Old 08-17-2001, 12:45 AM   #1
Guest
Posts: n/a
this seems nice &nbsp;<a href="http://www.i-m-racing.com/xs9324turkit.html" target='_blank'>http://www.i-m-racing.com/xs9324turkit.html</a>
Old 08-17-2001, 07:44 AM   #2
Guest
Posts: n/a
That's an awesome deal. If you look on the XS ENG. website they sell the kit for $3,995. And that manifold is a very nice piece of work
Old 08-17-2001, 03:09 PM   #3
Boostaholic
Boostaholic's Avatar
Boostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud ofBoostaholic has much to be proud of
But it doesnt come with an intercooler, injectors, ecu, fpr, downpipe, or bov. Personally I like the fmax kit although it is more expensive but you get ALOT more out of it...
FMAX HIGH-CARBON CAST-STEEL TURBO MANIFOLD
· 1 year warranty against cracking
· Available in thermocoated finish
CLOSED-LOOP MANDREL BENT DOWNPIPE
· Slip-notched closed-loop wastegate design eliminates cracking
· Bolts onto factory catalytic converter
· 16 gauge mild steel (thermal barrier available )
· Flex pipe standard for some applications
INTERCOOLER PIPING
· 2&quot; and 2.5&quot; 16 gauge mandrel bent mild steel,
· Finish color matched to application
INTAKE PIPE
· 3&quot; 16 gauge mandrel bent mild steel
· Maintains crank case ventilation in closed-loop operation
T3/T4E HYBRID TURBOCHARGER
· A/R and compressor wheel profiles can be custom made to fit order
· A Turbonetics T3\T4 is standard unless otherwise noted
DELTAGATE EXTERNAL WASTEGATE
INTERCOOLER
· Intercooler core with 99% charge-side efficiency comes standard
AIR FILTER
· A K&amp;N filtercharger comes standard
HKS RACING BYPASS VALVE
· Completely discharges excess boost pressure to eliminate compressor surge
JIM WOLF TECHNOLOGY ECU
· JWT computer governs all fuel and ignition maps to deliver reliable OBD II compliant performance
NISSAN 370CC FUEL INJECTORS
· 4 New primary fuel injectors that drop into place without major modifications
for just the stage 1 kit and if you spend the $ and get the stage 2 it adds
COBRA MASS AIR FLOW METER
MSD 525CC (50 LB/HR) PRIMARY FUEL INJECTORS
HIGH FLOW IN-TANK FUEL PUMP
Much higer quality parts in that kit and it is EVERYTHING you need to push as many pounds as your engine can handle.
Boostaholic is offline   Reply With Quote
Old 08-17-2001, 03:18 PM   #4
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Boostaholic on 3<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>9 pm on Aug. 17, 2001
Actually, it brings a skyline cooler with apexi endtanks,
a vortech FMU, an HKS B.O.V, and 3&quot; downpipe. FMAX manifolds are notorious for their ability to crack after the first year. Don't get me wrong, this kit does offer more HP than the XS kit, and I have heard good things, but I went with XS because you get the show and go.
Old 08-17-2001, 03:21 PM   #5
Guest
Posts: n/a
And also, it doesn't bring EVERYTHING to boost as high as you want because without pistons on the FMAX stage 2 you're looking at 11 psi MAX.
