07-28-2009, 03:31 PM | #1 |
Trader Rating: (106)
Feedback Score: 106 reviews
S-13 clearence sale, nothing over $20!
Ka24e distributor, p/s pump, aac valve, and iacv valve
All items were in good working condition when removed and were stored inside. Aac and iacv valves were cleaned with throttlebody cleaner. The powersteering pump does not leak and worked perfectly, no noise. $5 each item P/S pump SOLD! chuki bumper vent grilles Since I made my "version 2" brake ducts I no longer need these. They are in pretty good shape, but have a couple of knicks on them. SOLD! s-13 non-abs master cylinder (7/8") The master worked perfectly, no problems EVER. It comes with the resovoir and cap. This is MY brake master off MY car so you know it is good. SOLD! Passenger's side OE chuki bumper light This is a used, OE nissan, passenger's side, bumper light for the chuki front end. The lens is a little sandblasted, but has no chips, cracks, scratches, or fading. SOLD! Ka24e (singlecam) MAFS x2 Both came out of running cars and both have been cleaned with MAFS cleaner. One uses a 3 pin connector, one uses a 4 pin connector (only 3 used). If you look closely in the pic you can read the part numbers. $10 each 3 pin connector MAF SOLD! KA24e (singlecam) ignition coil assembly Came out of a running car, no problems. $5 Used s-13 non abs front calipers No leaks, both worked perfectly on the car. $15 Stock s-13 axles These are in perfect working shape, came off my car. One of the inner boots has a small patch which has held for over a year. SOLD! S-13 front endlinks 3 endlinks available, all in good condition. $5 each Last edited by racepar1; 08-19-2009 at 06:13 PM.. |
