Old 05-25-2011, 09:14 PM   #1
jimefam
jimefam is an unknown quantity at this point
S13 Drag Wheels
I'm building a drag S13 and wanted to find out what size drag wheels I need to buy to run the largest slicks possible. I'd prefer people with actual experience and not what you think might fit. I plan on running 15" rims unless you know 14" will clear the stock brakes.
jimefam is offline   Reply With Quote
Old 05-25-2011, 09:25 PM   #2
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
i would look into the Weld Drag light 15x8 5.5 Backspace in the 4x4.5 lug pattern.
you can run a 275/60/15 on those wheels. and Mickey Thompson makes about the best drag tires you can run.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 05-25-2011, 09:37 PM   #3
jimefam
Thanks for the reply that's the great first hand info I was looking for. On the tires though I see the MT listed differently like 28x10 what size would I get? Also what are you running in the front?
Old 05-25-2011, 09:44 PM   #4
Flicktitty
Flicktitty's Avatar
FYI thats not my car, but i am one of the few "drag" style people on here.
but tire size has alot to do with what class you run in, or if you just want a fast drag setup. and what suspension you go with.
this is the tire i would be getting, and will be getting.
Mickey Thompson 3754R - Mickey Thompson ET Street Radial Tires - Overview - SummitRacing.com
Old 05-25-2011, 09:51 PM   #5
jimefam
RB25det 1000HP Build : RB20DET / RB25DET / RB26DETT Forum
That's my build thread. I need the most traction I can get. I believe for most classes I can fit into the biggest I can run is 28x10.5 iirc but I'm not sure if that fits or even what that ='s in normal tire size.
Old 05-25-2011, 10:15 PM   #6
Flicktitty
Flicktitty's Avatar
at 1000RWHP S13 i would be looking into an automatic, and see if you can do some sort of ford 9" rear end swap. unless that breaks what ever class rules your looking to race. Also the 28 is how many inchs TALL the wheel is. and 10.5 is how wide it is. so some simple math can help you out.
Old 05-25-2011, 10:24 PM   #7
jimefam
Yeah I've got a coan racing TH400 already and I may swap in the 9" rear end but as you said I believe that would disqualify me from a few classes I'd like to run. Eventually I'll have to swap it in but I'd like to try and run it with the stock rear end and see how far it can get me.
Old 06-11-2011, 11:00 PM   #8
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
15x8 Weld RT's
235/60R15 but measured out is a 26'' x 9.5''
17x4.5 Weld Alumastars M&H 185/55
S@nt0s is offline   Reply With Quote
Old 06-14-2011, 12:43 AM   #9
Z28ricer
Z28ricer is an unknown quantity at this point
255/50-16 Mickey ET streets
16x8 RPF1's
Light, sticky and quality
Z28ricer is offline   Reply With Quote
Old 08-28-2011, 02:05 PM   #10
ke70 sr20det
ke70 sr20det is an unknown quantity at this point
bumping an old thread i bought mt et street radial in 15 size mt3750r that is 205/50 15 will it work on lightly modded sr20 for traction
ke70 corolla sr20det redtop t28 s15 7 psi stock motor
ke70 sr20det is offline   Reply With Quote
Old 09-11-2011, 03:21 PM   #11
sr20s13abel
sr20s13abel's Avatar
sr20s13abel is an unknown quantity at this point
600rwhp s13
275/50r15 MT on a 15x10 draglite 6.5 backspacing... these are my STREET tires..
for real hooking u need 15x8 5.5 backspacing and depending on power u can run 26x8.5 or 26x10 et draG !!.... 1.45 60' 6.46 @116 mph on 1/8 mile
sr20s13abel is offline   Reply With Quote
Old 03-14-2012, 06:30 PM   #12
Vetal
Vetal is an unknown quantity at this point
Is it only me, or these tires are too small for 275/60-15 (28")?
12.0@121mph 2.0 60ft, CA18 S13
Evo3 16G,XSPower ex mani, Nistune 950cc E85
Vetal is offline   Reply With Quote
Old 03-21-2012, 06:04 PM   #13
Vetal
For Weld Draglites, do you need to swap studs too (in the rear)? Or are stock long enough?
So many people run them but I couldn't find this out
Old 03-23-2012, 07:13 PM   #14
wayneSR20
wayneSR20's Avatar
wayneSR20 is an unknown quantity at this point
Send a message via Yahoo to wayneSR20
Summit Racing Lug Nuts 12mm x 1.25 .685" Shank Dia Chrome Set of 16
wayneSR20 is offline   Reply With Quote
Old 03-24-2012, 07:20 AM   #15
Vetal
Summit Racing SUM-7540120 - Summit Racing® Lug Nuts - Overview - SummitRacing.com probably?
I already found out that stock studs are not long enough - they're only 1.57" long, so 1.387" shank already takes up most of the length.
Seems I just cannot justify all the extra espenses and hassle with shank-style wheels for so little weight saving...
Old 03-24-2012, 08:31 AM   #16
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
stock studs are fine. I ran my Welds just fine with them.
