Old 01-07-2012, 03:38 PM   #1
EnemyS15
EnemyS15 is an unknown quantity at this point
custom ac condenser ?s
Car = rhd s14 zenki
Motor = s1 Rb25det
I am purchasing a s1 Rb25 and need to tackle the condenser issue. I am planning on purchasing the chase bays tuck radiator with the fittings on the right side. Using that set up means I can't use the oem condenser. I have seen some people use civic condensers which I am considering. My question is. Is there any company that makes custom condensers to spec? Are there any other condensers that are a better substitute than a civic?
Thanks for any help/info
EnemyS15 is offline   Reply With Quote
Old 01-09-2012, 04:43 PM   #2
chiboy002
chiboy002 is an unknown quantity at this point
porsche condensers if you can find one
street dancer.
GLEAM
Old 01-09-2012, 04:54 PM   #3
Sileighty_85
Sileighty_85's Avatar
This might help
http://zilvia.net/f/chat/332057-project-rb-how.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-09-2012, 08:39 PM   #4
EnemyS15
Sil, I read through the post. I see the condenser and what you did. My question is, from where did you source the condenser? Is that one off a different car?
Old 01-09-2012, 08:56 PM   #5
Sileighty_85
Nah its a Aftermarket OEM Style one for the S14. Forgot the brand just found a cheap one online
Although, I would recommend just having a shop mod the OEM one like mine.
後輪駆動車1番
1986 SR86 - 200ish
Old 03-29-2013, 06:23 PM   #6
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
I know this is kinda old, But I was searching around to find a A/c condenser to use with a s13 with the PBM HMIC.
anyone have info on this?
rwtf is offline   Reply With Quote
Old 03-29-2013, 09:07 PM   #7
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
You should be able to run any equally sized condensor that will take up the same general area. Obviously you'll nee custom lines, but that's easy stuff.
Old 03-29-2013, 09:11 PM   #8
rwtf
rwtf's Avatar
not sure what you mean.
Old 03-29-2013, 09:37 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
As in a custom condensor will need to be used/mounted. From there an AC or Hydraulic line shop should be able to hook you up with the right fitment lines.
Old 03-29-2013, 10:50 PM   #10
rwtf
rwtf's Avatar
yeah I figured as much, just need to figure out how much that will be
Old 03-30-2013, 11:08 AM   #11
EnemyS15
I found that Honda or Porsche condenser works for those with limited space.
Old 03-30-2013, 11:22 AM   #12
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
Exactly.
I'm running a civic condensor in my s14 w/RB25 and have had no issues at all. I had custom lines made for $100.
2.5T_/<ouki is offline   Reply With Quote
Old 03-30-2013, 11:24 AM   #13
rwtf
rwtf's Avatar
any links or info?
Old 03-30-2013, 05:48 PM   #14
ultimateirving
ultimateirving's Avatar
GO to junk yard, find any small condesor not beat to smitherines, and place in front or behind intercooler depending on location. Then go to a place that has a TIG, such as radiator repair shop or local machine shop.. Whatev, get them to weld up some lines that fit to your car. Then charge with some freon..(assuming you have a compressor and a drier and at least a few lines that hook up to the compressor.)
Z32 with lq4 swap
Old 03-28-2023, 05:10 AM   #15
G_Low_Gr33n
G_Low_Gr33n's Avatar
G_Low_Gr33n is an unknown quantity at this point
Originally Posted by 2.5T_/<ouki View Post
Exactly.
Which year/model civic?
G_Low_Gr33n is offline   Reply With Quote
