Old 09-24-2019, 09:13 AM   #22831
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Originally Posted by Andrewkd View Post
hey guys, currently swapping my pop up front for a Silvia front, as I was disassembling the front end I found this, what is this? do I keep it for the Silvia front?
thank you!
https://imgur.com/gallery/2k9oQPG
lol that is your horn
Old 09-24-2019, 01:51 PM   #22832
S14rebuild
thank you!
Thats super fukn rare treasure...holy grail of 240....take the pic down asap and dont let anyone know u have it.
Old 09-29-2019, 07:08 PM   #22833
Presto
Presto's Avatar
Presto is an unknown quantity at this point
Inside of my friends 240sx door there is the vin plate, on it there is a black stamp reading “1” and then /89 so it reads 1/89, we were wondering what this meant, made in January of 1989? Made in 1988? Or unrelated to date
Presto is offline   Reply With Quote
Old 09-29-2019, 09:31 PM   #22834
S14rebuild
Reads January of 1989
Old 09-30-2019, 01:53 PM   #22835
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
When using an oil restrictor for bb turbo, is it better to place the restrictor close or further away from the turbo?
lewisfk is offline   Reply With Quote
Old 09-30-2019, 01:54 PM   #22836
lewisfk
lewisfk's Avatar
s13 Oil restrictor
Old 09-30-2019, 04:20 PM   #22837
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
usually the restrictor is on the fitting going into the turbo.
Old 09-30-2019, 05:26 PM   #22838
lewisfk
lewisfk's Avatar
got it thanks!
Old 09-30-2019, 08:39 PM   #22839
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
what's everyone running wheel offsets to fit Origin type 4 75mm fenders and rear quarters. i'm trying to cut out wheel spacers. I'm running 18x9.5 -16 & 18x10.5 -16, 265/35 front he front and maybe 315/35 for the rears for tires.
this for a s13 for time attack or road courses.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 09-30-2019, 08:41 PM   #22840
s13silvia123
Old 10-03-2019, 04:07 AM   #22841
Presto
Presto's Avatar
Would the d21 intake box fit a 240sx Ka24e SOHC?
Both the d21 and 240sx have a Ka24e, could I use a d21 air box for my 240sx intake? Thanks
Old 10-03-2019, 04:49 PM   #22842
S14rebuild
You can use it but wont fit factory....intakes are designed diffrently, so box, snorkle tube are diffrent aswell
Old 10-04-2019, 06:19 AM   #22843
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
SR20 S13 Idle valve
Does anyone know if the SR20 S13 idle valve NEEDs coolant to be ran to it for it to function properly?? What I am getting at; does the stock valve have the wax stat (internal solenoid/thermostat for the air bypass valve) that aids in idle adjustment??
I do not have coolant running to mine and wondering if that is affecting the struggle to idle while cold and allowing too much/little air to bypass into the manifold.
I am on a MAP sensor btw
Old 10-04-2019, 07:05 AM   #22844
S14rebuild
Originally Posted by RalliartRsX View Post
SR20 S13 Idle valve
No it doesnt need coolant...it certainly helps, specially with iutside temp fluncation compared to operating engine temp.
Now if your running a standalone(cause ur running map) u could tech. Delete the whole ivac setup, use throttle adjustment screw for idle and tune for that.
Im sr20 greddy intake manifold and deleted the coolant lines running to my ivac. No idle issuses at all.
Old 10-05-2019, 09:15 PM   #22845
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
This is a noob ass question, but I just want to be absolutely sure. I blew a head gasket at the last event(confirmed with block tester). I noticed afterwards that when turning over the engine was audibly down a cylinder. I hoped it was the head gasket, but it's still doing it after replacing it. The engine runs smooth, but I'm 97% sure it has a cracked ringland or two. I'm fixing to rebuild the motor(oe rebuild, nothing crazy). Could this ringland failure have been caused by driving with the blown head gasket? I only stopped driving when the car stopped dropping from ~240F after runs, so obviously it was leaking the last few runs, which is when I noticed it sounding like it was down a cylinder.
My next related question is can there be detonation present but absolutely no damage to the piston tops or spark plugs? Everything APPEARS normal, but that doesn't always mean it's fine. There was never any sign of detonation when tuning, I've never heard any and I've never noticed it pulling timing. I'm pretty confident there is no detonation, but again I just want to be sure.
