very microscopic hairline crack.
So I ordered braided line and hopefully that will last.
Btw you can access everything by removing hot pipe, intake, and turbo outlet elbow.
Old 02-23-2012, 11:59 PM   #13
KiLLeR2001
Trader Rating: (46)
I just replaced my turbo the other day, I usually put a little bit of red thread locker on the oil feed line into the turbo. Just make sure you don't put too much, you don't want it seeping into the turbo that's for sure.
Old 02-29-2012, 08:01 AM   #14
beatd
wait did you remove the hardline without removing the manifold and turbo?
Old 02-29-2012, 08:46 AM   #15
Te37
Te37's Avatar
Yes, thankfully the oil feed line is on top...you can just nearly get a wrench in there.
Old 03-02-2012, 06:53 PM   #16
killer skittle
killer skittle is an unknown quantity at this point
This is my oil line and adapters i have:
Can i use the black one (restricted) to go from the block to the braided line, and use the silver one (not restricted) to go from the braided line into the turbo? I really want to get rid of the banjo fittings all together.
So the my second question is, what do i use on these fittings to seal them up? The braided line is tapered inside so do i just use thread lock to hold those tight? And then do i use pipe tape to seal the fittings onto the block and turbo?
Thanks
sorry for big pictures!
killer skittle is offline   Reply With Quote
Old 11-15-2012, 11:44 AM   #17
Nikko
Nikko is an unknown quantity at this point
where did you get those fittings killer skittle? i need one to run from the block to the feed line. if oyu could send me a link to where you got them or the size of the AN fitting thatd be awesome!
Nikko is offline   Reply With Quote
Old 11-15-2012, 04:41 PM   #18
jr_ss
Next time PM the guy, don't bump a 8month old thread with a question he may never look at.
