Old 08-12-2015, 11:33 PM   #1
Suprareal
Suprareal's Avatar
Suprareal will become famous soon enoughSuprareal will become famous soon enoughSuprareal will become famous soon enoughSuprareal will become famous soon enoughSuprareal will become famous soon enough
Suprareal's Proper Silvia Conversion Build
This thread will Showcase progress photos of my 2nd current S13 build.
93' 240sx converted to a "true" Silvia, meaning RHD, Front end swap, and SR.
And will include tips on how to successfully convert for people who might need the help.
This build is Visual oriented VS my track hatch build found here : http://zilvia.net/f/showthread.php?t=487054
Current as of 2/1/20
Let’s start this off
When I first bought the car as a shell for 200$. With no real intentions of what I’d do with it.
Started the Firewall swap first. I did this the most "legit" way you can possibly do a firewall swap. I say this because there's no real way to be completely proper about this.
Every single spot weld was drilled out and welded back up. This includes the JDM wiper/cowl section that people often dont bother doing while swapping.
If you choose to include the cowl in your swap you will loose your original stamped vin number so make sure you keep the old firewall piece if you plan to make in legal.
Make sure to seam seal your welds and creases making sure they wont leak. I through on some paint for rust.
Keep in mind the e brake bracket will need to be removed and retrofitted if you did not have the JDM one like me. I was able to cut the old one up and use it with the USDM handle.
Here is a mockup making sure everything still fits good
For wiring I am using the JDM body harness from a RPS13 so I needed to rip some wires out that i would not be using and connect to my tail light harness. This can vary from what car your clip was cut from and what shell you are converting.
If you plan to keep the auto seat belts you will have to wire them in yourself as the JDM s13 never came with them but a airbag instead. As for me i ditched the auto belts for s14 belts.
Since this is a visual build i did a tuck and threw all the wiring under the dash. The vent housings are not compromised by this, everything still sits where it should. The fuse boxes sit in the glove box via a tab welded to the dash bar. The glovebox has to be cut in order for it to close as you can see.
I welded 2 bolts to the dash bar to connect my grounds to.
I cant finish the wire tuck completely until i have the motor in place so i can cut to fit the engine harness so I started on the tubs. This is my second time doing tubs and was done in less than 3 days work by myself with essentially just a angle grinder and welder. If this is your first time don't be scared to jump on this project. I used 1 10'' trailer fender cut in half with sheets of 16GA scrap. Cardboard templates are all you need to get started.
If this is your first time doing this or new to welding... take the time to make all your ends sit as flush as possible in order to get the best weld.
If your OCD like me you can level out your car on jack stands so you are able to keep your tubs level and identical on both sides.
You can run small tacks around all of the seams and it will probably be strong enough but my preference is to run short beads around. Unlike my tubs in my Hatch these will be seam sealed for a cleaner look.
If your tubbing your going to end up stitching the towers, again I don't like the looks of small tacks running around so i did small beads again.
I decided to plate off the front of the frame wells as well as they will later be used for bash bar supports.
Suprareal is offline   Reply With Quote
Old 08-13-2015, 08:00 AM   #2
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
I like where this is headed.
-Jspec-
Instagram/CrimsonRockett
Old 08-13-2015, 08:11 AM   #3
Hatemy7
Hatemy7's Avatar
Hatemy7 is an unknown quantity at this point
very nice work seriously
Hatemy7 is offline   Reply With Quote
Old 08-13-2015, 08:28 AM   #4
ikennrockdis
ikennrockdis is an unknown quantity at this point
very interesting. totally forgot the jdm harnesses didn't have auto seatbelts, i gotta keep that in mind before i put mine in. looking forward to your future progress.
ikennrockdis is offline   Reply With Quote
Old 08-13-2015, 05:17 PM   #5
Suprareal
Suprareal's Avatar
Ill be running a front mount and decided against doing anything extraordinary with the piping routing even though i wanted to. So i just went the traditional way and cut out the holes. Later I will be tigging my own piping.
If you have a 3" hole saw or the money to buy a nice one I highly recommend it.
I don't have one big enough so i just drilled a hole and used a reamer bit until it was big enough.
My front clip was original to the digital climate control so it was all plug and play for me essentially. For those who are thinking about putting one in your s13, do it especially if you have working A/C you will love it.
