Old 07-30-2009, 08:33 PM   #1
spartanic
spartanic is an unknown quantity at this point
Complete DIY's on starting, charging, engines, trannys, etc.
How's it going guys. Here are some completed DIYs that you guys might find helpful. The repair info isn't model specific but does give you a general idea of how certain parts work. Let me know if you guys see any errors.
- Anti Lock Brake Safety Information (ABS)
- Air Conditioning Troubleshooting - No cool air, noisy AC, etc
- Ball join check
- Brake System Troubleshoot - screeching noise, dragging brakes, etc
- Break-in procedure for new engines
- Camshafts - removal, cleaning, inspection and installation
- Charging System - No start, Noisy alternator, fuses burn out quickly, battery not charged
- Clutch Troubleshoot - chattering, rattling, slipping, stiff pedal, and more
- Cooling System - overheating, low coolant, refilling, flushing, and more
- Crankshaft and Main Bearings - removal, cleaning and inspection, installation and more
- Cylinder Head Overhaul - removal, cleaning, inspection and installation
- Drive Axle - Clunk Noises, Gear noises, vibration, and more
- FF Axle Shafts and CV Joint Troubleshooting
- RWD Drive Axle Troubleshoot - clunking noises, vibration and more
- Troubleshoot hard starting, rough idle, slow acceleration, Misfire, poor gas mileage, etc.
- Electrostatic Discharge (ESD)
- Emissions Inspection - PCV, TAC, Evap, Catalytic Converter, EGR and more
- Engine Services - bead blasting, cold tank, steam cleaning,
- Engine Damage Inspection - Magnaflux, Zyglo, Dye Check, Ultrasonic, X-ray
- Engine Overhaul - cleaning, cylinder head, pistons, rods, crankshaft and more
- Engine Troubleshoot - rough idle, hesitation, backfire, detonation, low oil pressure and more
- Fuel System Troubleshooting - Hard starting or no-start, ping on acceleration and more
- Heater System Troubleshoot - Low or no heat, blower not working and more
- Troubleshoot ignition system, no-start, engine runs rough, etc.
- Proper vehicle jacking and wheel removal procedures
- Manual Transmission Repair - Troubleshooting noisy gears, gears clashing, hard shifting, etc
- OIL PUMP - Rotor and Gear type
- Parasitic Load Explanation and Test Procedures
- Pistons, Connecting Rods and Bearings - removal, cleaning, inspection
- Power Steering Troubleshooting
- Safety in the Garage
- Spark Plugs - troubleshooting, carbon deposits, electrodes, etc.
- Starter Troubleshooting - no start, no clicks from solenoid, etc.
- MANUAL STEERING GEAR TROUBLESHOOTING
- Suspension alignment troubleshoot - tire wear, odd suspension noises, etc.
- Tie rod test
- Timing Chain and Belts - tension adjustment, gear backlash, runout, etc.
- Undercarriage Quick test - this finds loose suspension parts that need replacement.
- Warped Rotors - this test helps determine if your rotors are warped.
- Wheel Alignment Operations - camber, caster, toe, steering axes and more
- Wheel Bearing Quick Test
spartanic is offline   Reply With Quote
Old 07-30-2009, 09:44 PM   #2
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
all your links are belong to us. megafail
w0nderbr3ad is offline   Reply With Quote
Old 07-30-2009, 09:45 PM   #3
pungkiteater_671
pungkiteater_671 is an unknown quantity at this point
supermega FAIL
pungkiteater_671 is offline   Reply With Quote
Old 07-30-2009, 09:52 PM   #4
Dee
Dee's Avatar
Dee is an unknown quantity at this point
I was expecting some good ish too
'78 280Z-LSx|76mm turbo|1840cam|8.8 Diff
Dee is offline   Reply With Quote
Old 07-30-2009, 10:12 PM   #5
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
Forbidden
You don't have permission to access /FuelSystemTroubleShoot on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
FAIL i'd rather have been rick-rolled haha
upsdude is offline   Reply With Quote
Old 07-30-2009, 10:27 PM   #6
Dee
Dee's Avatar
It works if you go to www.garage411.com(copy and paste link) then click "Nissan 240sx 1989-1994 S13"
Direct linking isn't permitted though...good info at that site.
Old 07-31-2009, 04:10 AM   #7
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Yea, that doesn't work either.
SochBAT is offline   Reply With Quote
Old 07-31-2009, 05:53 AM   #8
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
You suck at reading.. he said COPY AND PASTE
Anyways, I looked at it and it looks like stuff you can find in the FSM
Propaganda is offline   Reply With Quote
Old 07-31-2009, 06:36 AM   #9
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
you sent us up teh link. i want to look at the cv axle troubleshooting!
clark is offline   Reply With Quote
Old 07-31-2009, 06:38 AM   #10
clark
clark's Avatar
it works if you go to garage411.com WITHOUT the www
Old 07-31-2009, 09:36 AM   #11
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
this is stupid. seriously.
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 07-31-2009, 10:06 AM   #12
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
wtf...................
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 07-31-2009, 10:12 AM   #13
airforceone451
airforceone451's Avatar
airforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enough
here's a compilation of the links that circumvents the server restrictions on garage411
http://fhurl.com/c100006
airforceone451 is offline   Reply With Quote
Old 07-31-2009, 10:18 AM   #14
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
If you type in the website and click nissan 240sx it actually has some useful stuff
palmdale_mob is offline   Reply With Quote
Old 08-05-2009, 06:36 PM   #15
spartanic
Hey guys sorry about total screw up on the errors. When you click on the links you get an error but if you hit enter than the link will work fine after that. I'm not even sure why it does that but i'm looking into it.
Thanks for your patience.
automotive repair, diy, garage411.com, manual, trannys
