Old 07-29-2011, 12:30 AM   #1
Berto62085
Berto62085 is an unknown quantity at this point
sr20 rough idle trouble boosting
I recently have been having rough idling with my sr20 and was hoping someone can let me know if they have an idea on what it could be. I swapped in the motor about 2 months ago and have been just cruising in it trying to break in the new clutch. It's a stock swap with a walbro 255 fuel pump and 3 inch piping from the down pipe back.
Now this past weekend I was driving around and decided to open it up a little to see how it felt. Took off on first gear and it picked up really nice, shift to second gear and when I got to about 4000 rpms the car just lost power like something got disconnected. I pulled over and it sounded normal but when I revved it up and let go of the throttle the rpms dropped like if the car wanted to die out.
I drove the car home shifting like at 2500 rpms, and every time I would come to a stop the rpms would drop really low so I just feathered it a little before stopping and the car would idle normally but I could feel that it wasn't boosting like it did before.
I did a quick check under the hood and it looked normal, nothing looked disconnected. I'm hoping to work on it this weekend and if anyone can give some advise on what it could be I would really appreciate it. Thank you.
Berto62085 is offline   Reply With Quote
Old 08-09-2011, 11:05 PM   #2
Berto62085
Can anyone please give me some advice on what the problem could be?
Today I took it for a spin and when I gave it gas it would bog out whenever I hit 3000 rpms.
Could it be the fuel filter? I am currently running the stock fuel filter.
Old 08-09-2011, 11:15 PM   #3
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
that shud of been the first thing to replace .... check ur maf and check for boost/vaccum leaks those shud be number 1 to diagnose
jdm213 is offline   Reply With Quote
Old 08-10-2011, 01:54 PM   #4
ultimateirving
ultimateirving's Avatar
Im thinking ur intercooler piping has come off somewhere. First time really punching w/boost and those things pop off like whitehead on a zit.
Old 08-10-2011, 05:50 PM   #5
HOOCH
HOOCH's Avatar
HOOCH is an unknown quantity at this point
Id check fuel filter, check to make sure all ic connections are still good, then check to see what codes the ecu might be throwing
HOOCH is offline   Reply With Quote
Old 08-10-2011, 06:01 PM   #6
1llest13
1llest13's Avatar
1llest13 is an unknown quantity at this point
just curious what kinda of BOV are you using? a fake one might cause the rpms to drop. it could also be the timing. happened to me
1llest13 is offline   Reply With Quote
Old 08-10-2011, 08:46 PM   #7
Berto62085
Problem solved. I feel like such an idiot right now. I went to go work on my car, and noticed the piping that connects to the intake manifold got disconnected. I could have sworn I checked it.
Either way I'm still going to change out the fuel filter.
Thank you guys for your help.
Old 08-10-2011, 10:14 PM   #8
OkiDori17
OkiDori17 is an unknown quantity at this point
go to autozone or advanced or w/e auto store you like and pick up a z32 fuel filter, theyre really nice =]
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP
OkiDori17 is offline   Reply With Quote
Old 08-11-2011, 02:01 PM   #9
ultimateirving
Who called it?!?!?!?!?!
Old 03-08-2013, 01:06 PM   #10
mostdopes13
mostdopes13's Avatar
mostdopes13 is an unknown quantity at this point
boost and vac leaks are always the first thing to check lol glad you were able to fix it
mostdopes13 is offline   Reply With Quote
Old 03-16-2013, 04:17 PM   #11
240sx-pat
240sx-pat is an unknown quantity at this point
Send a message via AIM to 240sx-pat Send a message via MSN to 240sx-pat
quest
Guys I got a quick question my SR seems to be lacking power. I'm think it's because I've got a leak somewhere and the main place right now is from the downpipe to the testpipe I can feel air coming from it when it put my hand near it.
Could this be the cause of my slow ass SR? I mean my boost gage is showing that it's at 7lbs however I'm not feeling shit.
240sx-pat is offline   Reply With Quote
blacktop, boost, idle, rough, sr20
