07-17-2009, 04:28 PM | #1 |
S14 HUD-Need Help (LARGE Pics)
I've had a couple of these clusters collecting dust for some time now and have decided its time to put them to work.
The problem is that it's been impossible to get a complete wiring harness for the cluster and finding a Japanese version of the FSM hasn't been working out either. The following image is the only one I could find that relates to the HUD cluster and I have filled in the parts I know, but unfortunately I cant read Japanese and the English versions of the SR20 S14 FSM are missing the 2 pages showing the wiring for either cluster. Can anyone decipher the Japanese? The parts I'm not sure about are the ones connected to the "Electronic Speedometer" part. I figure the one that says C/U is the Display Computer and the one with SW is the Display Switch but i'm not sure. This is what i'v been looking at for the last few hours. S14 SE Zenki HUD Cluster. I know on the "Display Computer(Gray looking box)" that the black plug on the right goes to the actual heads-up-display LCD screen, but the black plug on the left I have no idea. The other plugs I figured are just the normal ones located on any of the various clusters. Here is a pic of the plug in question. And another angle. Here is the only pic I could find with the actual plugs intact. These last 3 pics are to just show the other plugs for reference. Any help would be greatly appreciated and maybe one day there will be how to/write-up and more than just a handful of S14's will be able to have their HUD. Last edited by wbarrett48473; 05-31-2022 at 01:07 PM.. |
07-17-2009, 05:21 PM | #2 |
heres a rough translation
07-17-2009, 06:17 PM | #3 |
Thank you very much for the translation, this should help a lot. I was also able to find another pic of the plug in question, but still unsure of where it comes from or what the individual wires are for. Last edited by wbarrett48473; 05-31-2022 at 01:08 PM.. |
07-28-2009, 07:32 PM | #4 |
I still haven't given up on the S14 HUD especially now that I learned that some '93 and '94 Altima GLE came with an optional HUD that is similar to the gauge cluster in a S14 this means that the FSM might be of some help.
This is what I'm talking about. Now only if I could find that one missing plug I would be one step closer. Also I finally received the actual HUD unit for the S14. Notice it also has a check engine portion. This is attached to the display but I have no idea what its for - maybe someone else does? This is the back of the display - maybe someone that works for Nissan would be able to order this part. Here are the wires connected to the display - Does anyone see similarities between this and the S13? Here is the connector for reference. I'll be sure to keep everyone posted as I get closer to figuring this out. Last edited by wbarrett48473; 05-31-2022 at 01:08 PM.. Reason: Updated picture links |
09-25-2009, 02:02 AM | #6 |
hey any news on this. im about to buy an s14 hud but i dont have the gauge cluster. i only have the edm kouki cluster. do you know if you need the box on the back of cluster to make it work? thanks im really curious and want to know if you ever figured it out.
09-25-2009, 05:18 AM | #7 | |
09-25-2009, 06:38 AM | #9 |
Isn't it just a small reflective film? I always thought it was just a piece of reflective film that it would display on.
09-25-2009, 12:34 PM | #12 |
how do you KNOW that? im pretty sure the s13 guys can make the hud work with the analog system. thats basically what i would be doing... and if you know so much about the hud then what does the box do?
09-25-2009, 12:37 PM | #14 | |
Also you can use the HUD without any window film but there is sometimes a little bit of "seeing double" on the window... using a small piece of tint will correct this. As far as getting my S14 HUD working there is still the plug labeled M45 that I haven't found yet, but I did pick up another HUD unit. I believe this one came off of a Kouki because of the size of the opening on the top. Here is picture from someone on a different form that had one with his Kouki Cluster. Here is one that came with a Zenki cluster. Notice the differences in size? Here is the one I picked up. The Plug on this one is different from the other one I have as well. Hopefully I find one of these plugs and I can start wiring everything up. I'll be sure to keep everyone posted when that happens. Last edited by wbarrett48473; 05-31-2022 at 01:08 PM.. |
09-25-2009, 12:59 PM | #15 |
i did a little search in google for the altima hud. found this site and the guy seems to know just about everything about them. they (from what i can tell) look very similar to the s14 ones..
'94 Altima SE - Heads Up Display (HUD) Conversion - Nissan Forums: Nissan Altima Forum |
09-25-2009, 01:01 PM | #16 | |
The 'box' is the control unit for the HUD, it converts the analog signal from the VSS to a digital reading and signals the display to interpret the speed to the glass. You're assuming you can just take the display, without any sort of control unit, and splice it in. You're wrong. But please, go ahead and do it and then come back asking why it doesn't work so we can laugh at you.
09-25-2009, 01:05 PM | #17 | |
i was unaware that the hud unit didnt convert the signal on its own. that is why im asking questions. and reading and searching for answers. |
09-25-2009, 01:06 PM | #18 |
The S13 unit won't work with an S14, the VSS signal is different between chassis.
10-01-2009, 07:57 AM | #22 |
Trader Rating: (22)
Feedback Score: 22 reviews
I had no idea these existed...Let us know if you figure this out.
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
10-08-2009, 12:57 PM | #23 |
Just a small update but a very important one...
I found the damn plug!! No idea why I didn't check my Digital climate control before but one of its plugs is the exact one that I was missing. ....Soo off to the local pull-a-part and found a 91 Q45 with the Digital climate control (same plugs as s14) and yanked them. Here is the plug for reference. Here are both plugs attached to the display computer. **Note this is the Zenki model (Kouki is completely different)** Now I just need some free time to wire the HUD into this. And the eventually fit everything into this. Lots of work just to show the speed on the windshield I know but it gives me something fun to do I'll be sure to keep everyone posted when I figure out this wiring. Last edited by wbarrett48473; 05-31-2022 at 01:09 PM.. |
10-08-2009, 03:48 PM | #24 |
Where are you getting these parts? Ebay? Other forums.
I have a Kouki HUD cluster without the hud computer and display. I've always wanted to hook it up. |
10-09-2009, 03:31 AM | #26 | |
Mainly from long hours of searching through YAJ and every once in awhile something will pop up on ebay.
Sure I could just get the Defi HUD but I'm only looking for parts that were made by nissan for the S14 Last edited by wbarrett48473; 05-31-2022 at 01:10 PM.. |
10-21-2009, 05:49 PM | #28 |
hey so i just got a jdm clip that im going to do a rhd swap. and it has an oem hud. the hud is burned out but the wiring is still there. maybe we can get yours working then i can buy a new one and get mine working!!! i am going on a trip this week and when i get back ill take detailed pics
guage cluster, heads up display, hud, s14 hud |
