02-02-2012, 07:30 PM | #1 |
Mazworx Z32/ Endless/ Koyo & Electric Water Pump/ GT28rs/ SR etc..
Some stuff for sale: Located Northern VA
If you pay to ship it, then I will. If you have questions ask. Ill get the rest of the pictures up tomorrow. Z32 transmission with a Mazworx adapter kit. $1500 PENDING SALE Everything you need to run it, Adapter Plate, Bolts, Driveshaft, Starter, Shifter, etc Garret Dual Ball Bearing 28rs with a 60 hotside. $800 OBO It has a 4 bolt on the back with a vband adapter and a Vibrant 90 degree elbow on the cold side. Spins like a top, made 350 on a stock sr with cams @ 15psi on a Dyno Dynamics. Endless Front calipers SOLD FANS SOLD Koyo by it self $200 Electirc water pump and block off plate with AN lines SOLD Subframe things $40 PENDING Full Race manifold for SR, T3 flange single wastegate $500 PENDING Tial BOV $125 SOLD It can come with the pipe its on or I have a new flange and clamp that you can weld onto your existing set up. Tial 44mm Wastegate $200 PENDING SALE Vband on both sides, 15lbs spring Flipped Greddy intercooler made into midmount $125 SOLD It will come with two red vibrant couplers and 4 clamps I was running fixed pop ups. Small amount of trimming needs to be done to the core support. Will work with projectors as well. Polished Freddy intake $100 SOLD Comes with a block off plate on the IAC, and multiple quick disconnect vaccum fittings. Stock s13 throttle body too. SR with Greddy oilpan, Ported and Polished Head, Cometic HG, BC 264 cam and HKS adj. cam gears, autometer oil pressure and water temp sensors, alternator/ powersteering lightweight pulleys, Valve cover with custom AN breathers. $800 PENDING Vibrant Vaccum Block - $40 S14 Spindles w/ Parts Shop Max Angle Kit $300 PENDING JGY Fuel Rail with 1000cc Injectors $300 Rail will have to push lock AN fittings for either end for rubber hose Last edited by pigeon; 02-11-2012 at 04:16 PM.. Reason: update |
