02-05-2009, 03:31 PM | #1 |
d1gp legal roll cage
do you guys know know of a company that makes either bolt in or weld in cages that are in spec
02-05-2009, 03:34 PM | #2 |
Trader Rating: (41)
Feedback Score: 41 reviews
Are you planning on going to a D1 qualifier? If so, a Cusco will work because the Japanese are awesome and don't care about bends in the cage.
If you want a Formula D or SCCA cage, I think KW cages are the legal thickness and amount of bends. Someone please correct me if I am wrong. |
02-05-2009, 03:53 PM | #5 |
Trader Rating: (63)
Feedback Score: 63 reviews
For all D1 Grand Prix USA - Points Round and Exhibition Match Events
The following additional requirements must be met. 1. Each car must be equipped with a six-point or better roll cage. Full front A pillar beams are required as well as door impact protection beams. 2. Functional tow hooks must be installed on both front and rear of vehicle 3. Roll cage must be welded or securely bolted and anchored. If roll cage is bolted then its must be securely reinforced with an anchor plate and backing plate sandwich on each side of the floor pan. 4. Roll cage may be placed in front or through the dashboard. 5. Roll cage tubing must be at a minimum of 1.5 inches OD tubing and no thinner than 0.098 wall mild steel or 1 .25x .083 Chromoly tubing. |
02-05-2009, 04:08 PM | #7 |
Trader Rating: (63)
OK THIS IS OFFICIAL FROM D1
http://www.d1gp.com/v2/docs/2009_D1USA_Rulebook.pdf Safety Cage Purpose The purpose of the safety cage is to protect the occupants in case of a rollover or a collision. It must be able to withstand the weight of the car landing on the roof. A cage with six mounting points or more is required Intent Chassis stiffening is a side benefit of a good safety cage system, but it is not the intent of these rules. The removal or redesign of the cage, whole or in part, to comply with these rules, does not imply that penalties will not be issued for violating the intent of these rules Installation The cage may be removable or may be permanently welded, or any combination thereof, providing that all aspects of the cage meet these rules. Padding All roll cage surfaces that may come in contact with the driver shall be padded with high-density padding. Bends None of the tubing may show any signs of crimping or wall failure. All bends must be Mandrel type. The center radius of the bends may not be less than three (3) times the outside diameter of the roll cage tubing. Main Hoop The main roll cage hoop shall be as wide as the full width of the interior and must be as close to the roof as possible. One continuous length of roll bar tubing shall be used as the main hoop. The main hoop must consist of not more than four (4) bends maximum, totaling one hundred eighty (180) degrees +/- ten (10) degrees. Diagonal Brace At least one (1) diagonal brace shall be used in the same plane as the main hoop. One end of the diagonal brace shall attach to the corner, or horizontal part, of the main hoop above the driver’s head, within twelve (12) inches of the driver’s-side corner. The other end of the diagonal brace shall attach to the mounting plate (or to the main hoop as close to the mounting plate as practically possible) diagonally opposed to the driver’s head (passenger floor). Forward Hoops - Option 1 The forward hoops shall extend from the main hoop (in a forward direction) to the floor by following the roof and the “A” pillar of the car. There shall be a bar connecting the two (2) forward hoops at the top of the windshield mounted as close to the roof as possible. The forward hoops shall incorporate no more than four bends each. Optionally a Halo Hoop (Option 2)” or Front Hoop (Option 3)” construction may also be acceptable. Halo Hoop (Option 2) A “halo bar” extends from the main hoop (in a forward direction) following the roof line to the windshield then following along the top of the windshield, then following the roof line back to the main hoop, thus creating a “halo” over the driver’s head. A “halo” bar shall be constructed of one continuous piece of tubing. One (1) down tube following the “A” pillar must support the “halo” on each side of the car. The down tubes shall incorporate no more than two (2) bends each. Front Hoop (Option 3) \A “front hoop” is a bar that extends up from the floor, then follows the “A” pillar up to the roof, then follows the roof line across the top of the windshield, then back down the other “A” pillar, and then terminates on the floor. There must be one (1) horizontal bar (following the roof line) connecting the main hoop and the forward hoop on each side of the car. The front hoop shall incorporate no more than four (4) bends. Rear Brace The main hoop must have two (2) brace extending to the rear. The brace shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top. Rear brace must not contain any bends The main hoop brace may be mounted at the rear shock mounts or suspension pickup points. They may go through any rear bulkheads provided the bulkhead is sealed around the cage brace. Door Bars / Side Impact Protection Door bars on both driver and passenger side must be used. The driver’s door window glass, window operating mechanism, armrest, map pockets, door panel, and inside door latch may be removed. *This gutting of the door is only permitted if the roll cage incorporates at least two (2) NASCAR style door bars that extend into the door or an X