Old 09-13-2016, 11:07 PM   #1
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Sway bar conundrum
18/16k spring rates
S14 rear subframe with solid frame bushings
S13 front suspension
What do i do?
Based off my re-search, opinions on sway bar setups are like assholes.
Everyone has one.
So before i make a offer on your swaybar let me call in a buddy whos a expert.
jared420sx is offline   Reply With Quote
Old 09-13-2016, 11:09 PM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
18k/16k???
I hope you mean 8k/6k.
Old 09-13-2016, 11:23 PM   #3
jared420sx
jared420sx's Avatar
Originally Posted by e1_griego View Post
18k/16k???
Unfortunatley that was not a typo
Old 09-14-2016, 02:21 AM   #4
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
What are you prepping the car for?
battery1882 is offline   Reply With Quote
Old 09-14-2016, 07:46 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
the illest hardparking you've ever seen.
unless you're planning on running the softest compound tires mankind has ever seen, and only drive on roads smooooooooth as glass, there is no reason for those rates (other than hellaillestflushness )
Old 09-14-2016, 07:48 AM   #6
jedi03
killing kidneys by the sound of it..lol
Old 09-14-2016, 08:14 AM   #7
jared420sx
jared420sx's Avatar
Time attack. I will probaly get softer rates in the near future
Old 09-14-2016, 09:59 AM   #8
Blk96t
Blk96t is an unknown quantity at this point
Assuming its a s13 chassis?
I did the s14 subframe swap also.
Use s13 sway bars.
The fronts are different. Rear bars are the same.
I've used suspension techniques on 3 cars. There isn't better bars for the money.
Blk96t is offline   Reply With Quote
Old 09-14-2016, 10:01 AM   #9
e1_griego
e1_griego's Avatar
Trader Rating: (24)
With that much spring you dont' really need bars.
Old 09-14-2016, 12:30 PM   #10
jared420sx
jared420sx's Avatar
Any other expierences here? Ive seen people not runnig the rear bar to increase over steer?
I dont understand how spring rates determine sway bar effectiveness though.
Old 09-14-2016, 12:38 PM   #11
e1_griego
e1_griego's Avatar
Trader Rating: (24)
A sway bar essentially adds spring rate in roll. Your car is way oversprung already, I can't imagine making it even stiffer.
You'd better be running like 335 Hoosier A7s or something, or Avons.
Old 09-14-2016, 02:45 PM   #12
battery1882
I would not run sway bar with those rates..
you have two choices :
1. Do it right and have those springs replaced and re-valve the shocks
2. Don't run sway bar if you're on a really tight budget: springs do not cost that much..
Also generally, having no rear bar will make the car under-steer not over-steer.
Regardless, have fun at the track and be safe!
Old 09-14-2016, 02:46 PM   #13
brndck
brndck's Avatar
Ive seen people not runnig the rear bar to increase over steer?.
I was gonna say the same thing. No rear sway will make the rear end LESS likely to step out.
Old 09-14-2016, 03:06 PM   #14
jared420sx
jared420sx's Avatar
Since i plan on redoing my springs and revalving in the near future what set up would you guys reccomend(spring rates and swaybar). I do want to be fairly low if that sways your opinion in anyway.
Old 09-14-2016, 03:55 PM   #15
brndck
brndck's Avatar
8/6 is pretty standard for s-chassis. 10/8 if you're going to be running 140tw tires (and you'll need shocks valved to match)
I've run largus sway bars in the past and they were excellent, I currently have tanabes and they're nice too. to be honest, unless you're switching from one to the next, back to back, 90% of users won't know the difference. if there are different holes on the end of the sway bar for adjustment, you will notice the difference going from one setting to the next.
Old 09-14-2016, 05:16 PM   #16
jared420sx
jared420sx's Avatar
Would running no sway bars for a few weeks be a bad idea or would it really just be a preference thing more than a safety thing?
Thanks for all responses to btw
Old 09-14-2016, 06:13 PM   #17
brndck
brndck's Avatar
on the street, no worries.
if you're going to a track event, and are unfamiliar with how the car will handle with no sway bars, i would advise EXTREME CAUTION.
handling characteristics will be markedly different with no sway bars
Old 09-15-2016, 11:22 AM   #18
Croustibat
I was running with 9/7K and no rear swaybar, front was a 29mm godspeed.
Then one day, i noticed a droplink had failed. I did not even feel it. Since then i binned the front bar too.
With 18/16k the car does probably not have more than 5mm of suspension travel, sway bars are useless. If you wanted a swaybar that would go with these springs, you'd probably end up with a solid 40mm bar, if not bigger...
Basically on the s13, if you are running heavy aero (diffuser, canards, splitter, flat bottom, huge rear wing), you'd want around 12/10. No aero, 10/8 is good.
As far as sway bar goes, it ends up being driver's preference. I like no sway bar in the rear, it gives me better traction with the torsen. But i might end up adding one back to the front. best bet once you are back on softter spings is to try whatever bars you have and see what you like best.
Old 09-15-2016, 12:18 PM   #19
jared420sx
jared420sx's Avatar
Thanks for all the replies guys! I think this is my first thread that i havent got roasted! lmao
