Old 06-17-2009, 05:34 PM   #1
b-rett
b-rett is an unknown quantity at this point
s13 FS: 1993 Black Coupe shell/rolling chassis w/1jz part out, big mods and conversion FS
I think this is the proper area, if not, Mods relocate and send me a link. Thank you!
I developed a rod knock a few weekends ago and need to part with this - grad school is a callin'
Oil Pressure got low (just about 15-20psi for a minute or two before I shut it down)...motor is pretty much toast, but I will be parting all that out as well.
Let's start this off by listing the rolling chassis (not parting this thing out - comes as is/stated below):
1993 240sx Coupe - black on black - when I traded for this car back in Dec 2007 the original cluster (which I still have - stated about 90K miles and I have only put 2K miles on it since then)
Int/Ext:
- A few dings here and there, nothing major - paint is in great shape (can see little sanding marks under clearcoat - previous owner did not know what he was doing when painting, but got the clear coat looking great)
- S14 leather seats, no rear seats - custom carpet (black & grey)
- 6-point rollbar (no door bars, just to the trans tunnel) - chassis black coating
- 4-point drivers belt/harness
- used to be HUD but converted to analog cluster
- no cracks in dash, new windshield
- all power options & all still work fine
- Pioneer CD player - gooood
- HID's - working great
- Carbon Fiber Trunk Lid - great shape & smoooooth
- Battery Relocated to the trunk
Suspension:
- Megan Racing: Rear traction rods, RUCA's, Sway bar, etc.
- KYB Shocks w/ Tein S-tech Springs
- Rear Crossmember has been coated with Chassis Black
- Will have stock from crossmember
Brakes/Wheels/Tires:
- Stern Leacher 2-piece wheels 17x8 & 17x9 w/Falken Azenis rubber (little wear on these) - these have been painted a flat black with red lip
- Z32 Rear Hubs with Nismo extended studs
- Ichiba 5-lug fron hub conversion w/ARP Extended Studs
- 300zx front brakes w/new hawk performance pads
- Brembo Blanks Rotors (rear's have little wear & fronts were re-ground)
- Russell & PDM Stainless Steel Braided Brake Lines all around
Others:
- Dual Walbro's with -6AN feed & stock return
- J30 3.93 FD R200 LSD
- 3" Cat-back exhaust
- SR20 "quibdo" (sp?) driveshaft can be included
- Black 26x12x3 FMIC & piping can be included for $$
- The entire underbody, wheel wells, etc. were cleaned, and sprayed thoroughly with rubberized undercoating
- There is little, if any rust on this car, most of which I tried to get rid of at the frame rails and upper shock tower (you can see some of the engine bay work in on the build site - click my sig picture)
Others & Others for part out:
- Koyo Radiator - adapted to fit 1jz/2jz (can be switched back at your request) - SOLD
- AEM UEGO Guage type sensor & o2 sensor - $150
- AutoMeter Phanotom Guages (removed green glow) - boost (mechanical) & oil pressure w/sending unit (electric) - $60/each
- SAFC II - SOLD
There are items that can removed, included, in the shell for additional or less cash. I'd like to move this pretty soon.
Price: around $4,000 OBO & mostly depending on what all you would like to include in the rolling chassis (over $7,000 in parts & upgrades listed above - more or less). I would be willing to trailer it to a point for additional money (depending on where you are located).
PICS:
http://www.kms-fab.com/images/...1.jpg
http://www.kms-fab.com/images/...2.jpg
http://www.kms-fab.com/images/...3.jpg
http://www.kms-fab.com/images/...4.jpg
http://www.kms-fab.com/images/...5.jpg
http://www.kms-fab.com/images/...6.jpg
http://www.kms-fab.com/images/...7.jpg
Engine Bay related: Brett's 1JZ_240sx Project
Chassis related: Brett's 1JZ_240sx Project
Rollbar/Int related: Brett's 1JZ_240sx Project
**Please let me know if you would like additional pictures and I will try my best to get them for you**
MOTOR/Performance Parts (most are negotiable):
- GT4082 .86a/r journal bearing with -10AN return line and -4AN feed line (with 10 micron inline oil filter) - $600
- Tial BOV (21-23psi spring) - $125
- Custom (made by Me) 1jz Turbo Manifold (additional heim joint bracing, Sch10 304SS runners, Mild Steel Flanges, dual 38mm wastegate flanges, T4 platform, very close to equal length - i have the measurements to prove it) - $800
- XSPower Wastegates (2) with .8bar springs and 1bar springs, with dumptubes (if you want them) - $65 each
- 3.5" Downpipe, v-band at turbo and exhaust connections, 1jz o2 flange & standard bung in place, flex section - $350
- 1jz ECUs - i have 2 of these both for Supra 1jz M/T - SOLD
- Aeromotive FPR with liquid guage and -6AN lines - SOLD
- 1jz/2jz coilpacks - i have one set left - $125
- 1jz/2jz Ignitor - $100
- 1jz Crower 264 Cams (retail for $600 if you can find them) - $400
- Koyo Radiator (adapted for 1jz & can be moded back) - SOLD
- Dual FAL fans (pusher or puller), with relay, etc. - $150
- R154 Transmission - SOLD
- HKS SSQV no flange (flanges run about $35) - $75
- Greddy Boost Cut Controller (for MR2 - new and in box) - $50
I also have the motor for part out:
- all sensors, intake manifold, SC300 alternator (100amp), front sump oil pan and assembly, 1jz Crower 264 cams, 440cc injectors with stock rail, coil packs, ignitor, etc.
