02-22-2011, 12:39 AM | #1 | |
Trader Rating: (289)
Feedback Score: 289 reviews
Sr20detman's For Sale Thread Of Greatness ~ A Lot Of Parts
Updated February 24, 2011 10:43pm
4 Yakima Q38 Clips for coupe, hate to let them go but im done with the roof rack, I also have 3 of the pads for below the q tower. missing one. $25 Stock SR20DET Intake Manifold w/ Throttle Body and extras Comes with both gaskets in good condition, and whatever in picture, No IACV $65 Stock s13 Sr20det 370cc Injectors with Stock Fuel Rail and Stock Fuel Pressure Regulator $125 Stock s13 Sr20det Mass Air Flow Sensor w/ Apex'i Power Intake Filter $75 Stock s13 Sr20det Air Conditioning System parts I am missing the evaporator and 1 Line I believe - $85 Greddy Style Manifold Throttle Cable Bracket for Sr20det RedtopThis one is rough i can clean it up to look nicer $20 Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $80 Stock s13 Hatchback Brown Rear Interior Trim pieces for 3 Point Seat Belts and A pillar $60 Stock s13 Hatchback Brown Rear Interior Panels Arm Rest Pieces - $10 Stock Slave Cylinder Not sure if its KA or SR, or if that matters $5 SOHC Throttle Cable Not sure if it comes with bracket. $8 Stainless Steel Clutch Line Not sure if this is direct bolt on. $15 Stock SR20DET Oil Catch Can $15 Stock SR20DET Turbo Line $5 Stock SR20DET Exhaust Manifold Heat Shield $15 Clutch Fork$5 Throw Out Bearing stuff $5 any other random part in that picture. $5 or less. Stock SR20DET Thermostat $5 Front s13 240sx Stock 24mm Sway Bar Energy Suspension Polyurethane Black Bushings $10 Stock SR20DET Oil Block Adapter $25 Summit Racing Oil Relocation Fitting for SR20DET Stock Oil Block Adapter.Comes with rubber o-ring $15 10 Gorilla Lug Nuts Close ended tuner 7/16 thread used with morosso studs #21173HT $15 Rear 300zx Z32 Brake Calipers $80 Anything in this picture $5 s13 240sx Cusco Rear Sway Bar 18mm $100 s13 240sx Brand New Yamato Garage Rear Sway bar 27.5mmOne on Left, Just sway bar, No Bushings $95 Front s13 240sx Stock 24mm Sway Bar. $15 (2)6x9 150w 40ohm Dual Illuminite speakers. $15 Sr20det Rocker ArmsUsed, 8 Total $5each. or $35 as a set.
02-23-2011, 05:55 PM | #2 | |
heres a bump
ac and maf stuff pending. condenser might still be for sale. 4 rocker arms pending i have also had a lot of flakers. so non flakers are appreciated.
02-26-2011, 07:28 PM | #3 | |
I hear that, where are you located?
RELAX BRO!!!! |
02-26-2011, 07:41 PM | #4 | |
i live in oceanside and drive to orange county almost daily
02-26-2011, 07:52 PM | #5 |
Trader Rating: (81)
Feedback Score: 81 reviews
hey bro, ill take all the rocker arms for $35 if you can drop them off at my shop =)
http://squarespokes.com/ |
02-26-2011, 08:45 PM | #6 | |
currently 4 of the rocker arms are pending to AJ, if he doesnt need them ill bring them by
02-27-2011, 02:52 PM | #8 | |
i still have the injectors
02-28-2011, 12:20 PM | #9 | |
bump #2 lowered prices.
300zx, cusco, redtop, sr20det, z32 |
