Old 02-04-2011, 11:13 PM   #1
Touge_drifter
Touge_drifter's Avatar
Touge_drifter is an unknown quantity at this point
SR Maybe went overboard on SR build
A friend suggested I post on here for my engine build & Its a S14 SR20det
here is what im working with.
Nissan s14 throttle body upgrade (NA 60mm)
Nismo engine bearings
Nismo clutch slave cylinder
Nismo stainless steel clutch line
Nismo clutch pivot fork bolt
Nismo engine/transmission mounts
Balanced & Blue printed
Custom coatings (dome & skirts)
Tomei 2.2liter stroker kit (88mm)
Tomei metal head gasket (1.2mm)
Tomei Procam camshafts (260in./260ex.)
Tomei valve springs
Tomei bronze valve guides
Tomei adjustable exhaust camshaft gear
Tomei oil cap
Tomei spark plug cover
Crower titaninum retainers
Crower stainless steel valves
Custom port & polish
Arp block/cylinder head studs
Greddy intake manifold (version 2)
Greddy oil pan
Greddy oil catch can
Greddy remote oil cooler (14 row)
Greddy oil filter relocation kit
Greddy engine pulley kit
Greddy Greddy rocker arm stoppers
Custom front mount intercooler
Custom intercooler piping
HKS bolw off valve (flat black)
HKS iron sleeves
Splitfire direct coil packs
Koyo aluminum radiator
FAL dual electric fans
Samco hose
Sard thermostat
Tomei fuel psi regulator
Bosch 1000cc fuel injectors
Power enterprise engine belts
SPEC Mini twin system(sponsorship)
Taka stainless steel turbo lines
Custom turbo outlet pipe
Tial wastegates 38mm
Full-Race turbo manifold
Forgerd performance hybrid twin scroll turbo (classified a/r)
XS engineering down pipe with catalyst converter delete
AEM EMS stand alone w/map conversion
Optima deep cycle battery
Walbro 255glph fuel pump (x2)
Swirl pot w/-AN fuel lines
Block (HKS) sleeved
Tomei 2.2 kit
Crank shaft in
Bottom end assembled
No tune No life
Touge_drifter is offline   Reply With Quote
Old 02-04-2011, 11:15 PM   #2
Touge_drifter
Other shots of the pistons and rods
No tune No life
Old 02-04-2011, 11:17 PM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
looking good bro, looking good
S-Nation S13 is offline   Reply With Quote
Old 02-04-2011, 11:18 PM   #4
T-FAST
T-FAST is an unknown quantity at this point
very nice!
T-FAST is offline   Reply With Quote
Old 02-04-2011, 11:24 PM   #5
Touge_drifter
Head
No tune No life
Old 02-04-2011, 11:31 PM   #6
azsr20det
azsr20det is an unknown quantity at this point
you nutsack lol
wish i could afford the tomei bottom end kit...
im stuck here slowly piecing everything together
so far i got camshafts.
cant wait to see where this goes
azsr20det is offline   Reply With Quote
Old 02-04-2011, 11:40 PM   #7
BoostSlideWayz
BoostSlideWayz's Avatar
BoostSlideWayz is an unknown quantity at this point
Send a message via AIM to BoostSlideWayz Send a message via Yahoo to BoostSlideWayz
Fuck this makes me feel like a failure
1994 toyota supra...... n-a D=
1992 nissan 240sx KA24E-T fully Built =D
BoostSlideWayz is offline   Reply With Quote
Old 02-04-2011, 11:58 PM   #8
Touge_drifter
Head bolted down
Thanks to SPEC for this AWESOME clutch
No tune No life
Old 02-05-2011, 12:13 AM   #9
satek
satek's Avatar
satek is an unknown quantity at this point
Major $$$ build
satek is offline   Reply With Quote
Old 02-05-2011, 12:58 AM   #10
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
lol that clutch is so thick.
16 plate clutch all siiick
right on man, this motor is one of the few that can be called "fully built"
looking forward to numbers.
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 02-05-2011, 01:01 AM   #11
NoPho4u
NoPho4u is an unknown quantity at this point
Looks pretty damn impressive with all that Tomei stuff but then a spec clutch...
NoPho4u is offline   Reply With Quote
Old 02-05-2011, 02:39 AM   #12
Om1kron
Om1kron's Avatar
lololololololololololol. spending tons of money isn't impressive.
Wayne Edwards
https://om1kron.blogspot.com
Old 02-05-2011, 08:35 AM   #13
NoPho4u
Spend 5K on some baller ass wheels
Top it off w/ some LING LONG TIRES LOL
Old 02-05-2011, 08:39 AM   #14
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
mmmmm legitimacy
Pandapants is offline   Reply With Quote
Old 02-05-2011, 10:38 AM   #15
Touge_drifter
I like spec, Plus its free through my sponsorship. I had their modified 350z version (stage 3 + w/flywheel) on this engine before I did this build. As for the rims I have these.
