03-06-2011, 09:51 PM | #1 |
Anyone used - STANCE subframe conversion bushing
Im getting a s14 subframe tomorrow and need to buy conversion bushing as the s14 SF is wider than the s13. I was looking at the SPL ones because i thought they were the only US company(easy to get) bushing for the conversion. then I came across these.
Stance Nissan 240SX Subframe Conversion Bushing Set For the price these seem to be the best deal, and through FRsport they are free shipping.They look to be press in, but maybe they epoxy in like PBM ones? also they raise the subframe 10mm, so good for roll center! Anyone using these and like them/hate them? Are they press-in, like the SPL? Are they epoxy-in, like PBM? Thanks, Zac |
03-07-2011, 12:46 AM | #2 | ||
If Yes move on to question 2. 2.)Do you enjoy the feeling of having your ass pounded by the feeling of every single bump, crack rock on the road? If yes: BUY these. If no: Don't do it. Solid Aluminium/Aluminum bushings are no joke. Imagine coilovers on full stiff all the time.
03-07-2011, 09:42 AM | #4 | ||
and yes, I have searched them too |
03-07-2011, 10:05 AM | #5 |
There is a DIY thread in Tech for this so search....
But its burn out rubber bushings, cut and chisel out the casing, epoxy and slide them in.... you don't need to epoxy them if you have a friend helping you, its just a pain cause if you don't, those things will try to slide out and move around while you are pusshing up the subframe which is FRUSTRATING RAWR!!!
Turn and Burn! |
03-07-2011, 11:23 AM | #6 | |
03-07-2011, 11:48 AM | #7 |
i wouldnt think that you epoxy them in , remember that these are to center the SF, so if you glue them in and they dont alighn your screwed,
what i did instaling PBM's is i drilled and welded a small nut on all 4 corners and put a bolt threw it so it would press the bushings while i reinstaled the SF..... i have seen where some guys remove the second ring and the bushing wiggles around to much, that might need to be filled in with epoxy, other than that , washer a torque to spec and thats it as far as the product in discucion i have not used it or know of anybody that has , but would like to get feed back if you use it, they may work for AE86 /s13 subframe |
03-07-2011, 01:20 PM | #9 |
I dont thin there are any poly bushing for the conversion.
AND I know how to install solid bushings....I have installed normal SPL press-in ones and PBM epoxy-in ones before. I AM NOT LOOKING FOR A DIY INSTALL ON SOLID SUBFRAME BUSHINGS. I was looking for the style these install? 1. Press-in? 2. Epoxy-in? im assuming these are press-in...but if they move the subframe up 10mm, that means there is around 2.6mm of wiggle room between the subframe and frame rails. And if the bushing loosens up then the subframe will move. - OEM has about 1/2"(12.6) between subframe and frame rail. - 12.6-10mm = 2.6 wiggle room - STANCE bushing design dont have a top lip to keep subframe from moving up if it gets loose. if I am wrong about anything let me know.... |
03-07-2011, 01:49 PM | #10 |
Trader Rating: (24)
Feedback Score: 24 reviews
Well the spl ones come with extra spacers to take up the extra room.
I used SPL when putting s14 subframe in my s13 a couple months ago. Worked great. |
03-07-2011, 01:55 PM | #11 | |
Hey el gribro, has that made a noticable differance in handeling? The s14 subframe, I mean. |
03-07-2011, 09:03 PM | #14 | |
edit: i'm sorry, i just remembered you're looking at the stance bushings, not the spl bushings Last edited by fakts13; 03-07-2011 at 09:09 PM.. Reason: careless error |
03-07-2011, 11:10 PM | #15 |
Trader Rating: (24)
blah blah
This weekend is going to be the first (autox) event I make, but I've redone the whole suspension this winter so not sure I'll be able to pinpoint anything specifically. I run rs3s and star specs so I try not to burn those off as I can't afford frequent replacements. Yes, the spl bushings have the shims. You have to pound out the car a bit to fit the s14 subframe, just as an fyi. The hammer work becomes obvious when you're trying to reinstall. |
03-08-2011, 12:02 AM | #16 | |
Also e1_griego are you planing on doing any of the PIR driving club classes this spring? Once I just this s14 subframe in and my driftwork knuckles show up ill be going to try a couple of those out and maybe the pats acres drift if they are still doing that. |
03-08-2011, 12:04 AM | #17 |
Trader Rating: (24)
Yeah, the s14 subframe at the front has a hump whereas the s13 subframe at the front is flat. You have to clearance the car to fit it.
I did the Cascade school @ PIR last year. Sticking to autox this year (OR SCCA, PCA, NWAA, etc) because the mortgage has killed the budget btw I think we met at the Tualatin meet a few months ago. Show up this week and chat. |
03-08-2011, 12:16 AM | #18 | |
Translation: I pounded the shit out of my subframe. I am disappoint! you didnt take it to a shop and have them re-engineer it with custom fabricated points on the s14 subframe to make it a one stop bolt in process? tsk tsk. on a more serious note, please point me in the direction of this PIR driving school |
03-08-2011, 12:41 AM | #19 |
Trader Rating: (24)
No, you move the car to fit the subframe. Pay attention now.
Cascade Sports Car Club - Driver's Training |
03-08-2011, 12:54 AM | #20 |
MotorsportReg.com : Online registration management tools for driving and social events
you can see what dates they have the driving the class at PIR and the cost |
03-25-2011, 11:22 PM | #22 |
I called and talked with TF about the stance bushings and they said that the 10mm lift of the subframe from the bushings is a rough estimate and will put the SF up agaisnt the chassis just like the PBM ones. Also they told me that instead of having to hammer out the tranny tunnel so the s14 SF doesnt hit, they cut around a 1/2" of the hump and welded a flat steel plate in. I decided to take that approach but take about 3/4" just to be safe...
03-26-2011, 09:49 AM | #27 |
It does hit the chassis even with stock bushings. It's not hard to bang/pry on the chassis though.
03-26-2011, 11:55 AM | #29 |
Yeah I dont know how much it has to move up...
Either way I was bored and still have to wait for bushings, knuckles and tie rods to show up, so why not play with the welder. I also didn't want any extra noise coming from the subframe rubbing on the chassis, now im almost guaranteed its not going to hit. |
