Old 06-05-2007, 09:02 PM   #1
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
How to assemble -AN lines *Approved*
Hey guys I decided to run a remote mount oil filter on my SR20 when I drop it in.
So here is how I made the lines
I got four -8AN hose ends, two 1/2” pipe to -8AN adapters, 3’ of -8AN braided stainless hose and an oil filter block.
First I cut the 3 feet of stainless hose in half by taping it with electrical tape and cutting it with the cutoff wheel.
Then I stripped off the electrical tape and slid the hose into the red part of the hose end, putting the end of the hose flush with the threads.
Then I lubricated the blue part of the hose end with some white lithium grease.
Next I clamped the red part into the vice using an AN assembly clamp and pushed the blue part of the AN fitting into the red.
I twisted it with my palm until the threads engaged then used a 7/8” AN wrench to tighten them.
I tightened the fitting until the red and blue parts were just about 1mm apart.
and viola you're done. I would advise however to blow some high pressure air thru the lines to get out any crap from cutting them. Also it hides the coolness but shrink wrapping the lines prevents them from fraying.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline
Old 06-05-2007, 09:13 PM   #2
yokotas13
yokotas13's Avatar
nice write up
but people done nkow how to do that?
yokotas13 is offline
Old 06-05-2007, 09:15 PM   #3
tknbkthrsdy4anfg
I dont know, noobs dont. I thought thats what this was all about.
Old 06-05-2007, 09:32 PM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
I like this write up. I have only seen the other type of installer that holds the blue part and you push the hose into it.
Carlos
Slidin240Wayz is offline
Old 06-06-2007, 12:13 AM   #5
tknbkthrsdy4anfg
Thanks its from JEGS
Old 06-06-2007, 12:32 AM   #6
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
How much did they run you? Also, what is to prevent the hose from falling out? Newb question, I know.
'90RPS13 is offline
Old 06-06-2007, 08:58 AM   #7
tknbkthrsdy4anfg
The line was about 15 dollars I think, the hose ends were about 8 bucks a piece and the adapters were about 8 bucks a piece.
Well whats holding the hose in, the blue part is male and the tip of it sandwiches the hose with the red part, there is also a barb if you look really close.
Old 06-06-2007, 09:37 AM   #8
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I didn't know how to do that. + rep.
FaLKoN240 is offline
Old 06-06-2007, 10:11 AM   #9
tknbkthrsdy4anfg
Thank you guys, I was a little afraid to do it too. Let me get a chance and I will post up how to do smaller -AN lines that require a ferrule.
Old 06-06-2007, 10:50 AM   #10
Slidin240Wayz
Link to the assembly kits:
http://www.jegs.com/webapp/wcs/store...Term=koul+tool
Old 06-06-2007, 10:58 AM   #11
tknbkthrsdy4anfg
Yea this one is good http://www.jegs.com/webapp/wcs/store...0002_537697_-1
however I think its better to cut off the line with a cut off wheel then with a pinch cutter, that way the hose says relatively round.
Old 06-13-2007, 10:25 AM   #12
tknbkthrsdy4anfg
Is this worth posting in the public forum?
Old 06-19-2007, 11:11 AM   #13
tknbkthrsdy4anfg
Mods... Kev? Phlip? Barry? anyone?
Old 06-19-2007, 03:53 PM   #14
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
should have done an oil cooler with thermo like mine
hydropgrahics!
ls1......
420sx is offline
Old 06-19-2007, 04:00 PM   #15
tknbkthrsdy4anfg
I'm lookin at that right now, however it would have added substantially to the cost.
Old 06-19-2007, 05:32 PM   #16
A Spec Products
A Spec Products's Avatar
Cool stuff
I just had Baker assemble the fittings for me
Figure I'd leave it to da pros
A SPEC PRODUCTS CORP
A Spec Products is offline
Old 06-19-2007, 05:47 PM   #17
tknbkthrsdy4anfg
Lol, you would have the cash to do that logan.
Old 06-19-2007, 05:54 PM   #18
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
Part of my job is assembling low/med/high pressure rubber and teflon(steel braided) hoses. from -3AN on up.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline
Old 08-24-2007, 11:01 PM   #19
mrmephistopheles
mrmephistopheles's Avatar
Originally Posted by PHLIP
mrmephistopheles is offline