Super advan version 2 front are 18x9 w/+15 and rear are 18x10 w/-8. it took me awhile to get (9 1/2 months) with the custom color (D1 spec gunmetal) and size.
No tune No life
Old 02-05-2011, 10:42 AM   #16
Touge_drifter
Greddy fuel rail and 1000cc top feed injectors
Greddy S14 sr20 version 2 high port intake mainfold
No tune No life
Old 02-05-2011, 10:42 AM   #17
NoPho4u
I was just giving you a hard time having all this top notch stuff but then having it topped off with the weakest link tho even if it was free. Of course it's clear money isn't an issue on your choice of parts. Why not go with a reputable brand with your own money.
OS Giken
Ogura Clutch
Nimso Copper Max
Exceddy
Old 02-05-2011, 10:50 AM   #18
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
mannn should have went with the VE head. Stock Neo VVL head will outflow the best DET heads and has no rocker arms so you can rev it to the moon and never have a problem while your rockin 280 cams stock haha!!!
JSimpson is offline   Reply With Quote
Old 02-05-2011, 10:52 AM   #19
dr1ft32
dr1ft32 is an unknown quantity at this point
Let's see the car
2013 Toyota Tacoma, Faster than your beater 240
dr1ft32 is offline   Reply With Quote
Old 02-05-2011, 10:53 AM   #20
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Who cares? ^^^^
But nice build man, I have the same sleeves, but you must to have robbed a bank to buy all this. Looking forward to see numbers and that turbo your hiding
jacobs13 is offline   Reply With Quote
Old 02-05-2011, 10:57 AM   #21
Touge_drifter
I like spec, its holds 1300tq and has stock pedal feel. what makes spec the weak link? Wouldn't have minded the OS Giken.....It would match the transmission gears Im going with. The Nismo has a harsh engagement and spec is all I have ever used even before the sponsorship.
No tune No life
Old 02-05-2011, 11:02 AM   #22
NoPho4u
Which Model Nismo are you referring to?
Also Spec clutch's are known to be budget minded american clutch which often times fail. Just do a search on here on their brand in general and you will find countless clutch's that didn't live up to their expectations.
I just felt all this money you spend on these upgrades almost goes to waste if your clutch isn't up to par.
Old 02-05-2011, 11:02 AM   #23
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
with this much money, i'd sell the built head and go p12 head.
SW Fab
shiftdrift is offline   Reply With Quote
Old 02-05-2011, 11:04 AM   #24
Touge_drifter
I didnt think about the VE head. Didnt know if it would work on a S14 sr20det. heres the car
No tune No life
Old 02-05-2011, 11:05 AM   #25
NoPho4u
Seen that car on here before. What are the details on the aero?
Old 02-05-2011, 11:09 AM   #26
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
it is your car, so if you like it that's great, i'm just not feeling the flat black, doesn't seem to be able to pull it off.
SW Fab
Old 02-05-2011, 11:21 AM   #27
fckillerbee
fckillerbee's Avatar
the wheels are sex.....the amount of gap between your fender and the actual rear wheel makes me want to vomit on a daily basis...throw a 1 inch spacer on there and it'll do gods of wonder....
nice fucking build man....good luck trying to blow that up...very NICE.
Old 02-05-2011, 11:22 AM   #28
Touge_drifter
I have to get it resprayed again. I wanted to do a ocean blue metallic, But kinda undecided on different color. as for the car being on here before. I just signed up on here in November.
S15 conversion (orgins bumpers, fenders & custom rear panels)
S15 wide body (+20mm-f & +80mm-r)
Satin matte black paint
AB Flug carbon fiber hood
Seibon carbon fiber trunk
Kouki taillights
Locking hood pins
Hid conversion kit
Advan Super advan ver.2 rims (discontinued D1GP spec gunmetal)
BFGoodrich T/A KDW2 tires 245/18-f & 285/18-r
Rotora 6piston front big brake kit
Rotora 4piston rear big brake kit
Project Kics Neo/Chrome lug nuts (open-ended)
Project Kics 60mm extended forged lug nuts
HKS hyper exhaust system (85mm)
Rearview camera (for mirror)
Window tint
No tune No life
Old 02-05-2011, 11:26 AM   #29
Touge_drifter
Wheels are fix already. Heres the turbo (1st turbo), full race manifold, new Tial wastegate
No tune No life
Old 02-05-2011, 11:29 AM   #30
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
this thread is so full of win......and +1 on the ocean blue
SW Fab
