12-31-2011, 12:54 AM | #1 |
DMAX,LS1 Stuff,S13,S14, RB26,TurboXS,N60,FAST,Accusump,ACT.
Greetings dudes and dudettes and fellow zilvians, welcome to my for sale thread.
Always willing to negotiate with reasonable people. Prices are OBO if you don't know what OBO means: OR BEST OFFER. It's kind of like bidding on it. You make an offer on the car/part, and if the seller likes your offer best, that's what you buy it for, even if it is less than the original asking price. Just so we are crystal, I will ship all of these items, unless otherwise stated. Here is what I have for sale: All prices are WITHOUT shipping. Shipping costs vary due to weight and location PM me for details. No international shipping. Brand New DMAX Silvia S14 ZENKI D1 Spec Wide Fenders [I believe they are +30mm] 395.00 OBO Brand New Speedway LS1 99-04 Full Stand Alone Wiring Harness. Mechanical Throttle body.[meaning "cable".] [pretty much like "Painless", or it could be, I got it from speedway though. Any questions about it PM me.] 600 OBO http://www.speedwaymotors.com/Painle...ess,12339.html S13 Hatch Kouki tails. I don't remember what brand they are, but they've only been mounted once, never on the car for more than five minutes. Pretty much new. The center piece plate has some peeling where the key hole is, barely noticeable though. 110.00 OBO S14 ebay tails w/o center piece. These are not in the best condition, but could be cleaned up nicely. They work great just need a little tlc. 30.00 obo just want them gone. ***SOLD to IRONMONKEY. Brand New TOMEI RB26DETT Ornament Plate. This thing is rad, never got to use it though. 65.00 SOLD to fullthrottle** Turbo XS RFL BOV ONLY no flange. Doesn't look like new its been sitting for a couple of years. Only used it for a couple of months when it was in use. 60.00 obo N60 MAF Decent condition, not sure what these go for 45.00 OBO Brand New Fast Fuel Rails for LS V8s. The hardware will not work with a 102mm manifold, its for the older version I believe. If you have a 102mm, Fast has a hardware kit you can buy off their site. 100.00 SOLD Hillkill** Brand New Pro 5.0 Shifter for T56 199.99 OBO OFFER UP! S14 SR Flywheel, Might have to re-tap a few of the holes where the clutch mounts to, but other than that its good, pretty much been beat up on, still works great though. 70.00 OBO ACT six puck sprung clutch, grabs like king kong, it has been beat up on as well, but not for very long and has quite a bit of life left. 140.00 OBO Brand New 3qt Accusump! With Electric valve. SOLD to fullthrottle** What is an Accusump? The Accusump is the original automotive oil accumulator. It is a cylinder shaped aluminum storage container that acts as a reservoir of pressurized oil, to be released when there is a drop in the oil pressure. The Accusump is connected to the pressure side of an engine's oiling system and is charged by the engines own oil pump. Its simple, efficient design revolves around a hydraulic piston separating an air pre-charge side and an oil reservoir side. On the oil side of the Accusump it has an outlet that goes into the engine's oiling system, controlled by a valve. On the air side it's equipped with a pressure gauge(on oil accumulators only) and a schrader air valve, which allows you to add a pre-charge of air pressure to the Accusump. The basic design of the Accusump Oil Accumulators and Accusump Turbo-Oilers are the same. However, the oil accumulators deliver oil to the engine before starting to eliminate dry start scuffing (pre-oiling) and discharges oil during low oil pressure surges to protect against engine damage during demanding racing conditions. The Turbo-Oilers deliver oil to turbos after shut down to lubricate and cool hot turbo components and prevent coke build up and turbo damage. ACCUSUMP : 360.00 SOLD ** Valued @ 180.00 + the accusump @ 260.00 Includes: Accusump 3 qt EPC 20-25 PSI pressure valve Mounting clamps The Accusump™ oil accumulator was designed to stop loss of oil pressure in racing applications. In road