I also can part out the 1jz/2jz_240sx conversion items (s13 or 14):
- front crossmember (with engine brackets & insulators) & trans mount - SOLD
- Dakota Digital Calibration Boxes - SOLD
- 3.5" Aluminum DriveshaftShop Driveshaft with Hal Effect sensor - SOLD
The car needs a new longblock and it would be back on the road. There are two on SupraMania for under $1,000 ($600 & $900) and you can swap stuff from the current motor to it (water pump, alternator, etc.) and then part with the remaining items (i would venture to guess that you would only have $500 in that long block after selling misc. items off of it). Also, there are suppliers with JDM 2jz Aristo and 1jz automatic motor sets for $1,250-1,500 on eBay - think about it)
I do not have the time nor desire any longer to keep at this. Just trying to be responsible...I guess (gay, I know).
Feel free to call with any questions. The car is still whole, for the most part and pulling stuff is not an issue for me. I am usually available after 5-6pm daily. I would love to entertain offers.
There are additional pictures of the entire build here ---> Brett's 1JZ_240sx Project
I do take paypal and can also do cash, certified check, money order.
paypal is [email protected]
One last addition - I am not a regulare "poster" here, but try to frequent this forum. I have great feedback on SupraForums (iTrader), SupraMania, eBay (username = kmsfab), paypal, and locally here in Cincinnati. I have plenty of people who can vouch for me and would be willing to give whomever is interested, some references' contact information if it will ease your pain.
Again, feel free to call or PM. I will try my best to get back with you ASAP.
Thanks,
brett
Cincinnati, OH 45209
513.205.2706
[email protected]
b-rett is offline
Old 06-17-2009, 06:33 PM   #2
cole d
cole d is an unknown quantity at this point
Is r154 trans modified for 240sx any issues?
cole d is offline
Old 06-18-2009, 12:28 PM   #3
slowkouki
slowkouki's Avatar
slowkouki is an unknown quantity at this point
what cfm are the fal fans and how much shipped to 70068?
slowkouki is offline
Old 06-18-2009, 02:05 PM   #4
koukis4teen
koukis4teen is an unknown quantity at this point
Pmed about brake lines
koukis4teen is offline
Old 06-21-2009, 06:07 AM   #5
b-rett
cole - the only thing modified on the trans is the shifter (i did not do the full conversoin, cutting & welding the top box) but rather i bent a piece of rod to make the be in the right spot.
slowkouki - if i can recall, i believe they were 10,000 cfm each. add $18 for shipping. let me know.
thanks for the interest. all pm's replied.
b-rett is offline
Old 06-21-2009, 08:03 AM   #6
*ClutchKick*
*ClutchKick* is an unknown quantity at this point
wondering if you would get rid of the cf trunk i can pick it up i live in westchester also have a black one i could swap ya let me know thanks
*ClutchKick* is offline
Old 06-23-2009, 10:03 PM   #7
b-rett
CF truck in staying on the car unless the paint and quality is comparable to the body of the car. i hate mismatching colors/shades - it helps bring the value down a lot.
updated!!
rolling chassis price is dropped to $3,500
1jz/2jz mounts and trans mount - SOLD
DD Calibration Boxes - SOLD
let me know if there is any interest in other items. I will part out the Megan Suspension items as I have the stock stuff still. Thanks!
oh, and guys that I give prices to, let me know your thoughts. we can always work something out - or try to.
brett
b-rett is offline
Old 06-27-2009, 06:56 AM   #8
b-rett
tippity top. let me know if you are interested. i would like some of this gone, sooner than later.
willing to trailer car, if distance isnt too far and price is right. thanks!
b-rett is offline
Old 06-28-2009, 11:05 AM   #9
sa3reghatch
sa3reghatch's Avatar
sa3reghatch is a jewel in the roughsa3reghatch is a jewel in the roughsa3reghatch is a jewel in the roughsa3reghatch is a jewel in the roughsa3reghatch is a jewel in the roughsa3reghatch is a jewel in the roughsa3reghatch is a jewel in the rough
Will you sell just the IAT sensor off the intake manifold? Mine went bad yesterday on my 2jz aristo swap, and I can not find one anywhere as only Aristo 2jz's and 1jz's use the same one. Let me know man.
sa3reghatch is offline
Old 06-28-2009, 11:55 AM   #10
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
ill take the aem wideband off your hands if it is complete and working.