PS: My Welds are forslae
15x8 Draglites, with 275 MT Drag radials. Expect to see a post soon.
KA-T_240 is offline   Reply With Quote
Old 03-24-2012, 09:28 AM   #17
Vetal
Do you have any close-up pics? I can't imagine how 2" long lug nuts are fine with 1.57" studs (and by the rules studs must protrude at least 1/10" past the lug nuts).
P.S. What's the price and BS?
Old 06-29-2012, 08:46 PM   #18
Adrenalinerush
Adrenalinerush is an unknown quantity at this point
hey im new here and was wondering if the 300zx factory rotor size with Q45 calipers will fit fine in my 240sx coupe with 15x8 rims with 5 1/2 backspace
Adrenalinerush is offline   Reply With Quote
Old 04-14-2014, 11:36 PM   #19
Mysterious Driver
Mysterious Driver's Avatar
Mysterious Driver is an unknown quantity at this point
Send a message via AIM to Mysterious Driver
Bringing this back from the dead, don't give a shit!
Ok so i'm having a little problems trying to get my drag wheel setup ideal. I ended up ordering Weld draglites with some troubling specs on them, I don't know much about wheels offsets and crap like that so that said my wheels are 15x8 4x4.25" and 4x4.5" back space.
Now i was told 4x4.5" is wider then a 5x5.5 back which didn't make sense to me the higher the number the wider the backspace is? Anyways i ended up getting some M/T ET drag radials 255/60/15 for the welds all though i originally wanted the 235/60/15 but oh well.
Few questions, i ended getting the summit racing lug nuts posted above in this thread originally and was wondering did anyone use Extended studs or are the lug nuts literally long enough to fit with the stock studs on the car through the rim???
Now for my problem the damn offset if really off on my car when i test fitted them i was hoping and thinking originally the wheels were going to sit flush inside the rear but guess not....
Friends were telling me to roll and pull the fenders, not my kinda thing so i'm thinking about adjusting and raising up the coilovers on the rear high any opinions?
Mysterious Driver is offline   Reply With Quote
Old 04-15-2014, 01:54 PM   #20
kovert240sx
kovert240sx is an unknown quantity at this point
I literally just got my wheels & tires yesterday. 235x60x15 MT ET radials. I also got the draglites but with the 5.5 backspace. They look like they'll fit perfectly flush on my S13 but I'm waiting on the lug nuts ( linked above ) before I can confirm.
To answer your question though: I don't see anyway your getting those inside the fender wells. I think the 4.5 backspace is the issue.
406hp/385tq- 11.43@121 Hatch(old)
599hp/454tq- ??@??? Coupe(new)
kovert240sx is offline   Reply With Quote
Old 04-15-2014, 03:18 PM   #21
jr_ss
Yep, you need higher offset(more back spacing).
Old 04-15-2014, 06:01 PM   #22
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I always thought thats the other way around, higher offset = less back spacing.
CLICK HERE!!!
Old 04-15-2014, 06:06 PM   #23
DJDANGER24
DJDANGER24's Avatar
Backspace measures the distance from the mounting plate to the back edge of the wheel. The higher the backspace the further into the fender well it will sit.
Looks like 5.5" would have been a lot better fit. Maybe even 6".
DJDANGER24 is offline   Reply With Quote
Old 04-15-2014, 07:22 PM   #24
Flicktitty
Flicktitty's Avatar
should have went with the 5.5BS
Old 04-16-2014, 09:39 PM   #25
Mysterious Driver
I know everyone i didn't know until i bought and paid for mines already to have gotten instead the 5.5 backspace so this really sucks like i said before i'm clueless when it comes to that offset BS.
Old 04-16-2014, 09:42 PM   #26
Mysterious Driver
Well my lugs came in today and i checked them for fitting and it looks like a pretty TIGHT fit! Can't say how they fit with my stuck studs as i can't do any test fitting until the weekend so hopefully you come out with a report before i do, here's some pics though...
Old 04-20-2014, 08:10 PM   #27
Mysterious Driver
Well The summit racing lug nuts fit great with the stock wheel studs thank god and best money spent on lug nuts! unfortunately i'm screw and probably be selling my Weld's as the fender is still sitting on the tire even after lifting the rear end up and maxing out the height on my coilovers unless i pull the shit out my fenders which i don't really want to do.
If i get lucky and manage to trade someone off for the right sizes i need which i seriously doubt it i can't do nothing with them meanwhile.
Word of advice to anyone looking for welds AVOID getting anything 4x4.5 back and less or your car will look like this unless your fenders are cut/pulled or running widebody.
Old 04-23-2014, 11:44 AM   #28
kovert240sx
Everything with mine fit perfect. Stock studs and all.
Old 03-20-2016, 02:48 PM   #29
Itsalexwoo
Itsalexwoo's Avatar
Itsalexwoo is an unknown quantity at this point
Were you running that street tire set up with no tubbing?
Itsalexwoo is offline   Reply With Quote