A/C on this car is still an idea im not sure if i want to go through with yet, well see.
My plans motor wise were constantly changing before i finally decided to go SR. I even thought about throwing in the viper V10 while working on Dean Kearney's new Viper. After research and measuring it was not a good choice for me. It is much longer than a JZ motor and does not add up in performance VS a LS swap while also thinking about finance.
And a pic of Robbie's car after the crash at Long Beach !
Old 08-23-2015, 03:41 AM   #6
Suprareal
Suprareal's Avatar
Its great having a girlfriend who actually supports the hobby. She bought me this 20ft long canopy that serves as my constant work space and will also serve as the paint booth.
Next was something i contemplated for a while but came out better than expected. After seam sealing ( which was is difficult to make a neat seam ) i decided to try making some areas completely seamless.
I used fiberglass bondo for this, only enough to flush out the edges. If your doing this try not to build it up to high anywhere because it will have more of a chance cracking later.
Went through the works with this. Wet sanding, priming, spot putty, repeat.
Next was to sand down the firewall and rear tubs to prime the whole bay.
Fully primed
P/S reservoir will be here in the corner not interfering with the wiper motor. I had done this in my hatch when it used to be SR and was very happy with it.
Interior seats are still being decided. Leaning towards using matching S14 kouki's.
Old 08-23-2015, 02:37 PM   #7
Arteeste
Arteeste's Avatar
Arteeste is an unknown quantity at this point
I like where this is going
Arteeste is offline   Reply With Quote
Old 08-23-2015, 06:48 PM   #8
JRex
JRex is an unknown quantity at this point
This is looking really good so far. I was thinking of doing something similar with my PS reservoir, definitely have to now that I've seen yours.
Never Due
JRex is offline   Reply With Quote
Old 08-23-2015, 07:02 PM   #9
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Very cool shit. Really digging it.
Old 08-28-2015, 02:02 AM   #10
Suprareal
Suprareal's Avatar
I made a power brace, this is the 3rd ive made for an s13. I don't have a dimple die or else i would have done the bottom plates.
Finally was ready to paint the bay. I chose a dark teal metallic.
P/S reservoir was also painted to match.
Base before clear was applied.
Don't worry about the over spray on windshield, its cracked and just sitting in place not stuck down for now. I wont be using this one.
Final spray
Old 08-28-2015, 04:34 AM   #11
808_s13
808_s13's Avatar
808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future
dope stuff man. keep up that hard work.
on another note, ive used that same canopy to paint before. just get some plastic sheets on the side and set up 2 square fans w/filter for intake and exhaust.
Originally Posted by ILoveMyRHS13;
Tomei or Megan? Is like comparing Trojan condoms and Ziplock bags.
808_s13 is offline   Reply With Quote
Old 08-28-2015, 08:49 AM   #12
OBEEWON
OBEEWON's Avatar
I enjoy your silvia immensely.
however it is no match for My Skyline.
Perhaps photo's of Robbie's suspension setup are in order?
My Skyline and I thank you in advance.
Old 08-28-2015, 10:04 AM   #13
w1zeman
w1zeman is an unknown quantity at this point
You sir have excellent taste. This has got to be one of the most top notch, attention to detail builds i have ever seen. Also your welds look extremely great for just mig, id hate to see your tig skills.
w1zeman is offline   Reply With Quote
Old 08-29-2015, 10:03 AM   #14
Heywood Jablomie
Heywood Jablomie is an unknown quantity at this point
wowee love that paint, nice color
Heywood Jablomie is offline   Reply With Quote
Old 08-29-2015, 06:14 PM   #15
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Very nice work. However, once a 240sx, always a 240sx. Never forget that.
Old 08-29-2015, 10:10 PM   #16
R_Rod_s13
R_Rod_s13's Avatar
R_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really nice
Seen you driving your hatch around long beach a few times ( I'm from long beach also) ... Both cars looking good !
fuck i hate zilvia
R_Rod_s13 is offline   Reply With Quote
Old 08-30-2015, 09:26 PM   #17
D-Clem
D-Clem is making a name for him/her selfD-Clem is making a name for him/her self
this is great!
