07-23-2011, 01:49 PM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
Garage CLEARENCE! Z pads, wedge bracket, SR wiring, swaybars, bushings, more!!!
Redtop SR20DET coilpack harness
This is a great condition coilpack harness from a redtop SR20DET. All connectors, insulation, and wiring are in great condition. $20 Redtop SR20DET coolant temp sensor subharness This is the small subharness that goes between the main engine harness and the two coolant temp sensors. It originally came off a redtop SR20DET. All wiring/connectors are in good shape. $15 S-14 SE stock rear swaybar (bottom in pic) This is a stock S-14 SE 16mm hollow rear swaybar. It will work with either s-13 or s-14. The bar is in good shape, no bends, no significant rust. The endlinks are still attached to the bar, but I do not have brackets and bushings. $10 S-13 stock rear swaybar w/poly bushings (second from bottom) This is a stock s-13 15mm solid rear swaybar with energy suspension urethane bushings and brackets. The bar is in good shape and is what I used to use in the rear on my track car. $15 S-13 SE 17mm rear swaybar (middle in pic) This is a little thicker than a stock rear swaybar for those who want to try a small change. No bushings/brackets/or endlinks are included, but I do have urethane bushings available for this bar as well for an additional charge. $15 S-13 hicas 21mm solid rear swaybar (second from top) This is the stock swaybar off a usdm s-13 w/super hicas. It is 21mm in diameter and is solid. This is a significant upgrade from stock. Bushings/brackets/endlinks not included... SOLD! S-13 JDM 22mm hollow rear swaybar (top in pic) This is definitely the most desirable stock rear swaybar out there. Is is just a little under 22mm in diameter and is hollow in construction. It is very light and possibly one of the best rear swaybars available period. Bushings/brackets/endlinks not included... SOLD! S-13 25mm front sway, adjustable, w/bushings (top in pic) This is the swaybar that I personally used on my 240. It is a stock s-13 SE 25mm front swaybar, but it has been drilled for a stiffer adjustment. Trust me when I tell you that drilling out those holes was a big PITA, but it made a large difference in front end stiffness. Included are urethane bushings and brackets. SOLD! S-14 27mm hollow sway, adjustable (bottom in pic) This is a stock s-14 27mm hollow front swaybar, that has also been drilled out for a stiffer adjustment. This was also a big PITA to drill as well. This bar can work for s-13 or s-14. No bushings/brackets/endlinks included... $25 S-13 stock front endlinks w/poly bushings I used these before I went spherical. The bushings/joints are in good shape and the bushings are energy suspension urethane. $15 S-13 15mm poly rear swaybar bushings (unpackaged in pic) These are brand new urethane bushings for a stock s-13 15mm rear swaybar. $10 S-13 17mm poly rear swaybar bushings (bagged in pic) These are also brand new and pretty rare. Most companies don't offer bushings for the 17mm rear bars since they're not very common, even on SE's... $20 Porterfield R4S 300zx brake pads This is a full set, front and rear, of used Porterfield R4S brake pads for 300zx calipers. The pads are in very good shape. They have lots of meat left, just a little dusty from sitting on the shelf. I used them for a couple months and then the car got de-comissioned. $75 KA24DE M/T TPS This is a throttle position sensor off a manual trans KA24DE. It does not have the closed throttle switch. It was in good working shape when removed. $20 KA24DE fuel rail w/4 injectors This is an undamaged KA24DE fuel rail with all 4 injectors. All 4 injectors are in good working condition. $40 S13 KA24DE MAF sensor This is a good, working, S13 KA24DE MAF sensor. No damage... $30 Last edited by racepar1; 08-16-2011 at 09:34 PM.. |
08-03-2011, 12:16 AM | #4 |
I sent you payment for:
S-13 hicas 21mm solid rear swaybar (second from top) S-13 25mm front sway, adjustable, w/bushings (top in pic) On JULY 17. It's now AUGUST 2. Where are my sways? You haven't responded to my PMs, and I was hoping to receive them before my next track day, which is this coming weekend. Text me if you need to, (510)-566-5296 Roush |
08-03-2011, 12:51 AM | #5 |
^^ I was concerned too. I sent him my payment on the 18th and just got my part today. He never responded to me either, last activity was on the 25th. Maybe wait another day or two?
08-03-2011, 12:41 PM | #7 |
I know, he appears to be a very legit seller, that's why I waited a while, and that's why I'm not jumping the gun, just trying to contact him and see if they're coming because he said he was going to give me a tracking # when they shipped and I never got one. Hopefully they come within a day or two.
08-04-2011, 07:43 PM | #8 |
Okay, does anyone know this guy personally? Can I get his phone number or other way of contacting him? I've PM'd him tons and e-mailed him the situation. I need my parts!
08-16-2011, 01:22 PM | #11 |
He's been real busy lately, I know he moved recently and hasn't gotten his interwebs and home phone set up still, he has no cellphone, and he has been real slammed at work. I'll make an attempt to get ahold of him. I'll vouch for him that he isn't dicking you intentionally, he just has a shitload on his plate at the moment.
