![]() Feedback Score: 14 reviews
![]() Making the switch to dual cam.
Located in Glendora, CA 91741. (626) 678-6984 Hit me up with questions/offers and whatnot. Will ship AT BUYERS EXPENSE. 1989 SINGLE CAM KA24E complete part out. Whatever you need!!! sensors, injectors, harness, ecu, power steering, etc... ALL PARTS CAME OFF OF A RUNNING VEHICLE. MOTOR PART OUT ONLY! KA24E head I'm pretty sure it's a little warped... may need to be resurfaced. ![]() ^^ Willing to part out i.e. cam, lifters, valves, springs and all that jazz. KA24E complete block ~160k mi. WAS RUNNING. RAN HARD. $50 ^^ Also willing to part out i.e. crank, timing components, pulley and all that jazz. Hicas power steering pump w/ bracket, high pressure lines and uncut sensor. Hicas power steering reservoir SOHC High pressure A/C lines. $25 SOHC EGR valve/pipe. $15 (1) Upper Harness for a KA24DE (DUAL CAM) only the consult clip is cut off of it. $25 (SOLD) ^^Still has all connections and dash connector. (1) DOHC Power Steering Reservoir. $10 (SOLD) KA24E SOHC UNCUT upper harness no dash connector. (depinned the wires from connector.) $45 (SOLD) SOHC dash cluster. (SOLD) KA starter. $30 ![]() Stock exhaust catalytic, piping and muffler. (SOLD) SOHC exhaust manifold & downpipe. (SOLD) SOHC Exhaust maifold O2 sensor. $10 ![]() SOHC power steering pump. SOHC power steering bracket. ![]() SOHC power steering reservoir. $10 ![]() (1) MAF sensor w/ top of airbox. (SOLD) Complete SOHC intake. (SOLD) SOHC Throttle body. (4) SOHC 270cc Injectors $30 (SOLD) SOHC fuel pressure regulator (SOLD) SOHC fuel rail. $10 ![]() SOHC power steering reservoir. $10 ![]() SOHC throttle cable. $10 ![]() SOHC Ignitor. $20 ![]() I have 3 SOHC ECUs: (2) AUTOMATIC. $25 (1) MANUAL. $35 ![]() Torque Converter. $20 ![]() Automatic flywheel. $5 ![]() Backing Plate. $5 ![]() ![]() Last edited by itsmejeremy; 03-11-2012 at 11:40 PM.. |
#16 |
![]() I apologize for all of the delayed responses. I haven't been receiving email notifications on this thread.
$15 sound good? Yes I do. How does $15 sound? I believe I already sold it, but I can check later today and get back to you with an answer and price. I still have the complete block. Just needs the head and exhaust manifold. I still have it here. $25 let me know what you think. Thank you Steve |
#19 |
Sounds good. Just want to make sure though, in the picture it looks pretty similar to the Dual Cam BPT valve, do you know if it will work with the Dual Cam? I think it should just need the "L" shape vacuum ports up top and one vacuum port on the bottom side.
#22 |
![]() Oh ok. Cool. Yeah, I have no problem with that. I get home from work at 5, so anytime after that is good for me. Text me for the address. 6266786984