D-Clem is offline   Reply With Quote
Old 08-31-2015, 10:50 PM   #18
Suprareal
Suprareal's Avatar
Everything metal that is removable that goes in the engine bay will be painted. Everything that needs to be painted black will have a slight purple flake! Its hard to get good pics of the reflection of the flake but im very happy with the outcome.
Every nut and bolt used will be either new or close to it. Nothing stripped or rusted. These brand new headlight brackets came with the shell, i think i will paint them black with flake as well.
Front end being mocked up for wiring to lights cut to length
Old 08-31-2015, 11:24 PM   #19
blasian
blasian is an unknown quantity at this point
almost there keep up the good work
blasian is offline   Reply With Quote
Old 09-01-2015, 07:05 AM   #20
Apex Eight
Apex Eight is an unknown quantity at this point
This really is proper. Some people seem to throw that term around a bit loosely these days, but I feel as though you deserve to use it so far. Keep it up man.
Apex Eight is offline   Reply With Quote
Old 09-01-2015, 08:30 AM   #21
_tony_s13
_tony_s13 is an unknown quantity at this point
damn bro... this thing is gonna be fuckin cherry when shes all done oh my god
_tony_s13 is offline   Reply With Quote
Old 09-02-2015, 02:23 AM   #22
Suprareal
Suprareal's Avatar
The booster got a pretty big run on the clear coat. To big to just let it slide so i re sanded it down and did a respray
How often do you still see these yellow rubber pieces that keep the crash bar level still on the car?
Here's a few shots of the painted parts being put back onto the car
The SR has been in pieces since i started this whole project and i finally have the time to start putting it back together.
Im doing a full stock rebuild since i don't plan on making and more power than stock.
These pictures are taken after taking all the appropriate measurements of course.
Everything as clean as can be before install. Freeze plugs were also replaced.
Old 09-07-2015, 08:41 PM   #23
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
moaaaarrrr
turboshoebox is offline   Reply With Quote
Old 09-08-2015, 12:42 AM   #24
Suprareal
Suprareal's Avatar
Came across this vert for 30 Bucks so I brought it home (without the silvia front pieces). And the tail lights for the Silvia from the same guy. These lights were always in my plans but just got them much sooner than anticipated.
Vert Will a full on KA missile with just a seat and steering wheel being done under 700$ just to have a little fun with.
Partial cage will be added onto as well.
Fresh new Energy suspension steering rack bushings came in and i was able to install the freshly painted rack.
Night picture kinda shows the sparkle of the purple flake on the subframe.
Don't think i mentioned this but the rack is HICAS. For those who dont know the HICAS rack reaches full steering lock quicker that a ordinary rack. Even though this wont be a drift car it will still be a compliment. I'm currently working on a small angle upgrade for the car for fun.
Old 09-08-2015, 11:45 AM   #25
JRex
Attention to detail makes me happy. Loving the subtle touch of purple flake on random bits and pieces.
Never Due
Old 09-08-2015, 01:57 PM   #26
drewr4411
drewr4411's Avatar
drewr4411 is an unknown quantity at this point
love the color choices.
is there any paint code to that black with purple flake? or is that flake added by hand?
89 S13/2JZ Silvia(Project Phoenix)
IG @awrperformance FB awrperformance
drewr4411 is offline   Reply With Quote
Old 09-09-2015, 02:27 AM   #27
Suprareal
Suprareal's Avatar
The flake is added into the clear mix right before shooting. You can add as much as you like to make more or less dramatic look. Also laying multiple coats will give different looks. Everything I've done so far was one thick coat.
Old 09-12-2015, 12:59 AM   #28
Suprareal
Suprareal's Avatar
Due to the plans of this car being a show car I will be paying alot of attention to wheel fitment. lower control arms extended by 50mm (2'') will give me loads of camber which will work perfect for my setup because i am using stock tension rods and will be adjusting caster with the coil camber plates. Fitment idea will be similar to Justin Shreeves car.
Old 09-12-2015, 02:08 PM   #29
JRex
Why are you keeping the stock tension rods? Justin's car is pretty much perfect
Never Due
Old 09-12-2015, 10:48 PM   #30
Suprareal
Suprareal's Avatar
Stock tension rods for now. Ill adjust caster with the camber plates on the coils if needed. The car wont be driven much at all so i don't think aftermarket tension rods are necessary for now.
