Old 08-20-2013, 11:06 PM   #1
5casey1dimer0
5casey1dimer0 is an unknown quantity at this point
Sr20det power fc, Greddy intake, 2860rs, 740 injectors, more.
Not in a hurry to sell. Want to make a reasonable offer other than what I have listed? Go right ahead. 253 326 6355
S13 sr20det Power Fc D-Jetro with all sensors and engine harness. Commander included. $900
S13 sr20det Greddy intake manifold with throttle body. $500
Stock fuel rail, Nismo 740cc injectors, and adj. fpr $400
Tomei turbo manifold. Ugly Weld on top of collector to prevent a coming crack. $80
Garret gt2860rs "disco potato" turbo. T2 flange 5 bolt exhaust. Bolt on upgrade for sr20. Only custom thing needed is a hot pipe made. Only 4 events on it and 2 dyno sessions since new. $800
No name 3" down pipe for sr20det $100
Sr20det bell housing and transmission $350
OS Giken twin disk sr20det clutch. Good life on disks left. Pressure plate had some tough scoring from wrong TOB Collar being used. Works 100% fine. Will come with TOB and correct collar I bought new and used one track day. $800
One piece aluminum driveshaft for sr20 in s13 chassis. $350
S13 black top Sr20det complete long block. Head was hot tanked, decked, valve grind, new valve stem seals, stock cams, 100% fresh out machine shop only driven 4 times.
Bottom end brand new everything. acl race main and rod bearings, thrust washers, polished crank, honed block, brand new k1 tech rods, cp 8.5:1 pistons, apexi head gasket, and acl head studs.
Power steering pump, alt, belts, all included and working. All sensors and coil packs included.
Scoop on motor: last Sunday at SSSJ I was experiencing random blow by. A lot of it. However, the motor still had all of its power, 305/300 on dyno jet. All signs point to not enough time on the motor last year before I parked it for the winter. Oil separation rings are believed to have gone bad on a cylinder. Going to leak down test this weekend to verify. I'm over it- selling off the lot. Shoot me offers on a built engine that just needs some new rings and a proper break in.
I DO NOT CHECK FORUMS OFTEN- call or text me. Will ship on your dime. I can provide more specifics and pictures upon request. Motivated seller. Won't give hassle, won't take none. Serious inquires only please.
253 326 6355
5casey1dimer0 is offline   Reply With Quote
Old 08-20-2013, 11:27 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
you should post photos. they go a long way towards helping you sell shit.
Old 09-15-2013, 09:31 PM   #3
IM1ACEHOLE
IM1ACEHOLE's Avatar
IM1ACEHOLE is an unknown quantity at this point
Ya I agree. Post pics
IM1ACEHOLE is offline   Reply With Quote
Old 09-26-2013, 01:13 PM   #4
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Power FC still available?
Darren is offline   Reply With Quote
intake., power fc, s13, sr20det, turbo
