Old 10-26-2011, 06:30 PM   #1
Z-Fever
Z-Fever is an unknown quantity at this point
Z-Fever:Anatomy of a Custom Intake Manifold (VQ35)
I am Doug from Z-Fever. We build custom cars and do a lot of custom fabrication. We are currently building a VQ35DE powered 280ZX (old school but cool). We had to make a custom upper intake manifold to get the OEM hood to fit without hitting the engine. So, I figured I would do a tutorial of what it takes to make a custom intake manifold from start to finish.
I hope you find it interesting and educational.
Enjoy....
We start by scanning the stock gaskets where the lower plenum meets the intake manifold and the throttle body gaskets. Once we do that we digitize them to work with our design software. The images look like this:
Then we create those 2D image into 3D images:
Then from those images we create the program that will tell the machine how to cut the blocks of stainless into these shapes. This program details the speed the machine rotates each bit, what type of bit to use on each cut, in what order to make each cut, and more. The finished products look like this:
From here we create the image of what we expect the finished part will look like. We take the finished 3D images and fuse them together into a complete image. We also rotate and measure as we go making each piece fit so that we can get to the bolts on the intake flange. We map out exactly where each mandrel bent 2" tube has to be welded to the flange so that the clearances are accurate. This is what that looks like:
Then we make the intake plenum side wall where the mandrel bent tubes meet the intake. We make this ONLY after determining where the holes need to go in order to be able to get to the mounting points of the lower flange:
Then we put all the pieces together and cut out the 15"x15" piece of 16 gauge stainless that the intake plenum will be made from, the 4"x7" pieces that the front and back plenum walls will be made from, and we start welding.
Here is a pic of all the pieces before welding:
Here are the (6) - 2" 90 degree mandrels:
Here is the folded 15"x15" stainless section:
We start by welding the mandrels to the intake side wall (you will see that the folded intake section is attatched to this side wall at this point but only to keep the side wall from bending and contorting its shape while being welded on):
Then we weld the mandrels to the lower flange:
Then we cut off the sections of the mandrels that are sticking through the side wall of the plenum:
Then we fit the rounded plenum section to fit the side wall. Making sure that the clearance to the valve cover is accurate and also making sure that we increase velocity of airflow away from the throttle so that the cylinders furthest from the entry point get an equal amount of air as the one's closest to the entry point:
Then we weld the throttle body flange to the 3" stainless mandrel intake pipe:
Then we weld the 3" stainless mandrel pipe onto the intake plenum at the angle we need to make the clearance to the valve cover and the hood.... It looks a little something like this:
(BTW... you may notice the Z-Fever logo plate on the intake tube. We already made the cold air intake pipe with the air flow meter flange we made welded to it rather than using the stock black plastic air flow meter housing, looks a ton better in IMO)
This shot offers you a good look at the inside of the intake after it is all together.
By tomorrow morning (maybe 30 mins after we open) we will have this all closed up and the engine will be running. We will post dyno #'s after we get them to see if we have any actual realized gains.
As always, I hope you appreciate our post.
Z-Fever, Inc 813-877-7600
www.zfever.com or www.VQ35swap.com
Z-Fever is offline   Reply With Quote
Old 10-26-2011, 06:35 PM   #2
revcyanide
revcyanide's Avatar
revcyanide is an unknown quantity at this point
looks a lot like a better made xcessive one, I am real excited to see actual gains!
Originally Posted by Blackzenki82 View Post
bring da ruckus to dat ass with the braaaaaaaaaassssssssssssshhhhhhhhhhh
revcyanide is offline   Reply With Quote
Old 10-26-2011, 08:01 PM   #3
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Lovely work! Is there any particular reason why you guys didn't go with a front mounted throttle body setup?
simmode1 is offline   Reply With Quote
Old 10-26-2011, 10:18 PM   #4
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
Hmmmmmmmm.... Is this piece backpurged? It's hard to tell but it doesn't look like it.
A lot of those welds look hotter than they should be. Could use a lot more practice to improve consistency.
atutt is offline   Reply With Quote
Old 10-26-2011, 10:28 PM   #5
sexcii-zenki
sexcii-zenki's Avatar
sexcii-zenki is an unknown quantity at this point
lol i want 1 but with the throttle pipe facing the right side...cant wait 2c the gains
sexcii-zenki is offline   Reply With Quote
Old 10-26-2011, 10:35 PM   #6
DreamDriveDrift
DreamDriveDrift is making a name for him/her selfDreamDriveDrift is making a name for him/her selfDreamDriveDrift is making a name for him/her self
How did you come up with the optimal design? In terms of runner length, runner diameter, shape of the collector, intake diameter, etc?