racing as cornering speeds increased and ground clearance decreased the ability for shallow wet sump oil systems to provide continuous oil pressure was becoming a problem. To solve this oiling problem an oil accumulator was designed to provide the oil required during the high load periods when the oil pickup became uncovered and pressure was compromised. Eliminating the momentary loss of oil pressure saved engines.The Accusumps success on the road racing circuit was soon noticed by drag racers who had their own set of oiling problems because of high acceleration and deceleration rates. The Accusump™ became the accepted way to provide more continuous oiling and add longevity to drag race engines.Over 25 years the simplicity and effectiveness of the Accusump™ has spread to all areas of motorsports and into all types of applications.The realization that most wear on a normal engine occurs during startup before oil pressure is established has made the Accusump™ popular in many non-performance areas. By providing pre-oiling the Accusump™ can extend the life of any engine. Parts Shop Max or PBM Swirl Pot kit. Brand New, never been mounted just opened. 80.00 SOLD to Skeeter** Brand New Parts Shop Max or PBM Oversized Rear Rotor kit/hardware. 350.00 OBO** PRICE REDUCTION 250.00 or 275.00 shipped! Dual Rear brake kit by George: 220.00 SOLD to cornloaf** So what exactly is it? This bracket allows you to use 2 pairs of Z32 rear calipers for AWESOME stopping power. One pair of calipers gets plumbed up like normal and works off of the brake pedal. The other pair gets plumbed SEPARATELY to the hydraulic handbrake. No more weird pedal feel when pulling the e-brake and the footbrake! You now have a dedicated setup for the hydraulic handbrake. I have two almost new HKS 740cc injectors will get pics @ request. 220.00 obo OS Giken twin plate clutch for 13B rx7 FC will get pics @ request 320 obo. I would recommend replacing the hardware. Anyone possibly interested in a 56k LS6 longblock I will not ship it, local pick up only. 1700 OBO price is flexible but I would mainly look for a trade of equal or some what close value. LS6 exhaust manifolds: 40.00 LS6 Stock Fuel Rail 40.00 LS6 Throttle Body DBW 40.00 LS6 FULL no cut Engine Harness 200.00 OBO Looking to get cash for this stuff, but I would entertain any s14 SR stuff or s13 coupe stuff. So send me your options of stuff, or cash. Stuff I need for the coupe: SAFC Electronic Boost Controller Ceiling carpet. Floor Carpet. Middle console. All the little plastic trim pieces. S13 Coilovers. Walbro or equivalent fuel pump. Aero either silvia or pop ups. No ghetto ish! Pop Up lights complete and working. Silvia Headlights triple/dual/brick SR Radiator SR S14 Intercooler SR Coolant Hoses/Rad. S14 SR Intercooler piping STOCK KA/SR shifter housing S13 One piece driveshaft S13 core support Any interesting trades will be considered. Also this isn't a Lowballer thread, so feel the need to stfu about idiotically ridiculous offers. Prices are OBO, if you think the price should be lower PM me if your interested and well work something out. My time is important don't waste it. Thanks for looking and keep drifting fun. I take paypal @[email protected], please, lets not get into any bullshite, I like zilvia.net and the people on here, lets not change that. If you are feeling cunty and have nothing positive to bring to the thread then you can go sit on a flag pole pm me for the lube if you don't have any. Please, don't forget how easy it is to press the back button. Last edited by bftII40; 01-28-2012 at 12:02 PM.. Reason: accusump price adjustment. |
12-31-2011, 06:28 AM | #3 |
Is that tomei cover the whole center piece that covers the coil packs, or just the center piece that goes on that piece... If that makes sense.
12-31-2011, 10:38 AM | #5 | |
They are pending, send me a pm and I'll let you know if they fall through.. thanks for looking.
Thanks sir! |
01-20-2012, 10:32 PM | #17 | |
TTT Last edited by bftII40; 01-28-2012 at 12:00 PM.. |
