Old 03-15-2011, 02:57 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
s13 confirming info on j30 lsd and axles
so ive been searching around and after already getting the wrong set of axles i just want to make sure i got this straight.
i have an s13 with what i think is the newer j30 vlsd because it is the 6 bolt one. i got 6 bolt j30 axles but the one seems too long so i guess the i needed the j30 axles for the earlier j30 diff.
so if i go to advance auto and order oem 240sx axles will they be the right ones need for this diff in this car? that is what i gathered from searching and just want to make sure its right. is there a certain model 240 i need the axles from?
thanks for the help.
HellaSexyS13 is offline   Reply With Quote
Old 03-16-2011, 01:29 PM   #2
HellaSexyS13
no one can confirm this for me?
Old 03-16-2011, 08:47 PM   #3
Corey121
Corey121 is an unknown quantity at this point
The only j30 diff that will work with 240sx axles is the 95-96 j30 diff it has a five bolt axle
Corey121 is offline   Reply With Quote
Old 03-19-2011, 01:09 PM   #4
gixxerbob
gixxerbob is a well-known jackass
dont listen to the guy above me, 95-96 was a 6 bolt axle flange and you can use your stock 240sx axles and an abs 240sx driveshaft
93 j30 diff was a 5 bolt axle flange and you need 93 j30 axles to fit it onto a 240sx. and you need an abs driveshaft
94 j30 was a split year and i believe they changed the axle shaft half way through so just avoid that year and avoid the confision.
gixxerbob is offline   Reply With Quote
Old 03-19-2011, 01:26 PM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
this information is readily available in the archive and faq section. If the OP had managed to do a search before asking this question he would have found it.
As usual an already answered question got asked followed by a post of misinformation which then lead to the need of a correction.
Search before asking it leads to less confusion.
New Video
Buy my mounts!
Old 03-22-2011, 04:53 PM   #6
HellaSexyS13
i did search thats why my post had the info i found and i just wanted to confirm it and thanks everyone
Old 03-22-2011, 09:52 PM   #7
Corey121
So sorry if i told him the wrong bolt pattern.
Old 03-26-2011, 03:35 PM   #8
titangts
titangts is an unknown quantity at this point
simple... the older j30 uses a 5 bolt set up..all you need is the j30 diff and j30 5 bolt axles for that diff...its a new one just drop your old diff and put the newer j30 diff on ( which are both 6 bolt).. thats it.. ppl make this harder than what it is.
titangts is offline   Reply With Quote
Old 03-27-2011, 12:04 PM   #9
HellaSexyS13
thanks, i got my car without axles, so i never had the oem 240 ones but thats what im gonna buy now
Old 03-28-2011, 09:02 PM   #10
c_mancuyas8
c_mancuyas8's Avatar
c_mancuyas8 is an unknown quantity at this point
Not trying to be a smart ass but do you know this from experience? Im trying to hunt one down now and im still unsure which to get? Cant find where this other guys saying its posted
c_mancuyas8 is offline   Reply With Quote
Old 03-29-2011, 03:29 PM   #11
since87
since87 is an unknown quantity at this point
95-96j30 diff is a 6bolt axle
since87 is offline   Reply With Quote
240sx, axles, lsd, nissan, silvia