DreamDriveDrift is offline   Reply With Quote
Old 10-26-2011, 11:01 PM   #7
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
First thing i noticed was how terrible the welds are on the intake piping.. Please tell me they are just being used for fitment, because the intake manifold looks amazing.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 10-27-2011, 07:51 AM   #8
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
This is awesome!!!!!!!!
need to add to the fab thread when/if it comes back....lol
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 10-27-2011, 08:29 AM   #9
Highway Riding
Highway Riding is an unknown quantity at this point
Kinetix look alike? I had one. Meh.. sounded nice! The cosworth's are nicer. Nice fab work tho..
Highway Riding is offline   Reply With Quote
Old 10-27-2011, 08:43 AM   #10
OBEEWON
OBEEWON's Avatar
Good for biz!
Old 10-27-2011, 09:57 AM   #11
Bushido
Bushido's Avatar
Bad ass.
Lol at the weld snobs... But this is zilvia right?
Old 10-27-2011, 10:16 AM   #12
NickZ32
NickZ32 is an unknown quantity at this point
how bad did that flange warp?
NickZ32 is offline   Reply With Quote
Old 10-27-2011, 12:46 PM   #13
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Saw your thread on the 240sx VQ35DE Turbo!
very nice work
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 10-27-2011, 02:00 PM   #14
bardabe
bardabe's Avatar
needs back purge lots of crystallization inside the plenum, why not make it aluminum?
Review Thread
bardabe is offline   Reply With Quote
Old 10-27-2011, 09:47 PM   #15
trainkiller
trainkiller is an unknown quantity at this point
finished product?
Ricers are just people who have bodykits without being HELLAFLUSH bruh.
trainkiller is offline   Reply With Quote
Old 10-27-2011, 10:16 PM   #16
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by careboy View Post
Could use a lot more practice to improve consistency. Good job.
Are you speaking from experience or just posting to up your post count?
Sure we could pick it apart, but it looks fine and will undoubtedly make some power. Splitting hairs is one thing, but only on the internet do so many experts exist. Sure it could be better, but if it's already better than 90% of the junk created, what's the point in getting hyper critical?
Old 10-27-2011, 10:24 PM   #17
trainkiller
wait are you serious?
Just look at a couple of build threads. These welds are pretty damn good, compared to some of them.
Old 10-27-2011, 10:31 PM   #18
Def
Welds look fine to me, but the back of them needed to be shielded (backpurged or solarflux).
The weld-els have got to be heavy as crap though...
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 10-28-2011, 09:36 AM   #19
revcyanide
revcyanide's Avatar
what happened to posting the finished product yesterday! : P
Old 10-28-2011, 10:45 PM   #20
sexcii-zenki
thats why i came for as well
Old 10-28-2011, 11:06 PM   #21
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
look great can totally tell the quality is good and great craftsmanship
Old 10-28-2011, 11:17 PM   #22
tryangle
tryangle's Avatar
tryangle is an unknown quantity at this point
got my ecu and harness from doug, great work and when the motor isnt having issues it runs strong as hell.
tryangle is offline   Reply With Quote
Old 10-29-2011, 06:53 AM   #23
R33E8
R33E8 is an unknown quantity at this point
Wow, how much does that weigh?? Why not use aluminium? I can only imagine it would be much faster and easier to machine and cut (and weld for me)...
R33E8 is offline   Reply With Quote
Old 10-29-2011, 09:00 AM   #24
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
These are probably the same experts who call this piece of fucking shit "Hella nice welding":
omgRWDgoodness! is offline   Reply With Quote
Old 10-29-2011, 11:59 AM   #25
90white240
90white240's Avatar
90white240 is an unknown quantity at this point
O my what the f#$K is that^^^^^
90white240 is offline   Reply With Quote
Old 10-29-2011, 12:10 PM   #26
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
DON'T TALK ABOUT MY CUSTOM FRONT MOUNT TURBO MANIFOLD LIKE THAT!!! lol jk, whoever made that should have his fingers welded together...
pacotaco345 is offline   Reply With Quote
Old 10-31-2011, 08:15 AM   #27
conrad_s13.5
*sigh,.. leave it to zilvia
cONtRol FReAkS
Old 11-01-2011, 10:16 PM   #28
sexcii-zenki
mr. doug...
still waiting on the end results...thanx
Old 11-05-2011, 04:44 PM   #29
Z-Fever
Here is the finished and installed product w/ video
Here is the finished product installed along with video
And video of it running:
Z-Fever built VQ35 280ZX custom intake running.MOV - YouTube
Old 11-05-2011, 04:47 PM   #30
Z-Fever
We did that already on our VQ35 Twin Turbo Drift S14:
Here is the pic:
350z, intake manifold, plenum, vq35
