Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > Mountain States
Mountain States Colorado, New Mexico, Utah, and Wyoming.
Old 11-01-2011, 11:49 AM   #1
waverunner
waverunner is an unknown quantity at this point
CO emissions
just a quick question really. if i buy a 97-98 240 with an sr20 in it, will it pass the standards here? i tried reasearching but all i can find is east coast and az guys posting about it. i know standards are different for every state. not worried about the visual inspection just the nox, co and hc readings. thanksfor the help guys!
waverunner is offline   Reply With Quote
Old 11-19-2011, 10:20 PM   #2
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
AFAIK it'll run cleaner than the KA, so it should pass fine. I'm getting ready to register my SR'd coupe though, so I'll let you know how it goes. Always make sure your cat is nice and hot before testing though. Makes it more effective.
Z_Spool is offline   Reply With Quote
Old 04-07-2012, 05:01 PM   #3
jdo180
jdo180 is an unknown quantity at this point
any up dates ..
pass? if so --setup?
jdo180 is offline   Reply With Quote
Old 04-12-2012, 09:05 PM   #4
Z_Spool
Z_Spool's Avatar
I'm running around town on demo plates at the moment. Car's running lean right now so once I get that handled I'll attempt an emission check.
Old 04-16-2012, 12:37 AM   #5
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
cant wait to hear the results. just moved to aurora from california and i have to get my sr smogged
nissansrdub is offline   Reply With Quote
Old 04-25-2012, 01:11 PM   #6
atchiloonie
atchiloonie is an unknown quantity at this point
i have a s14 240sx with a sr swap and i live in the denver as well, it took me a couple tries to pass but you will be able to pass. go in for the first test and see how your results are. i had to replace the cat and used the denatured alcohol trick. hope all goes well!
atchiloonie is offline   Reply With Quote
Old 11-05-2012, 12:38 AM   #7
Zapiel
Zapiel is an unknown quantity at this point
Old thread, but we can have sr20det in colorado legally? My gf's family live in westminster near denver and we are thinking about moving back there from california. I was thinking about bringing a 240 hatch with sr in it from california.
Sent from my PC36100 using Tapatalk
Zapiel is offline   Reply With Quote
Old 11-05-2012, 01:10 AM   #8
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
I'd like to know as well. Moving to Steamboat in Jan
Looked at the regs online and they are confusing
Ch
Sent from my DROID RAZR using Tapatalk 2
heychris is offline   Reply With Quote
Old 01-24-2013, 01:11 AM   #9
Saiko88
Saiko88 is an unknown quantity at this point
Colorado Springs doesn't have emissions so most people register their cars here.
Saiko88 is offline   Reply With Quote
Old 01-24-2013, 03:41 PM   #10
atchiloonie
Sr motors in general are illegal in the states but u can stilll register them, not a lot of people will know that its a different motor so as long as u keep it quiet and tell them that the motor hasnt been swapped u should be good
Old 04-04-2013, 10:38 PM   #11
Z_Spool
Z_Spool's Avatar
FWIW, The emissions station south of Denver on Lipan St. is pretty lax. N/A'd me for not having a smog pump which was cool... New O2 sensor, vac lines, spark plugs, fuel filter, air filter, catalytic converter, half a tank of E85 and instructions to the workers at AirCareCO to drive her gently to keep it out of boost and I passed on low PSI snow tires. Finally have plates after having been driving around on expired California plates for a year.
Old 04-04-2013, 10:53 PM   #12
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
I heard from a friend Denver does a sniff test, Drive test, under hood inspection and CEL's.. and you have to drive the car a certain speed and engine rpm etc..
it's alot of shit to get past.
OrangeVirus1 is offline   Reply With Quote
Old 04-04-2013, 11:18 PM   #13
Z_Spool
Z_Spool's Avatar
its kinda all those things in one... they do a quick visual inspection where they check for your cat, o2, egr/smog pump and check for any CELs. If you have a CEL it's just and "advise" condition, not an automatic fail like in CA. After that they pull your car onto a dyno where they put the sniffer cone behind your exhaust and run the car through the test. It varies the driving condition simulating going from stop to city speeds, then to a stop and then getting up to highway speeds. Once that test is done they pull it up to test the gas cap and you're done. Avg. test time is about 20mins. start to finish.
Some stations are stricter than others. Like I said, the station on Lipan hooked me up, but the one just down in Sheridan tagged me for no EGR and they couldn't verify the serial no. on my cat. for whether or not it was emissions legal. Needless to say, I didn't go back there.
Old 04-17-2013, 10:39 AM   #14
sunk
sunk is an unknown quantity at this point
Denver can be rough depending on the jerk that does the test. Some are better than others. You could always register your vehicle outside of the Denver area. Greeley, Buyers, Franktown, Colo Springs, Grand Junction all have different standards and you can get away with alot of mods.
sunk is offline   Reply With Quote
Old 04-26-2013, 06:31 AM   #15
Akito86
Akito86's Avatar
Akito86 is an unknown quantity at this point
Whoaaaa Colorado it's so humble and nice hmmmm
Your state it's not trying to make a fortune from you guys,,,
I met a guy from Colorado very kind guy, California it's so hard on us, I notice op
Moved from CA to CO must be cold plenty thou. Well good luck everyone
I was just browsing around Zilvia decided to visit.
☆*Nissan-RPS13☆Nissan 350Z*☆ ☆*Toyobaru FRS☆Toyota XB*☆ ☆*o(≧▽≦)o*☆
Akito86 is offline   Reply With Quote
