07-05-2011, 09:49 AM | #1 |
Massive 2JZ / S14 Partout thread
Name: Matt Willoughby
Location: Smyrna Items: See Below Contact: PM me, post in thread, or text at SIX 15 four82one737 Wellllll........I've been putting off doing this long enough trying to make a decision as to what to do, but I've finally come to the realization that it's best for me to do what I'm about to do. I've got so much stupid money in this build and I will definitely be taking a hit on it, but I've gotta sort out some of my own things and start over with what I think will be best for me, and my family in the long run. More stuff will be added as I get to it. And no, I will not sell you misc. pieces from the chassis. So without further adieu here goes everything....pics will be added over the next few days. And if someone is willing to dish out the cash for the whole thing, I will give them a deal on the whole shebang. Haters keep your comments to yourself, or your comments will be deleted. If you feel you have something to say to me, then PM me, as opposed to ruining my thread. Parts can come in packages for a bit better pricing, or it can be split up if I get enough interest in the whole thing. Dual Fuel pump setup for S14 Includes 2 Walbro in tank 255 pumps, The top for the return/feed lines, -6an lines for 2 feeds and 1 return, and (2) -6AN inline fuel filters. The setup was made to fit a 2jz, however, there is enough room to modify it to fit on any setup as the 2jz is on the opposite side and has to cross underneath car. $350 If separately: Walbro Fuel Pumps (x2) Part Number GSS341 $60 a piece Aeromotive FPR with gauge $200 Dual Pump Assembly/Hangar with no pumps: $100 -6AN Inline Fuel Filters 50 -6AN Line with fittings allowing for inline filters $125 FMIC $150 Piping $400 ISIS Suspension arms for S14. No I don't know the differences, nor what will interchange. ( I lied, I know the tension rods will, but not sure what else). They are all powdercoated starlight purple except the rear traction rod. $300 Megan Racing Track Series Coilovers (Only miles have come from towing, and rolling around my shop) $800 Oil Lines for a 2JZ turbo setup, but will work with others obviously depending on your fittings. $75 -10AN Drain line -4AN Feed line Tial 44mm Wastegate (Tial Purple Color with 11psi spring) $300 bucks. Comes with firing ring, however it will need the vacuum nipple on top Tial Q BOV (Tial Purple Color) $200 AEM UEGO Wideband $150 AEM Trueboost Boost Controller (opened to inspect but other than that, BNIB) $225 Samco Radiator Hoses for 2JZ (Water pump side has been slightly modified) $75 R154 Slave Cylinder $30 AEM EMS Version 1 (Will include AEM 3 bar map sensor and AIT Sensor) $1000 Hawk HPS Brake Pads for Z32 (30mm) Front and Rear $120 Drilled and Slotted Rotors for Z32 Front and Rear $120 or $70 per set S Chassis Conversion Lines for Z32 Brakes $75 Mishimoto Radiator (Originally for SR, however top inlet was cut off to be modified for 2jz, however can be welded back on for serious buyers) $100 Version Select Front Bumper $200 Sideskirts and Rear Aero (can't remember brand off hand, but I wanna say its version select as well) $250 for both, or 150 a piece Minty Ass S15 Headlights $350 3 Inch Turboback Exhaust for S14 with JZ Engine Swap (no catalytic converter-- straight back) $350 JZ Mount Kit for S Chassis Includes 2 engine mounts, and transmission cross member $250 1 Piece Steel Driveshaft for 2JZ into S Chassis. $200 2JZ GTE Engine with Brian Crower Valve Train *272 cams, and BC Valve Springs and retainers...mild port cleanup work, upgraded alternator, Titan Motorsports adjustable cam gears, aluminum water pump pulley, and alternator pulley as well. Intake Manifold tapped for AEM AIT and AEM Map Sensors, -10an Fittings welded to valve covers as well. Will come with all sensors and throttle body with TCS. Turbo Manifold can be included for the right price as well. Waterpump is new, along with timing belt. Motor has been cleaned up and painted. Does not come with fuel rail, or turbo $4000 S Chassis Bride Seat Rails $200 for both Crow Harnesses (purple) $150 Circuit Sports Quick Release and Thin Hub $125 for both Adapter to run Brembo 350z rotors on front of s chassis $75 240SX Solid Motor Mounts $85 3 inch Downpipe (Ebay 3 inch downpipe for 2jz) $75 Items in RED are SOLD Last edited by mwilloughby87; 07-16-2011 at 08:47 PM.. |
07-05-2011, 10:41 AM | #2 |
danggg ur close and i need coilovers hopefully i can get some money up. is this on tennspeed as well?
89 s13 silvia front new paint Ksport aspec blast pipes s14 sr soon **soco** |
07-05-2011, 11:20 AM | #3 |
Lots of swap parts.
Hey I would like to buy your fuel pump set up which is priced at $450 then your R154 slave for $30 then the s chassis z32 conversion lines posted for $75, jz motor mounts and cross member for s14 posted for $250, one piece driveshaft for the jz s14 $200 and solid mounts for $85. And your catback exhaust along with dp and test pipe. How much wold you give all of that to me for?
I'm basically doing your same build and will be using z32 brakes. Do I also need your custom clutch line for the slave with the mounting bracket? Do you also have the conversion plate for them to s14 nuckle? Thanks. |
07-05-2011, 03:46 PM | #7 |
Yes coils are on tennspeed as well.
Corvett, pm me and we can talk more, the biggest issue is gonna be shipping it out your way due to pricing, but if serious, we can get something worked out. Aled, got the text, sorry about that man. 2.2 - the headlights and bumper are pending right now. Ill let you know if it falls through And yes, I do still have the harness available. Its pnp for s14 into a 2jz. Tech 2 did the conversion |
07-14-2011, 10:53 PM | #20 |
Im interested in the dual pump set up parts listed below. I can pay asap. Let me know. e-mail me at [email protected]
Dual Fuel pump setup for S14 Dual Pump Assembly/Hangar with no pumps: $100 -6AN Inline Fuel Filters 50 -6AN Line with fittings allowing for inline filters $125 |
07-15-2011, 12:43 AM | #21 |
yes, ive been replying to pm's texts, etc. trying not to post in the thread because i don't want it locked.
front bumper and headlights have been sold fuel setup, fmic piping, wastegate, downpipe, igniter, and a few misc. other things have been sold. I will have a full update on whats available after tomorrow. anyone going to IA this weekend, let me know and I am willing to bring parts there if necessary. any missed texts, pm's etc, hit me up again and I will get it taken care of. |
07-16-2011, 08:48 PM | #26 |
Thread has been updated with all items that are still available.
If you missed a pm back, or still have questions, let me know. I know a few people texted asking for pics so I will get those to you as soon as possible. |
