Old 09-29-2016, 07:54 PM   #1
Stancyeze
Stancyeze is an unknown quantity at this point
Ignition Switch wiring to switch panel
Just had some questions about wiring the ignition to my Moroso switch panel. I currently have the entire dash pulled and all the wiring exposed. I just need to know how to wire it, theres 5-6 wires coming from the main loom to the ignition switch. Just confused as to how to wire it to the switch panel switch...
Stancyeze is offline   Reply With Quote
Old 09-29-2016, 10:06 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
wire the ignition wires to the ignition switch.
done? ok good
in the future, go get a haynes or chilton manual that has wiring diagrams, then look at the diagram for the ignition circuit. THEN, look at the instructions from the moroso panel, see what i'm getting at?
Old 09-29-2016, 10:11 PM   #3
Stancyeze
done? ok good
I've read the Moroso instructions. Like I said, there are 5 wires associated with the switch so it's not possible to hook them all up to the switch panel switch. There's only one prong on the switch panel switch.
Old 09-29-2016, 11:16 PM   #4
brndck
brndck's Avatar
and like i said, you need a haynes manual or chilton manual to get the ignition switch wiring diagram.
Old 09-30-2016, 12:04 PM   #5
Stancyeze
The whole point of starting this thread was to see if anyone could had a diagram or could show me on their own car.
I understand the wiring schematic, what wires do what, but I can't figure out where to put the wires onto the switch panel to make them function.
Old 09-30-2016, 01:32 PM   #6
tuzzio
tuzzio's Avatar
The black wire with the white strip is the ONLY wire in an s13 chassos (if I recall correctly) that has power while cranking. So, i'd wire that to the switch and then from the switch to the starter
Old 09-30-2016, 01:50 PM   #7
Stancyeze
Okay and then what about Accesories(blue wire) and the ECU power(white/green wire). These two also need power when switching the ignition on.
Old 09-30-2016, 04:34 PM   #8
justinbyrant
justinbyrant is an unknown quantity at this point
google is so easy to use, its almost like they want us to use it for something
justinbyrant is offline   Reply With Quote
