Old 07-12-2010, 10:33 PM   #1
jing
jing's Avatar
jing is an unknown quantity at this point
Clunking noise when braking
I have clunking noise coming from the drivers side up front under braking, light or hard (the harder it is, the more noticeable the sound), and nothing when stopped and I hit the brake. This sound came about a week after I installed my coilovers and TC rods. Everything was torqued to spec according to the FSM. I checked it over just now to see if anything came loose but everything appears fine.
Any other suggestions?
jing is offline   Reply With Quote
Old 07-13-2010, 01:34 AM   #2
Xplat
Xplat is an unknown quantity at this point
Sounds like warped brake rotors, replacing the pads helps quiet the noise but it will come back until you replace the rotor. Otherwise, everyone is just going to guess that it could be anything. Look at your car there's only so much that holds your wheel on...
Xplat is offline   Reply With Quote
Old 07-13-2010, 01:49 AM   #3
mad-ass
mad-ass's Avatar
get you some rear subframe collars or new subframe bushings.
that's where the noise is coming from.
Old 07-13-2010, 01:58 AM   #4
510-SR20DET
510-SR20DET's Avatar
510-SR20DET is an unknown quantity at this point
are your brake pads worn out?
Originally Posted by EDaciouSX
You should fix your opor grammar.
510-SR20DET is offline   Reply With Quote
Old 07-13-2010, 02:13 AM   #5
NINJASPY
NINJASPY is on a distinguished road
jack the car up, shake the whole suspension with wheel on then with it off.
my guess is tension rods, or maybe tie rods.
NINJASPY is offline   Reply With Quote
Old 07-13-2010, 09:24 AM   #6
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Is it like a loud clunk and does it only happen when you come to a stop or when you accelerate? If you or a loved one are experiencing these symptoms your car may suffer from wornoutsubframania bushing syndrome lol.
redline racer510 is offline   Reply With Quote
Old 07-13-2010, 09:56 AM   #7
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
do the coilovers you put on have pillow ball mounts? if so check them. jack the car up, and watch the top of the mount, see if it moves up and down-it shouldn't.
FRONT = no sub frame bushings
c72c is offline   Reply With Quote
Old 07-13-2010, 10:08 AM   #8
mad-ass
mad-ass's Avatar
well, you think it's coming from the front, but...usually when you hear a thump noise when you brake and you don't have subframe bushings installed, the noise is coming from the subframe.
it took me 2 month to figure this out 3 years ago
Old 07-13-2010, 10:12 AM   #9
payne219
payne219's Avatar
payne219 is an unknown quantity at this point
^ this is most likely your issue
payne219 is offline   Reply With Quote
Old 07-13-2010, 10:21 AM   #10
drifterdave
drifterdave's Avatar
drifterdave is on the path to ruindrifterdave is on the path to ruin
just a thought but it could be your brake pads shifting in the caliper, but idk how loud the noise is. i would start with the front of the car and work your car backwards checking all areas
keeping it gangster
drifterdave is offline   Reply With Quote
Old 04-20-2011, 07:39 PM   #11
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Did you ever get a solution for this? I tightened up my tension rod brace yesterday. But the clunking noise is still very blatant. I want to fix it before something happens.
I have solid subframe bushings installed in my car and I can hear the clunk when I steer the wheel left and right.
Old 04-20-2011, 11:29 PM   #12
mad-ass
mad-ass's Avatar
may even be the ball joint actually. check that out
Old 04-21-2011, 04:07 AM   #13
Jakob
Jakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to allJakob is a name known to all
it could be the tension rod bushings too, they are broken on almost every s chassis, except somebody replaced them haha.
they do clunk when you brake, but not always.
just check the subframe bushings and the tension rod bushings, and get solid bushings and aftermarket tension rods.
the car will feel amazing after you did that!
Jakob is offline   Reply With Quote
Old 04-21-2011, 04:21 AM   #14
[email protected]
Advertiser
Mogli@9KRacing.com's Avatar
Trader Rating: (87)
Mogli@9KRacing.com is an unknown quantity at this point
Feedback Score: 87 reviews
Send a message via AIM to Mogli@9KRacing.com
did you install new or used parts?
ex: tension rod / coilovers
LIKE 9K Racing On Facebook for discount and product updates.
http://www.facebook.com/9KRacing
Contact 9K racing for any of your tuning or modifying needs.