brace. Mounting Points The roll cage shall be mounted to the floor of the car in a minimum of six points. The cage shall not go through the firewall. The seventh and eighth points must attach to the firewall or front fender wells. All cage attachment points must be mounted to plates. Mounting Plates Each mounting plate shall be no greater than 100 square inches and no greater than 12 inches or less than 2 inches on a side. Welded mounting plates shall be at least 0.080 inch thick. Plates may extend onto vertical sections of the structure. Any mounting plate may be multiangled, but shall not exceed 100 square inches total including vertical sections. Mounting Plates – Bolt-In Cage The attaching points of a bolt-in cage to the body must use reinforcing plates to sandwich the body. At least three (3) bolts are required for each bolt-in plate and the plate must be at least 3/16 inch thick. All hardware must be SAE Grade 5 or better with 5/16” diameter minimum. Tube / Mounting Plate Specifications Any number of tubes may attach to a plate so long as they are touching each other at the plate. There may be a small gap between tubes to allow welding 360 degrees around each tube. Welds All welding must be of the highest quality with full penetration and Arc welding should be used whenever possible. The welder, using magnaflux, should inspect all welds for quality. All attachment points must be welded 360 degrees around the tube. http://www.d1gp.com/v2/docs/2009_D1USA_Rulebook.pdf LOOK UP PAGE 22 ~ 24 i mean dude... do some research... i found all these in less than 5 min... GOOGLE IT or YAHOO IT or whatever... |
02-05-2009, 04:15 PM | #8 | ||
lmao FAIL FOR U , um i already have all that i didnt ask what the rules are i asked are there any cages already made , so you need to learn to read Quote:
and on the cusco cage , theres no info on it passing d1gp tech , so far i see its just called d1 cage |
02-05-2009, 04:17 PM | #9 |
[quote=karl wasabi;2616415]a Cusco will work because the Japanese are awesome and don't care about bends in the cage.quote]
Save your money and avoid cusco. Their cages are a joke. The huge S-bends in the a-pillar bars completely neagate the point of even having a-pillar bars, and their clevis style bolt thrus for tube attachments are questionable at best. Not to mention they have ZERO triangulation, and no harness bar. Basically they're a piece of collapsible scaffolding that you can crush you skull on seconds before it impales you. |
02-05-2009, 04:22 PM | #10 | |
Trader Rating: (41)
A cusco cage WILL hold up in a rollover... |
02-05-2009, 04:26 PM | #11 |
regardless of the fact that it held up in that specific incident, you can't refute that their "cages" are a horrible design. It's not approved to be used by any sanctioned road racing body.
02-05-2009, 04:30 PM | #14 |
Trader Rating: (44)
Feedback Score: 44 reviews
Isn't Autopower SCCA approved?
www.realize-jp.net |
02-05-2009, 04:33 PM | #16 | |
Trader Rating: (63)
MyNismo.com - CUSCO D1 Roll Cage this cusco roll cage is called D1 ROLL CAGE.. |
02-05-2009, 04:34 PM | #17 | |
Then the cage would cost more money. Just make a cage. It isn't that expensive. And don't ask for help then get angry at the people who post up help for you.
02-05-2009, 04:35 PM | #18 |
02-05-2009, 04:44 PM | #21 |
02-05-2009, 05:05 PM | #22 | |
yes. |
02-05-2009, 05:38 PM | #25 |
"I am not good English, I like the drift" CHINA DRIFT "some guys have a better relationship with their car than their wife haha. sad but true." SECRET SOCIETY |
02-05-2009, 05:53 PM | #26 |
Approval is free. All you have to do is build a cage according to the rule set, such as SCCA's GCR.
02-05-2009, 06:03 PM | #27 |
personally i would say have a custom cage built. Yes they are more expensive but everycar is different and normally bolt in cages have lots of leiway. Custom cage will get you that baller "a game" fitment. It will also be built to your requirements and tolerances. I wouldnt have chimed in but work at a roll cage metal fab shop. Seeing how it is done and how well fitting a good cage is blows a bolt in out of the water.
Unique Fabrication Yeah custom shit is more but with something like a cage you can't really put a price on safety. |
02-05-2009, 06:40 PM | #28 |
Yea, Cusco cages have proven to withstand rollovers.
However, by looking at it from an engineering standpoint, they leave a lot to be desired in a cage in terms of design and build. Just decide what you want out of the shit, and go from there. Honestly, even though I have the facility and capability to build my own cage, if I could run Safety21 and Tandem, I would. But, for my plans for my car, they require a NASA approved cage. and to echo what was said before, if you have to ask on a public forum........
Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
02-05-2009, 07:57 PM | #29 | ||
there not saying if there d1 legal , so far only FD legal and you still need a X door bar cusco and safety 21 cages are fine , and work well , theres many threads on here about them , i just dont think there d1 legal Quote:
lol ugh show me proof to where this cage will pass D1 tech ill prolly just have a custom done cage there like 700 or so here , so yea |
02-05-2009, 08:53 PM | #30 |
I should just scan up my cusco catalog that shows ALL the cages they make.
They have FIA cages, just so you know. Cages SHOULD be mostly for looks anyways.
http://bhworld.wordpress.com/ |
