Old 03-23-2011, 07:48 PM   #1
TheQ
TheQ's Avatar
TheQ is an unknown quantity at this point
Exclamation VLSD Problem
Hey guys I have a question and can't find anything anywhere on it so ill ask it here. I have a vlsd from a j30 but it did not come with a pumpkin. I am thinking of using my old open diff. pumpkin with j30 output flanges and j30 axles. Do you guys see any problem with this? would the output shaft even fit onto the open diff pumpkin and seal up correctly? Someone suggested that I swap the pinion gear from my open diff that it should work out fine as is. I never even heard of this was wondering if I can get some tips from you guys.
TheQ is offline   Reply With Quote
Old 03-23-2011, 07:59 PM   #2
Sileighty_85
Sileighty_85's Avatar
you cant use the VLSD Diff with the Open Diff Ring gear it wont fit. Open diff ring gears are thicker. You'd have to find a VLSD ring gear with the same Gear ratio as the Open diff.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-23-2011, 08:03 PM   #3
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I beg to differ. I just did this swap with a buddy of mine. He had S13 open diff pumpkin and we took the ring gear off of the open diff and put it on the J30 VLSD. Used J30 output shafts and axels.
Old 03-23-2011, 08:17 PM   #4
Sileighty_85
Hmm weird I tried this a while ago with a S14 VLSD into a S13 Open diff and the Ring gear would not allow the proper back lash.
Granted I was drunk,
Give it a shot
後輪駆動車1番
1986 SR86 - 200ish
Old 03-23-2011, 08:19 PM   #5
TheQ
TheQ's Avatar
IF this is so...I would have to go and grab a ring gear and pinion off a j30 correct? And this is going on an s13 not s14
Old 03-23-2011, 08:21 PM   #6
Sileighty_85
If the gear ratio's are the same.
S13/S14 doesnt matter they are the same R200 Diffs
後輪駆動車1番
1986 SR86 - 200ish
Old 03-23-2011, 08:56 PM   #7
KiLLeR2001
Trader Rating: (46)
Give it a shot
The important thing to remember is using the same spacers (that keep the differential snug) as the pumpkin you are placing it in. With the same ring gear + pinion and these spacers, the fitment is identical to that of the open diff.
We ran his car for a couple weeks and it worked great. He is getting new axles so we just recently pulled it back out to see if there was any damage to it and the oil drained out fine with little to no metal shavings on the magnet.
Old 03-23-2011, 09:04 PM   #8
TheQ
TheQ's Avatar
The guy I bought it from doesn't know the year that the vlsd came out of, is there anyway I can tell the difference between the early j30 vlsd and the later ones just by the internal itself? I don't want to go and get the output flanges and shafts and it end up being the wrong ones.
Old 03-23-2011, 09:12 PM   #9
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
To clear everything up, Take your stock open diff pumpkin off your car, open and pour oil out, undo the 4 bolts holding in the differential. pop out open diff. Make sure to keep track of what side each shim went on! After that pull the open diff pinion gear off and install onto the vlsd, install vlsd with shims on original side. make sure there is correct amount of backlash than fill up with gear oil, pop cover back on top and go for a drive.
http://www.youtube.com/watch?v=lz2BhokGWF4
check out the video it shows everything i just said
oh yea and no thats not me...
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 03-23-2011, 09:16 PM   #10
KiLLeR2001
Trader Rating: (46)
Originally Posted by Schassis707 View Post
To clear everything up, Take your stock open diff pumpkin off your car, open and pour oil out, undo the 4 bolts holding in the differential. pop out open diff. Make sure to keep track of what side each shim went on! After that pull the open diff pinion gear off and install onto the vlsd, install vlsd with shims on original side. make sure there is correct amount of backlash than fill up with gear oil, pop cover back on top and go for a drive. i will edit this post after i go find a video about it.
Hes using the s13 pumpkin. All he needs to do is use the ring gear from the s13 diff onto the J30 vlsd, get the correct flanges and axles. Put it back in with the correct shims from the s13 pumpkin.
Old 03-23-2011, 09:22 PM   #11
TheQ
TheQ's Avatar
Yeah the process now seems pretty simple. Still need a way to find out what year the diff internals are, if anyone knows please enlighten me
Old 03-25-2011, 06:41 PM   #12
TheQ
TheQ's Avatar
Hey here is the pic of the j30 vlsd. I'll put this in the identify thread too but if you could take a look and tell me if its from the early j30s or later j30s (6 bolt flange or 5 bolt) that would really help!
http://img819.imageshack.us/i/dscf3406l.jpg/
http://img576.imageshack.us/i/dscf3407n.jpg/
http://img28.imageshack.us/i/dscf3411a.jpg/
http://img600.imageshack.us/i/dscf3410z.jpg/
j30, open diff, pionion gear, pumpkin, vlsd
