Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 04-06-2011, 03:36 PM   #1
Lustgarage.com
Lustgarage.com's Avatar
Lustgarage.com is an unknown quantity at this point
Talking Sikky this Sikky that
Lust Garage now offers Sikky LS swap kits and parts for your S chassis, 350Z, or your G35!
Get a FREE t-shirt with any purchase over $200!!!!!
S13 and S14 LS1 Swap Kit $1,750-$1,950 shipped!
Kit Includes:
Aluminum Race Oil Pan V3
  • 7 quart high capacity design
  • 6061 CNC machined flanges from 1/2" material retaining OEM like structural rigidity. (not flimsy like other aftermarket pans)
  • Rear flange at bell housing allows install of factory dust shields
  • Baffle and trap doors to prevent oil starvation
  • New OEM oil pan gasket
  • Custom Oil pickup assembly
Remote mount filter Kit
  • 8 AN fittings (2) and stainless braided lines (2)
  • Remote oil filter base
  • High quality oil filter
  • All fittings and hardware
Engine Mounts & Transmission Mounts
  • CAD/CAM designed CNC machined solid 6061 T-6 aluminum mounts
  • Custom Urethane Bushings with true isolation
  • High Grade Hardware Kit
  • Proper Engine Placement and Axle Alignment
  • Lifetime Warranty on engine mounts
Trans Mount
  • CAD/CAM designed
  • CNC bent steel mount bracket
  • Urethane bushing
  • High Grade Hardware kit
  • Designed for use with the T56 transmission
  • Lifetime Warranty on transmission mount
Driveshaft
  • Steel One Piece Driveshaft with high strength 1310 U-joints
Optional Upgrades
  • Aluminum Driveshaft +$200
  • Solid Aluminum Mounts +$70
_______________________________________________
350Z/G35 LS1 Mount Kit $2,250 shipped!
Kit Includes:
  • 8 quart high capacity design
  • Oil pickup
  • Urethane Bushings
Trans Mount
  • CAD/CAM designed
  • Steel mount bracket
  • Urethane bushing
Billet Short Shifter
  • 6061 Aluminum Shifter plate
  • T304 Stainless steel shifter
  • Designed for use on the T56 transmission
Driveshaft
  • Aluminum One Piece Driveshaft with high strength 1310 U-joints
  • Drive shaft length is set up for use with a T56 transmission
Optional Upgrades
Full Line of Sikky Swap Headers Available!
LS1 S13/S14 1 3/4" Header $650.00
  • Uncoated mild steel 1 3/4" primaries with 3" collector
LS1 S13/S14 1 3/4" Header coated $945
  • Aluminum coated mild steel with S.S. V-band female flange 1 3/4" primaries with 3" collector
LS1 S13/S14 1 7/8" Header $695
  • Uncoated mild steel 1 7/8" primaries with 3.5" collector
LS1 S13/S14 1 7/8" Header coated $995
  • Aluminum coated mild steel with S.S. V-band female flange 1 7/8" primaries with 3.5" collector
LS1 S13/S14 1 3/4" Header Right Hand Drive $650
  • Uncoated mild steel for RHD vehicles - 1 3/4" primaries with 3" collector
LS1 S13/S14 1 3/4" Header coated Right Hand Drive $945
  • Aluminum coated mild steel with S.S. V-band female flange for RHD vehicles 1 3/4" primaries w/ 3" col.
LS1 S13/S14 1 7/8" Header Right Hand drive $695
  • Uncoated mild steel for RHD vehicles - 1 7/8" primaries with 3.5" collector
LS1 S13/S14 1 7/8" Header coated Right hand drive $995
  • Aluminum coated mild steel with S.S. V-band female flange for RHD vehicles 1 7/8" primaries w/ 3.5" col.
__________________________________________________
Front Sway Bar for S Chassis
S13 Front Sway Bar $279.99 shipped!
  • 32mm solid steel sway bar for S13 240sx JDM/USDM swapped engine
S14 Front Sway Bar $279.99 shipped!
  • 32mm solid steel sway bar for S14 240sx JDM/USDM swapped engine
Oil Filter Relocation kit $200 shipped!
  • Oil filter relocation kit for LS1 into S13/S14 240sx
LS1 S13/S14 Power Steering Line $135 shipped!
  • Power Steering line for LS1 into S13/ S14 240sx
S13 / 14 Master Cylinder conversion kit $250 shipped!
