s13/s14 garage sale; clearout my garage
Alright guys, I'm moving on from my 240 and it's time to clear out all my parts. These are left over parts from my build and items i picked up along the way. I will ship at your expense. prices are negotiable but no low ball offers I'll just ignore you. I'm putting what ever I can't sell on ebay in a week, thought i'd give you guys first dibbs.
I dont have all my pics up I'll try to get them up as soon as I can. List: Greddy s13/s14 sr20det MAF Filter. bolts right in. - SOLD ![]() Greddy s14 IC Piping. (NEW) This is the aluminum piping you get when you buy the s14 greedy front mount kit. - 90.00 - 3 pieces no hoses ![]() Greddy s14 sr20det Hot Pipe with HKS flange and nipple already welded in. - SOLD ![]() Greddy s14sr Turbo outlet pipe - SOLD ![]() HDI s14 sr20det aluminum IC pipe, this one is the one from the IC to the intake. - 30.00 ![]() s14 sr20det Head comes with valves no springs or cams. 75.00 s13 sr20det Redtop block only std bore - 70.00 s13 sr20det stock crank std - 50.00 ![]() s13/s14sr crank pulley has a couple of chips but works fine - 15.00 ![]() s13/s14 sr20det cp pistons 87mm nitrate treated. - 400.00 These were used on my first s14 sr build. they have about 1000 miles on them. pulled the block apart when I started hearing a noise. the head turned out to be cracked scrapped the head and ended up buy a whole new built bottom end. I was going to build a s13sr with them but decide not move foward with it. ![]() ![]() ![]() BC sr20det intake valves +1mm oversized (NEW) 2 sets 60ea set. ![]() NOS 50 shot dry system with 10lbs tank (FULL) and trunk bracket. ran this on my KA for about 4 years worked great been sitting for about 1 year now. - 70.00 ![]() ![]() s13/s14 KADE - K&N air filter - 10.00 ![]() FAL 220 electric fans with DIF controller - (NEW) 400.00 Never used them both still in the box, opened to take pics. ![]() ![]() s13 dual cam clusters. 1 - 135,xxx. - SOLD 1 - 145,xxx miles - SOLD ![]() sr20det Coil packs - 4 good had them on my s14sr - 50.00 ![]() sr20det - good off my s14sr ignitor - 50.00 ![]() s13 sr20det injector insulators (NEW)- they go on the intake - 5.00 ![]() SR/KA Circut Sports short shifter. missing the 4 screws that hold the shifter plate to the base. pick some up from a hardware store. - SOLD ![]() Oil cooler with lines and heat shield 8an fittings- 250.00 ![]() ![]() T28 - Turbo hardlines from my s14sr - SOLD ![]() T28 turbo Actuator (NEW) - from my 2871R Garrett turbo - SOLD ![]() Spark Plugs sr20det - NGK BKR7IEX used for about 3000 miles switched to greddy heat range 8. - 25.00 ![]() Spark Plugs KA - NGK BKR7IEX -11 NEW these were bought by mistake these are for a KA not SR. - 30.00 ![]() s13 steering rack was rebuilt a year ago will come with new boots- 100.00 ![]() ![]() TEIN s13/s14 Tie rod ends and Arms (NEW) - SOLD ![]() s13/s14 clutch master cylinder with Nissan rebuild kit - 30.00 - if you want me to rebuild it - 40.00 ![]() s13 Zenki original side skirts - these were used on a drift car they have cracks but are still good. should be able to repair them. SOLD ![]() s13 Type X Body Kit all original Nissan parts. - I will not part out don't ask. New front bumper with extensions grills and lights. New front bumper upper support Kouki 4 piece side skirts Kouki 3 piece rear bumper skirts 180sx Glass - just glass Kouki tail lights - these are still on my car. I will take them off once items are sold. s13 Wing not original Nissan, it needs a bit of work were it bolts on but easily fixable. 1600.00 takes all. 1300.00 minus the Tail Lights. The boxes are up in the attic If your really interested and have the money I'll take them down unwrap everything and send you pics or if your local you can check it out yourself. until then these are the pics I was able to take. ![]() ![]() ![]() ![]() ![]() Pm me with any questions about the items. Thanks, Jorge Last edited by jorgezee1; 01-12-2011 at 04:55 PM.. |
#6 |
Not splitting the 180sx glass or taillights, I'm only selling them as a package for now. your more then welcome to come and pick up the steering rack and endlinks. Don't think i noted it but the Tein stuff is new.
Thanks for the interest. Jorge |
#7 |
how much do you want for the wastegate shipped to 45426? and whats the wastegates set psi?
#8 |
Waste gate and Turbo hardlines are Pending, if it falls through I'll PM you. Not sure on the PSI. It came with my 2871R Garret turbo I bought from Phase2Motortrend. You can probably call Alex or Howard and ask them or I can call Monday to find out. I want to say 16-18psi, this is a guess If someone else actually knows please chime in.
Thanks, Jorge |
#10 | |
anytime this weekend. I'm in west covina let me know when you want to swing by.
#13 |
Any scoring, rust, pits, cracks and/or damage of any kind? Ready to be installed without any additional work being done? Are you willing to pack this really well to prevent any shipping damage? Would you be able to drop this Item off at the nearest FEDEX shipping store after I send you the shipping label via E-mail? I am interested, Please answer all questions, do you have a PayPal account? |
#14 | |
sr20det std Crank
The crank was pulled from a stock redtop block I bought that is also for sale. The crank is not a drop in item. it has been sitting for about 3 years or so and there is a bit of flash rust although its sprayed down with wd40. is it usable? Yes. there is no cracks or scoring on the journals. If the crank was a drop in crank I would be selling it for about 3 times of what I have listed it for. any good shop should be able to clean it up and check for straightness. If your interested in a drop in crank this is not the crank for you, sorry. I would look for a crank still in a case or just pulled. If your interested in paying for it I can send it to the shop I go to called Castillos Crankshafts and have him clean it up or prep it for a high horspower sr20det. He can ship it to you straight from his shop to you as well. hope I answered all your questions
Thanks, Jorge Quote:
#18 |
How much for the aero minus the quarters (don't need) and the wing (not OEM) if you decide to part.
"I am not good English, I like the drift" CHINA DRIFT "some guys have a better relationship with their car than their wife haha. sad but true." SECRET SOCIETY |
#19 |
not much of a price drop. but everything minus the glass and wings 1450.00
- 100.00 for the glass and - 50.00 for the wing. all the pieces are in great shape the front is new with all the lights grills and brackets. the side skirts are used but they solded I think there might be 1 or 2 tabs that are cracked but still usable, the 3 piece rear bumper lip/skirts.. they are good, solid not cracked all tabs are there. every things is in my attic and it's been there for about a year now. well kept. thanks for the interest. Jorge |
#26 |
