Old 05-05-2011, 09:44 AM   #31
adamvann3
adamvann3's Avatar
adamvann3 is an unknown quantity at this point
Picture from last summer
My previous brake setup was 350z track rotor with z32tt calipers. All in all the setup worked well, filled the gap and performed.
However it was still z32 calipers and everyone uses them. After some calculations, research and help from the zilvia brake threads I tossed together new wilwood superlites, 350z track rotor, flex lines and new caliper spacer/hardware. Setup mechanically went together very nicely. Had a few issues getting all the air out of everything but eventually got over the hurdle. I am still running the stock z31 BMC. Pedal is softer and goes nearly the full travel distance. I will have better feel once I bed the pad and do some high speed stopping. I have a feeling I will be upgrading to the 1 1/16 BMC to get a better pedal feel. Just a little uneasy about it now.
Crappy cell phone pic for now from fitment. Will get better ones of everything soon.
88ss 368
adamvann3 is offline   Reply With Quote
Old 05-06-2011, 02:02 AM   #32
LoneStarSilvia
LoneStarSilvia's Avatar
LoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond repute
Beeftastic. I get weird itches for owning a Z31 sometimes.
I long for the day I can get my coilovers on. Did you run into any snags during the tube installation?
LoneStarSilvia is offline   Reply With Quote
Old 05-06-2011, 12:18 PM   #33
adamvann3
adamvann3's Avatar
Nope. Was a pretty straight forward cut and weld scenario. I was a little skeptical when I started it but I x-rayed the welds and there is great penetration.
From ppls past builds they always ran into a problem with not being able to get the fronts low enough. So I paid extra close attention in making sure everything I did focused on making it low as possible. Said and done I can lay the upper fender frame on top of the tire.
I cut my tubes down to 4mm then beveled the hell out of my new spindle tube to ensure good penetration (double pass, stitch weld style) to the original tube and casting. If I were to do it again I would leave 10mm of original tube and not grind down the casting nub and use it as a spacer. Then make the 1st pass weld to the original tube, second pass to the casting. That is a much safer approach to take.
Also be sure to preheat your casting before you weld. The new spindle tubes heat up quick with welding and having the original spindles a high temperature makes everything easier.
88ss 368
Old 06-20-2011, 09:57 PM   #34
adamvann3
adamvann3's Avatar
Recent pic from BZF courtesy of andrewbkeller on flickr
88ss 368
Old 10-22-2011, 07:10 PM   #35
adamvann3
adamvann3's Avatar
Till next season. Packed away for the winter
88ss 368
Old 11-25-2011, 02:39 PM   #36
AE_Racer
AE_Racer is an unknown quantity at this point
Always loved the Shiro's. Looks awesome man.
http://tougestars.net
AE_Racer is offline   Reply With Quote
Old 11-25-2011, 03:23 PM   #37
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
i never liked these cars.. but you made this car look great.. my dad has always had one..
gunmetalr32 is offline   Reply With Quote
Old 12-15-2011, 05:37 PM   #38
S30TurboZ
S30TurboZ is an unknown quantity at this point
That is a beautiful Z31! I've always wanted to build a Shiro.
Are you going to colormatch the hood/lip/wheels?
S30TurboZ is offline   Reply With Quote
Old 12-17-2011, 12:32 PM   #39
adamvann3
adamvann3's Avatar
Hood is going to stay raw. Twill double weave CF is way to nice to paint match. Front end needs a re-spray in which the lip will be color matched.
I am revisiting my rear suspension in the spring and adding adjustable heim joints to the LCAs to correct caster and toe. As for the wheels... you will just have to wait what 2k12 brings
88ss 368
Old 01-25-2012, 09:14 PM   #40
johnnyboy110
johnnyboy110 is an unknown quantity at this point
I love this car
johnnyboy110 is offline   Reply With Quote
Old 05-18-2012, 10:45 PM   #41
darkzschneider
darkzschneider's Avatar
darkzschneider is an unknown quantity at this point
Send a message via AIM to darkzschneider Send a message via MSN to darkzschneider Send a message via Yahoo to darkzschneider
sick build Adam.
2JZ31
darkzschneider is offline   Reply With Quote
Old 05-18-2012, 10:48 PM   #42
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
Sick Z31!...
FS OEM RB25 PARTS
Smurf_240SX is offline   Reply With Quote
Old 07-07-2012, 05:17 PM   #43
Tle1993
Tle1993's Avatar
Tle1993 is an unknown quantity at this point
very nice looks good my friend!!
Tle1993 is offline   Reply With Quote
Old 07-08-2012, 06:37 PM   #44
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
Super clean
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 07-27-2012, 01:11 PM   #45
adamvann3
adamvann3's Avatar
Been a while.
Briefly moved down to SC for work this past winter. Just brought the DD, but still had fun. I drove the tail of the dragon on my way back up in march.
View from a rest spot just over the TN border on the tail
Fast forward a few months, I had most of my hybrid BBK left over after upgrading the shiro. Instead of doing the smart thing and sell it, I re-purposed for my 86 (oh i have an 86 z31 that I have owned for the past 9yrs).