  • Sikky MC adapter plate
  • Sikky Clutch bleeder fitting and line
  • Wilwood performance master cylinder
  • All lines and miscellaneous fittings
LustGarage.com - Toll Free: (888) 761-8220
Lustgarage.com is offline
Old 04-06-2011, 04:37 PM   #2
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
do u have any pictures of an ls swaped on a s13?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline
Old 04-06-2011, 04:48 PM   #3
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Best price for S14 front sway bar shipped to 06082 please
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline
Old 04-06-2011, 05:59 PM   #4
Lustgarage.com
One of the best looking swaps I've seen and he did use the Sikky kit
Old 04-06-2011, 06:03 PM   #5
Lustgarage.com
PM sent! Thanks!
Old 04-06-2011, 06:09 PM   #6
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
Where are the brake mc on that s13 more info.please.
roboticnissan is offline
Old 04-06-2011, 06:48 PM   #7
Lustgarage.com
I believe he is using the wilwood brake kit similar to this:
Old 04-06-2011, 07:29 PM   #8
godrifttoday
Trader Rating: (82)
would their be any fabrication needed once installed? so direct bolt on?
Old 04-06-2011, 07:36 PM   #9
Lustgarage.com
There is some fabrication needed with just about any non-stock motor swap Sikky does have a "Write-Up" that you can look at to get some sort of idea.
Old 04-08-2011, 05:23 AM   #10
Lustgarage.com
Formula D Season starts today, get pumped!
Old 04-08-2011, 05:25 AM   #11
NismoPlsr
NismoPlsr is an unknown quantity at this point
Price on s13 front sway bar shipped to 06010? Thanks
S12 || KN13 || S13 || B16
NismoPlsr is offline
Old 04-08-2011, 07:37 PM   #12
Lustgarage.com
PM Sent!!!!!
Old 04-08-2011, 08:38 PM   #13
aalbert240
aalbert240's Avatar
aalbert240 is an unknown quantity at this point
so wats in the pic is all you need to make an ls1 work in a s13?
aalbert240 is offline
Old 04-08-2011, 08:42 PM   #14
Lustgarage.com
You will still need swap headers, a wiring harness (Sikky offers a custom harness service), and some other things. I can get you an exact parts list if you would like one.
Old 04-09-2011, 04:46 PM   #15
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
im thinking to switch to the cleaner look with the sikky ill hit you up soon
surge s14 is offline
Old 04-09-2011, 11:54 PM   #16
Lustgarage.com
Sounds good man, just let one of us know and we'll get you taken care of
Old 04-10-2011, 03:02 AM   #17
devilzdriver
devilzdriver's Avatar
devilzdriver is an unknown quantity at this point
could i get a list pm'ed to me? When i get back from deployment i wana do the ls1 to my 240....
Grip Grip Grip!!!
devilzdriver is offline
Old 04-10-2011, 10:27 AM   #18
Lustgarage.com
I'll get a list put together for you
Old 04-10-2011, 01:11 PM   #19
Shmex
Shmex's Avatar
Shmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfectionShmex is close to perfection
Send a message via AIM to Shmex
Hey Lust, same here. Can you pm me a list? thanks.
Shmex is offline
Old 04-10-2011, 02:02 PM   #20
Lustgarage.com
will do, thanks guys
Old 04-11-2011, 08:11 PM   #21
thenooblet
thenooblet's Avatar
thenooblet is an unknown quantity at this point
the only major modifications are trimming the windage tray and hammering the trans tunnel a little...its not any major cutting or anything
Originally Posted by towlie View Post
Texas does LS's hard
thenooblet is offline
Old 04-11-2011, 08:45 PM   #22
Lustgarage.com
Orders went out today! Get your swap kick-started and get those parts ordered today!
Old 04-12-2011, 03:01 PM   #23
khmer1
khmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymore
might be a long shot but do yah guys do toyota engine swaps mounts
khmer1 is offline
Old 04-12-2011, 03:29 PM   #24
Lustgarage.com
looking to do a JZ swap? I can look into it for you
Old 04-18-2011, 04:00 AM   #25
nisco
nisco's Avatar
nisco is an unknown quantity at this point
I might be interested as well. 1JZ into S13
Thanks
nisco is offline
Old 04-18-2011, 04:50 AM   #26
Lustgarage.com
Thanks
I'll start getting some info together on the swap this week then
Old 06-16-2011, 08:42 PM   #27
Lustgarage.com
Old 06-28-2011, 06:36 AM   #28
TheRookie
TheRookie is an unknown quantity at this point
Need a list pmd for everything on lhd s14 and also a rhd s14
TheRookie is offline
