Old 11-27-2011, 11:06 PM   #1
sandy ms6
sandy ms6's Avatar
sandy ms6 is an unknown quantity at this point
S13: dohc ecu, clutch pedal S14:engine/tran harness's, ps pump, brake booster
As title says I have some s13/ s14 stuff left over that I dont need anymore.
Sorry for the crappy pictures, I need a new phone lol
s13 dohc automatic ecu- 40$
eliminates the rev limiter on the 5speed
part number is # A11-B47 G10
you can check the number yourself if you have doubt that its not a dohc auto on the link: http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
s13 clutch pedal assembly- 20$
needs the sensors, but a great start on gathering a 5speed swap
s14 brake booster- 10$
s14 powersteering pump with bracket- 30$
difference between s13 and s14 is the s13 has 2 bolts on the backside and the s14 doesnt. and the s14 pushs around 1300psi compared to s13 1100psi
Heres a link if that doesnt make sense : Removing / Replacing Power Steering Pump : 240sx Articles
s14 abs drive shaft- 10$
I only have the one half sorry.
It measures 25.04" from center bearing mount to the diff and 27" from end to end
This will work for a 5speed swap, just make sure you get the correct length for the front part.
s14 engine wiring harness-60$
clean, has a couple broken clips, no cut wires!
Pictures go from ECU to the MAF, end to end...
s14 trans harness-30$
A little dirty but nothing out of the usual.
Im not completly sure but I think it from a 5speed.
It has 2 cut wires, which is to the 2nd to last sensor, easy fix.
Other than that everything is awesome.
Last picture shows where it was cut.
sandy ms6 is offline   Reply With Quote
Old 11-28-2011, 06:22 PM   #2
sandy ms6
sandy ms6's Avatar
Ill take trades and prices are OBO. Lemme know what you guys got
Old 11-30-2011, 01:40 AM   #3
sandy ms6
sandy ms6's Avatar
Bump bump bump
Old 06-12-2012, 09:15 PM   #4
stelth213
stelth213 is an unknown quantity at this point
im intrested in ur ecu but how far are you from hollywood
stelth213 is offline   Reply With Quote
Old 03-04-2013, 02:03 PM   #5
vincent_18
vincent_18's Avatar
vincent_18 is an unknown quantity at this point
can I pick up this brake booster from you today? PM me for quickest response.
vincent_18 is offline   Reply With Quote
ecu, power steering, s13, s14, wiring harness