Dont have any before shot, but these are the iron 30mm calipers... they looked like hell. Took them apart and gave them a chemical bath
Sent them out and had them powder coated ford blue
Picked up some late model turbo hubs with fresh bearings and ichiba 50mm studs (ritter RBz31) and some new e-coated 350z track rotors.
Fresh rebuild and seals
Old stock
New hotness
Stock seats bolsters were all blown out and needed new bottom cushion ect... New Corbeau A4s fixed that
Since the Shiro we feeling neglected I ordered a set of wheels. Took a few months to get them, and then I left them in their boxes for months. I got sick of having them in my living space, so I built a wheel rack.
Ordering one off the internet is for the weak. Picked up some extruded aluminum cut it down to size and had it welded up.
Painted it all up purdy to match the rest of the shelving. Decided it needed some padding to prevent issues (mcmaster carr can get you pretty much anything).
Mounted some tires to the Weds. Found a set of Watanabe rs8 to add to the collection as well.
Ill post up more info on the shiro once its complete.
88ss 368
Old 07-27-2012, 01:24 PM   #46
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
If there was a like button on this still I would hit it!
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 09-21-2012, 03:19 AM   #47
z31_Law
z31_Law's Avatar
z31_Law is an unknown quantity at this point
Originally Posted by adamvann3 View Post
Been a while.
Old stock
New hotness
dude slap on the watanabes!!
z31_Law is offline   Reply With Quote
Old 09-24-2012, 09:56 AM   #48
copsloveslicks
copsloveslicks's Avatar
copsloveslicks is an unknown quantity at this point
another bad ass z31. nice work!!
Awful Hero S130
copsloveslicks is offline   Reply With Quote
Old 10-11-2012, 01:23 AM   #49
Blue91SL
Blue91SL is an unknown quantity at this point
I just have to say, your car is beyond beautiful. I hope mine will be a tenth as good as yours is.
I'm definitely subscribed for updates.
Blue91SL is offline   Reply With Quote
Old 10-17-2012, 09:56 PM   #50
adamvann3
adamvann3's Avatar
Thanks for the comments
Been busy this summer, but still made some time for the car
New Headliner
Rear window seals were getting a little gummy
Problem Solved
Wanted a better place to mount my harness. Bought, and re-fabricated a 4 point roll bar to suit my needs and had it powdercoated texture black
Trimmed the rear interior pieces, the finish product turned out really well
Much better now
Installed/tested one of my 18x11 in the back. Picture is at -11, but once I remove the 15mm spacer it should be back where I want it
88ss 368
Old 10-17-2012, 11:02 PM   #51
MAHALOHAWAII
MAHALOHAWAII is an unknown quantity at this point
I came here for the title... So there's no case of ciroc?
MAHALOHAWAII is offline   Reply With Quote
Old 10-17-2012, 11:06 PM   #52
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Cars looking good Adam, looking forward to seeing whats next, woulda been nice to talk to you a little more a few weeks ago.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 10-18-2012, 01:35 PM   #53
adamvann3
adamvann3's Avatar
Thanks. All I really see is getting the LXZ's on and doing a bit more driving next year. Been a roller coaster ride with Weds this summer trying to figure out to do with the unbalanced wheel. Everything worked itself out, but pretty late in the season before it was resolved. It was good seeing you and Liz this weekend, first time I really had the car at any sort of gathering or event this summer.
Ill have the car out this weekend weather permitting. Maybe Ill catch you out.
88ss 368
Old 10-29-2012, 10:08 AM   #54
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
niice more pics of wheel on car
project-D180 is offline   Reply With Quote
Old 11-10-2012, 08:56 PM   #55
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
wow. very nice z31
bataangpinoy is offline   Reply With Quote
Old 12-14-2012, 07:50 PM   #56
adamvann3
adamvann3's Avatar
Closing out the 2012 season. Have some good plans for 2013
Shiro_Fall12_2 by adamvann3, on Flickr
Finally painted the lip... why it I took so long is beyond me.
88ss 368
Old 12-20-2012, 02:36 PM   #57
Benedict
Benedict is an unknown quantity at this point
keep it going man. I'm looking forward to seeing it rolling around on the weds.
Benedict is offline   Reply With Quote
Old 12-20-2012, 10:19 PM   #58
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
there simply are NOT enough clean z31 builds.
Yours, on the other hand, is GORGEOUS.
Kudos to you, sir.
Old 12-20-2012, 11:12 PM   #59
Homeboyx
Homeboyx is an unknown quantity at this point
+1 on what ^ said.
Although I usually despise the late model z31's looks, this is definitely an exception. Clean, well put together, originality. Love it, subbed, and can't wait for future updates.
Homeboyx is offline   Reply With Quote
Old 02-17-2013, 01:13 PM   #60
first_choice
first_choice's Avatar
first_choice is an unknown quantity at this point
I wish there were more clean Z31s like this one, very nice car. Most of these I see are shot.
first_choice is offline   Reply With Quote