Old 10-06-2019, 09:34 AM   #22846
S14rebuild
Ringlang failure could of been caused from overheating(headgasket issuse) could of happend from cooland entering the cylinder and liquild doesnt compress.
Yes u could have detonation and no signs. But that be so little couldnt imagine it cracking a ringland.
Maybe ur down a cylinder due to just a blown head....run a leakdown test and ull get ur answer.
Old 10-06-2019, 10:18 AM   #22847
Hoffman5982
Trader Rating: (25)
I’ve since replaced the head gasket and it is no longer leaking. I also forgot to note there is blue smoke at idle now, so I figure it’s most likely a ringland failure or at least substantial wear. The motor had 280k so it’s to be expected
Old 10-06-2019, 11:30 AM   #22848
S14rebuild
Leakdown test will answer all ur questions lol
Old 10-07-2019, 12:24 PM   #22849
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Has anyone ordered from Fineline Tuning recently?
I placed an order over a month and a half ago and am yet to receive any update. I've tried emailing Alex during business hours through the email listed in their contact section but no reply... Went as far as trying to contact them through their eBay store and still no luck.
Anyone else run into this before? Trying to get my car to paint, a general time frame for when the aero should arrive would be helpful. Thanks in advance.
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 10-07-2019, 01:32 PM   #22850
Alan_s14
Alan_s14's Avatar
Alan_s14 is an unknown quantity at this point
Hey there, i´ve been out of the scene for a while now... Long story short, a local guy is looking for quick money for school, he´s trying to sell a set of allegedly Road Magnet lowering springs for my S14... (i had hear about them and from what i remember, they where one of the best suspension for B13, B14 or B15) i´ve been searching but i can't find a thing about this springs for a S14... guy is asking for 75 USD... any thoughts?
Alan_s14 is offline   Reply With Quote
Old 10-07-2019, 03:11 PM   #22851
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Alright guys I bought a s14 Sr20det that was rebuilt and the guy removed a bunch of plugs that thread into the block and I am missing about 5 of them.
This is how they look
I’ve searched and cannot seem to find these at all, Idk what to do
Hopefully someone has some extra ones they can sell?
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 10-07-2019, 03:14 PM   #22852
coupesallday!
Trader Rating: (18)
Double post....................
Old 10-07-2019, 03:16 PM   #22853
S14rebuild
I tried to place an order....tried to reach themnthru multiple outlets including zilvia...to this day no replies...spent my money eles where and couldnt be happier.
From what i was told ull wait months to recive ur order and no communication, so keep waitn is all i can tell u.
Old 10-07-2019, 03:19 PM   #22854
S14rebuild
Fukn $75 lower springs...buy them there LOWERING SPRINGS LOL
Old 10-07-2019, 03:23 PM   #22855
S14rebuild
https://www.mazworx.com/mazworx-sr20...-plug-kit.aspx
Solved..
Old 10-07-2019, 03:26 PM   #22856
coupesallday!
Trader Rating: (18)
Thanks man!!!!!!
Old 10-08-2019, 06:29 AM   #22857
EFITTZY
EFITTZY's Avatar
Thanks for the reply, saw your FineLine Tuning thread right after I posted in here... I guess I will keep waiting
Old 10-08-2019, 08:12 AM   #22858
S14rebuild
There quality dropped alot aswell, so be prepared todo more then the usual body work to have a decent fitting/looking kit. Lots of air pockets in fiberglass, thing layers in spots and rough gel coat spots. All the edges are super rough.
Just speaking on what ive come across.
Old 10-08-2019, 12:28 PM   #22859
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
literally MOST people who orde rfrom fineline go through this same thing.
its 1 dude doing everything. its gonna take a while. did he give you a timeframe when you ordered?
Old 10-08-2019, 03:46 PM   #22860
Eyze240
Eyze240 is an unknown quantity at this point
I have a broken maf sensor that reads 22680 53F01 A36 00 G62 all the other ones I find are 22680-53F00-A36 00 G60, only a 2 number difference I’m just wondering if it will mess up anything
Eyze240 is offline   Reply With Quote