PinkPanther is offline
Old 06-28-2009, 11:57 PM   #11
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
interested in the safc II
any pics?
pm me
sr20sean is offline
Old 06-30-2009, 06:17 PM   #12
b-rett
pm's replied. sorry for the confusion on some of the pricing...i know there was at least one typo - AEM UEGO guage type w/sensor. the UEGO is complete and working well.
post updated and a few more items sold!! thanks to all buyers thus far. keep'em coming!!
someone buy the rolling chassis, please?!?!
brett
b-rett is offline
Old 06-30-2009, 06:30 PM   #13
b-rett
oh, and i will sell just the IAT off the motor. price?? i have no clue what they go for, i will do some research however. thanks and let me know,
brett
b-rett is offline
Old 07-01-2009, 05:21 PM   #14
intel
intel is making his/her stupidity well-knownintel is making his/her stupidity well-knownintel is making his/her stupidity well-known
- Megan Racing:RUCAs
pm me price on these please?
intel is offline
Old 07-02-2009, 06:26 PM   #15
b-rett
i am not parting with these as of yet. they will be included in the rolling chassis...
if it comes down to it, i may part the car suspension out (as i have a parts car coming in a month). thanks and keep posted,
brett
b-rett is offline
Old 07-02-2009, 07:40 PM   #16
240_fun
240_fun's Avatar
240_fun is an unknown quantity at this point
did the wideband sell?
if not LMK
240_fun is offline
Old 07-03-2009, 07:10 AM   #17
memphis350z
memphis350z's Avatar
memphis350z is an unknown quantity at this point
email sent
memphis350z is offline
Old 07-03-2009, 04:22 PM   #18
b-rett
wideband has not sold yet, let me know.
brett
b-rett is offline
Old 07-06-2009, 06:47 PM   #19
b-rett
radiator, shroud, 1jz/240 Driveshaft, (1) 1jz ECU, SAFCII, 1jz Alternator, and Stinger EMS v4 have all SOLD. thanks for those that purchased and came through.
all pm's replied. let me know!
brett
b-rett is offline
Old 07-06-2009, 06:53 PM   #20
yzfsr20
yzfsr20 is an unknown quantity at this point
if you part out i want the brake upgrades
yzfsr20 is offline
Old 07-07-2009, 07:54 PM   #21
b-rett
i would hate for someone to part out a great looking coupe, myself included. the rolling chassis is up for grabs, tell your friends. i can ship/trailer if distance isn't too far and price is right. thanks,
all PM's replied
brett
b-rett is offline
Old 07-07-2009, 08:47 PM   #22
niSE7EN
niSE7EN's Avatar
niSE7EN is an unknown quantity at this point
damn, i'm in cincinnati wow this is a great partout, but i got an s14
niSE7EN is offline
Old 07-09-2009, 08:22 PM   #23
b-rett
all PM's replied - hibbity tippity top.
pending sale on the long block w/1jz cams
pending sale on the r154 trans and flywheel
everything else...well thats for YOU!!
let me know,
brett
b-rett is offline
Old 07-10-2009, 12:21 AM   #24
barraza1984
barraza1984 is an unknown quantity at this point
Send a message via Yahoo to barraza1984
dude free bump just for the red line all around the car los great!!!!!!!!!!!!!
barraza1984 is offline
Old 07-13-2009, 02:17 PM   #25
b-rett
updated!!
trans is gone, both ECU's gone, (1) set of coil packs gone
there is much to get off my hands. long block (although blown), stock cams, stock downpipe, etc....
let me know if you need anything. thanks,
brett
b-rett is offline
Old 07-29-2009, 02:07 PM   #26
b-rett
I WANT TO GET RID OF THE ROLLING CHASSIS. MAKE AN OFFER!!
top top! i have a new thread with the 1jz turbo kit if interested. all custom made by yours truly. thanks,
brett
b-rett is offline
Old 07-29-2009, 10:27 PM   #27
racerx2k1
460
racerx2k1's Avatar
brett
let me know,
brett
updated!!
brett
brett
racerx2k1 is offline
1jz, black coupe, s13 coupe
