10-28-2010, 07:48 PM | #1 |
FS: 3071 Full Race kit, Build sr20det, Maxworx sr-z32 trans setup and more
Parting out my sr setup.
This setup helped me alot this year and because of it I didn't miss a single event. Everything I put in my car is quality parts and it shows in power and realiblitiy. Events suck when you have to fix things over and over again. Do it right the first time. 3071 Full Race sr20det kit $2500 Full race T3 twin scroll manifold Full race mid pipe Garrett 3071 twin scroll Turbo Tial 44mm waste gate w/ 1 bar spring T3 turbo blanket -6 coolant lines -3 oil line with reducer -10 oil drain line 4 inch intake with filter All lines are heat wrapped 5 layer s15 exhaust gasket twin scroll turbo gasket Built sr20det $2000 Stock crank with OEM nissan bearings Eagle rods CP 9.0:1 compression pistons Cometic Headgasket HKS 264 step 2 cams Greddy Rocker Arm stoppers peak performance valve springs When the motor was put together Other new oem parts where used like: Oil pump Thrust washers timing chain tensioner timing chain valve seals Motor oil has been changed everyother event and I have only used synthetic 15-50 to keep the bearings nice and fresh. Maxworx sr to z32 transmission adapter kit with z32 transmission $1500 Maxworx adapter plate w/ hardware Mazworx shifter braket w/ shifter Mazworx driveshaft z32 Transmission in perfect working order Competition clutch twin disk used for about 9 events. $700 Still has lots of life on it. This is a picture of it when it was new Power FC with commander d Jetro with map sensor- 1000 SR20 engine wiring harness with voltage reducers for rc injector- 200 Splitfire coilpacks- 400 RC engineering 1200cc Injectors with plugs- 500 Top feed fuel rail- 100 Sard FPR- 150 Mid mount intercooler made for oem intake manifold and top mount turbo w/ tial BOV Includs all t bolt clamps and couplers- 500 S13.4 valve cover- 300 Greddy oil pan– 200 Derale oil cooler w/ fan block adapter and all lines- 400 ATI super Dampener- 300 Stance water pump pulley- 100 SR alternator rebuilt to put out 120 amps instead of usual 80 amps- 160 Power steering pump with high pressure line and cooler- 200 Oem intake manifold polished w/ thermo intake manifold gasket- 150 More pictures and items will be posted in the next few days. I am willing to negotiate with the prices and the more you buy the more I will reduce the price. I am willing to ship at the buyers expense.
Autobodylv.comworldhookah.com endura-tech.comvegasdrift.com Last edited by lv240s14; 10-31-2010 at 04:58 PM.. |
10-28-2010, 10:21 PM | #4 |
It works amazingly well. After drifting with this trans setup I realized how bad sr transmissions are.
Autobodylv.comworldhookah.com endura-tech.comvegasdrift.com |
10-29-2010, 07:07 PM | #6 | |
2500 plus shipping depending on where you live and how much shipping is.
Autobodylv.comworldhookah.com endura-tech.comvegasdrift.com Last edited by lv240s14; 10-29-2010 at 07:43 PM.. |
10-29-2010, 11:33 PM | #8 |
Actually it was close to the same. I noticed no difference in top end or acceleration. The only thing I noticed is a strong feeling transmission that I could upshift without feeling the trans was going to blow. This thing is rock solid and strong.
10-30-2010, 12:20 AM | #9 |
i have same trans setup,, feels a little longer geared to me.. depends on the rear end you are using. if you have 4:08 r32 or 4:10 z32 it should be around the same as Sr trans and J30 with the 3:91.
10-30-2010, 01:15 AM | #10 |
http://ep.yimg.com/ca/I/phase2motors...2127_123169747
according to this they are about the same and to me it feels the same. I don't know how much .023 in second gear out make.
10-31-2010, 04:44 PM | #15 |
I ran a 1.1mm headgasket. I tuned the car for 21psi but never ran that much. I ran 18psi during the season because of the smaller courses I ran on didn't need the extra power.
12-02-2010, 12:07 AM | #20 |
sorry for the late update but turbo kit is sold.
motor and accessories still up for grab. I suggest getting everything as a whole for a discounted price. midmount is still for sale too. pm me don't post on the thread if you guys want something it's easy for me to see if someone wants something that way
3071, full race, sr20det, z32 |