Mogli@9KRacing.com is offline   Reply With Quote
Old 04-21-2011, 04:23 AM   #15
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
the OP hasn't posted since 9 months ago...
mxexux is offline   Reply With Quote
Old 04-21-2011, 05:26 AM   #16
mad-ass
mad-ass's Avatar
that doesn't mean much with your input. someone else could be having the same problem and doesn't want to create a new thread for the same question that has a similar systems/problems.
not all old threads are classified as beating the dead horse.
Old 04-21-2011, 06:03 PM   #17
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I have megan coils and SPL tension rods. I should've checked it after work today, but have spent the past 2 hours playing left 4 dead.
Old 05-23-2011, 02:10 AM   #18
jing
jing's Avatar
The clunking noise on my car was actually due to loose bolts where the tension rod brackets attach to the lower rad support. Torqued them to spec and no issues since.
A week ago however a new clunking noise has appeared again, which once again, is only evident when braking to a stop. Once I figure out that one I'll update here again I guess.
Old 05-23-2011, 02:26 AM   #19
wacko2
wacko2's Avatar
wacko2 is making a name for him/her selfwacko2 is making a name for him/her selfwacko2 is making a name for him/her self
a friend have the same problem... when he comes to a stop it make a load squeaking noise in front his s14....the sound coming from the wheel.... he just install z32 rebuild brake calipers that was rebuilt last 2 weeks and got new slotted and drill rotor and pads... when we install them... we went around the block and test out the brake... when u do a stop it make a dame squeaking noise from the caliper... im think the pad no good or there defected... but he think something else...
wacko2 is offline   Reply With Quote
Old 05-23-2011, 09:02 AM   #20
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
Kinda old and not really directed to you, but whoever is wonder; clunking while steering left of right is usually due to the springs on coilovers binding. Better bearing and preload adjustment helps.
Pandapants is offline   Reply With Quote
Old 05-23-2011, 09:10 AM   #21
Spartan325
Spartan325 is an unknown quantity at this point
I have a similar issue in my S13 Hatch. It clunks when driving, lessens when steering to the right, worsens when braking lightly, all but goes away when braking heavily. I looked in there and found the boot where the tie rod meets the steering rack was in tatters. I am thinking this could be my problem, but I wanted to know other issues that it could be too...
Spartan325 is offline   Reply With Quote
Old 05-23-2011, 08:30 PM   #22
dsastr_clan
dsastr_clan is an unknown quantity at this point
i think is ur steering rack shaft too, there should be no play
dsastr_clan is offline   Reply With Quote
Old 05-23-2011, 09:56 PM   #23
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I replaced my steering rack bushings, wheels, brake rotors/pads, front wheel hubs/bearings, and all it turned out to be was a loose tension rod bolt.
Make sure ALL 3 bolts (on each side) are TIGHT.
Old 05-23-2011, 10:09 PM   #24
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Make sure you guys check every single suspension/chassis nut and bolt. Don't be surprised if anything has come loose after 20 years.
Hashiriya415 is offline   Reply With Quote
Old 07-28-2019, 12:37 AM   #25
180sx_
180sx_'s Avatar
180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about
I have this problem aswell. Only just started recently.
I have brand new kts tension rods, New lca's with ball joints. And have Subframe locking collars too.
It happened last year and I replaced the passenger tie rod end and it fixed it, now it's making the sound again. Let's hope it's just the drivers side tie rod end. If not then it will probably be the rack ends [emoji51]
Sent from my SM-G935F using Tapatalk
180sx_ is offline   Reply With Quote
Old 08-12-2019, 11:48 AM   #26
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
I always had issues with my tension rod bolts coming loose, or the bracket that bolts to the body coming loose and clunking. Take out the bolts, clean them well and use blue loctite on them and reinstall.
LayNLow is offline   Reply With Quote
Old 08-15-2019, 09:24 AM   #27
sr vegas 240
sr vegas 240 is an unknown quantity at this point
As the op stated it happened after he installed coilovers and tc rods. Most likely you left something loose, pillow ball mounts bad (cheap coils) cheap tc rods have cheap heim joints that make that clunking noise. Always use quality parts.
sr vegas 240 is offline   Reply With Quote
Old 08-15-2019, 09:30 AM   #28
180sx_
180sx_'s Avatar
One of my tension rods got loose where it connects to the Lca, which I fixed and checked everything back over. For some reason I think it's stopped Making the noise because I haven't noticed it the past few times I've driven it
