Old 12-17-2008, 09:55 AM   #1
amartizleGV
amartizleGV's Avatar
amartizleGV is an unknown quantity at this point
short shifter
need help installing the shifter
any advice on how to do this??
amartizleGV is offline   Reply With Quote
Old 12-17-2008, 09:58 AM   #2
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
Follow any instructions you got with the purchase of the shifter. If you didn't get any, go to the manufacturer's website and look for some. If you can't find a manufacturer, shame on buying counterfeit chinese crap. If you did get a fake and want to take a chance on using it, go buy any manufacturer's instructions on installing a shifter, such as B&M
alzahakar is offline   Reply With Quote
Old 12-17-2008, 11:48 AM   #3
projectRDM
projectRDM's Avatar
Remove the old one.
Install the new one.
Since you failed to disclose which shifter you have that's all we can do for you.
FORMERLY R240NA
Old 12-21-2008, 12:14 AM   #4
s14freak
s14freak's Avatar
s14freak is an unknown quantity at this point
Take your shift boot off, and the rubber boot underneath. There are 6 bolts holding the stock plate. Assuming you bought a shifter that included a new plate, remove those bolts, and with some wiggling you should be able to bull it out thru the hole in the floor. Put the new plate thru the hole and bolt down.
s14freak is offline   Reply With Quote
shifter, shifter knob, short shifter
