Old 07-11-2011, 10:29 PM   #1
xxsptcuztomsxx
xxsptcuztomsxx is an unknown quantity at this point
S14,RB,Turbosmart,Q45 Brakes, Q45 Throttle Body, 56k Not a Chance!!!
After going through my parts storage unit i have determined that i have entirely too many unused parts and need to part ways with many items to make room.
Prices do not include shipping charges unless noted. I accept paypal and USPS money orders sent via USPS certified mail. If you have any questions at all please do not hesitate to call. I am located in Knoxville, TN. Most items will be sent USPS Priority Mail with Delivery Confirmation. All items are used unless otherwise noted.
If you have a question please feel free to contact me by texting/calling 865-323-5760. Quickest reply if contacted by text message.
1995 s14 240sx Automatic Transmission (120,xxx miles). Good Shape. So slipping or grinding at all. Shifts smooth. Just removed due to RB swap.
$65
1995 s14 240sx Open Diff. In good shape (120,xxx miles). A little dirty. Nothing wrong with it. Just removed this to install a vlsd unit. Good candidate for welded diff.
$50
1996 s14 240sx SE Auto output shafts(vlsd equipped). 3x6 Bolt Flange.Good shape.Boots are fine.Slightly dusty from being in storage.Includes both sides.
$40
1995 s14 240sx Automatic Trans KA24DE Radiator, Shroud, OEM Electric Fan. Item is in great shape! No leaks, no cracks in shroud, efans work fine. Nice setup for rb guys.
$100
Used downpipe for SR20DET. It is a bit rough...would be nice after some sanding and a shot of hi-temp paint. No holes. Just dirty.
$40
Used Q45 front calipers. In good shape. A bit dirty. I had plans to rebuild them and install in my s14 but ran across a good deal on a z32 setup. These are a great choice for the s13 & s14. Purchase a rebuild kit at the part store for a few bucks, clean em up, throw on some paint and you have some nice dual piston calipers that retains the same brake baisis as oem brakes.
$30
Brand new in original box 38mm wastegate by Turbosmart (14psi spring). Inlcudes everything shown in the picture.
$175 Shipped
Used n62 MAF sensor with the plug with about 8" of wire. The item is in perfect working condition and were removed from a running vehicle. They are packaged up and ready to ship.
$75 Shipped
Q45 80mm Throttle Body. Item is in good shape. Includes sensor pigtails. Packaged up and ready to go.
$70 Shipped
The following two pictures go with the Item list at the end of this post. Prices do not include shipping.
Item #1 - S14 OEM Rear Sway Bar $45
Item #2 - S14 OEM Zenki Tail Lights (missing emblem) $25
Item #3 - RB20DET OEM 270cc Injectors (all 6 are included) $40
Item #4 - Sony 4way 6x9's - $25
Item #5 - OEM RB20DET Intake Tube - $15
Item #6 - OEM RB20DET Crossover Pipe w/ OEM BOV - $20
Item #7 - Windshield wiper and turn signal switches $10 each
Item #8 - KA24DE Starters - $15 each
Item #9 - S14 Cruise Control Components includes actuator with cable - $25
Item #10 - S14 Auto KA24DE ECU - $30
Item #11 - S14 KA24DE Radiator Hoses $12
Item #12 - S14 KA24DE Intake pipes, filter, box, maf - $25
Item #13 - E61 RB25 MAF (chip on one mounting bolt) - $20
Item #14 - Ebay SSQV Blow Off Valve w/ adapter pipe - $20
Item #15 - S14 Windshield Reservoir with Solenoid - $20
Item #16 - Iso mount din pocket - $5
Item #17 - Edlebrock Valve Covers (for a 350) - $65
Item #18 - KA24DE Power steering pumps - $15 each
Item #19 - S14 Auto Shifter Assembly - $25
Item #20 - KA24DE ECU (s13 i belive) - $25
Item #21 - S14 Driver Side Door latch - $15
xxsptcuztomsxx is offline   Reply With Quote
Old 07-15-2011, 09:19 AM   #2
xxsptcuztomsxx
bump....i will accept reasonable offers and trades on most everything....hit me up fellas
blow off valve, ka24de, rb20det, s13 240sx, s14 240sx
