Old 08-15-2011, 08:36 AM   #1
ChiSleepyEyes
ChiSleepyEyes's Avatar
ChiSleepyEyes is an unknown quantity at this point
Send a message via AIM to ChiSleepyEyes
s14 sr20 blacktop seems to be dumping fuel
Ok guys, i've done some research and what all the other threads i can find on this show that it is either timing or a iacv not being plugged in, but under those conditions the car smokes out the exhaust. Mine doesn't smoke and it runs well, just goes through gas like no other. I've changed the plugs that were bad and still just the smell of gas. So, any ideas? Could it be a bad FPR? or am I missing something else here?
ChiSleepyEyes is offline   Reply With Quote
Old 08-27-2011, 10:44 PM   #2
colombianbryan
colombianbryan's Avatar
colombianbryan is an unknown quantity at this point
someone help!! i have the same problem :/
colombianbryan is offline   Reply With Quote
Old 08-28-2011, 11:25 AM   #3
nsfmike240
nsfmike240 is an unknown quantity at this point
check the o rings on the top of the injectors where the fuel rail is , the orings might of went bad
nsfmike240 is offline   Reply With Quote
Old 08-28-2011, 12:55 PM   #4
RedSiBaron
RedSiBaron is an unknown quantity at this point
If those o rings on the injectors were bad, id expect there to also be a leak...
What sort of engine management/controls are you running on this swap? Do you have a safcII?
RedSiBaron is offline   Reply With Quote
dump, fpr, fuel, s13, sr20det blacktop
