02-12-2012, 08:13 AM | #1 |
Trader Rating: (53)
Feedback Score: 53 reviews
NC: FS: 240sx Parts Cleanout KA SR etc
Concord, NC 28025 Feel free to make offers Prices not include shipping [email protected] In not particular order S13 KA24DE Valve Cover with bolts $55.00 KA24DE Auto Flywheel Bolts $10.00 KA24DE Upper & Lower Timing Chains & Tensioners $35.00 KA24DE Idler Gear w/ boolt/washer, Upper & Lower Timing Chains & Tensioners - plus guide bolts $45.00 S13 KA24DE Intake Manifold - Missing IACV, Fuel rail & injectors (but I can get them if you want them) $50.00 240sx 5 Speed Bellhousing Bolts/Nuts/Washers - Missing 1 bolt $10.00 KA24DE/SR20DET Injector Caps - missing 1 isolator & screw $10.00 KA24DE Intake Manifold Bolts/Nuts $10.00 KA24DE/SR20DET Exhaust Manifold Niuts/Washers $10.00 KA24DE Starter - works $20.00 KA24DE Crankshaft Oil Pump Drive Spacer and Timing Gear $10 each or $15 for both Anything you see in the tub make an offer KA24DE Front Timing Cover with Oil Pump $35.00 KA24DE Block (comes with main bearing beam but will need to be line honed as its not the stock main bearing beam) - It is stock no machine work - perfect for your build project $80.00 8 Ton Hydraulic Long Ram Jack - This came off my Engine Lift - I use an air over hydraulic jack on mine - its like new condition $40.00 KA24DE Unorthodox Crank Pulley $100.00 S14 KA24DE EGR & EGR Tube $15.00 S14 KA24DE Throttle Body - No TPS $25.00 S14 KA24DE Head Cam Caps w/ Bolts $20.00 Michelin 3 1/2 ton floor jack - needs fluid bled $40.00 S13 KA24DE 5 Speed Tranny Harness - can be used on the SR as long as you swap out the SR tranny sensors with the KA Sensors $60.00 S13 KA24DE Engine Harness - Converted for SOHC Chassis Duty - I can put this back the DOHC Chassis Duty if need be $100.00 S13 KA24DE O2 Sensor and Water Temp. Sensor - Both work - they were removed for troubleshooting and new parts were used but was not the issue $10.00 for both S13 SR20DET Intake Manifold - Fuel Rail with injectors is included but no FPR (not pictured) - No throttle body (I can include a S13 auto TB if needed) - No throttle cable holder (only the bracket is there now) $65.00 without fuel rail & injectors $175.00 with fuel rail & injectors SR20DET ARP Head Studs (undercut) - 1 torque cycle $95.00 S13 SR20DET Stock I/C Hotpipe $20.00 S13 KA24DE Emissions Stuff on back of the head $20.00 KA24DE Clutch Slave Cylinder $5.00 SR20DET Timing Chain Tensioner $40.00 S13 Passenger headlight assembly $35.00 SR20DET Stock Oil Pan - has a bent and some sort-of bung on it $20.00 S13 Door Bezels & Cups - $15.00 KA Tranny Rebuild Kit (no syncros) - Should work for SR too $90.00 KA24DE Crankshaft - I have 1 needs to be ground down because of spun bearings - they should still have plenty enough left to ground down $75.00 89' S13 KA SOHC 240sx MT ECU with mounting brackets $55.00 A11-B02 G48 89 240SX N M F S13-KA24E 8.6:1 23710-40F01 I have 1 set of OEM mounting hardware for a S14 Zenki front lip $50.00 KA24DE 5 speed motor to tranny dust plate $50.00 SR20DET Coil pack harness - came off a redtop $45.00 shipped SR20DET tranny to motor dust plate $45.00 shipped SR20DET Flywheel - off a redtop needs resurface $25.00 shipped or $75.00 resurfaced shipped T25/T28 turbo to elbow gasket - $8.00 shipped T25/T28 turbo to manfold gasket - $5.00 shipped T25 turbo drain barb - $20.00 shipped SR20DET timing chain tensioner - off a redtop - $25.00 shipped |
05-26-2012, 05:09 AM | #10 | |
Trader Rating: (53)
05-28-2012, 11:31 PM | #12 |
Well my dyslexia got the best of me there, shipped to 83422 is what I meant. But I think I will take it. I will send payment shortly and the paypal will have all the information on it.
09-13-2012, 06:14 AM | #17 |
Trader Rating: (53)
jds-performance-parts.com
I also have them used too |
09-13-2012, 08:12 AM | #22 | |
Trader Rating: (53)
[email protected] - send as a gift or add the 4% fee |
