12-01-2013, 09:37 AM | #31 |
Similar to a gt35 !
My budy with a similar set-up runs 425whp @ 20psi
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
12-01-2013, 09:46 AM | #32 |
12-01-2013, 03:52 PM | #33 |
No dyno graph from that car !
12-02-2013, 06:47 AM | #35 |
Yup on pump fuel (94 oct) from PetroCanada
12-03-2013, 04:43 PM | #37 |
12-03-2013, 06:37 PM | #38 |
The fuel i wish we had at the pump is e85 ! That would be sick and i would be able to go over 20/22psi
12-04-2013, 06:11 AM | #40 |
12-04-2013, 09:23 PM | #41 |
any one ever bought parts for a z33 transmission !!! what was the best place if you all ready did
my nissan dealership here is asking for 900$/gear i need to change 3 ... i started looking around on the net and in the state at the dealer ship its around 1/2 price ... is there a place cheaper ???
12-05-2013, 06:13 PM | #43 |
Brand new cd009 is around 2500$ in the state here in canada its over 5k$
If i remember the first time i looked around for gear the amount was around 650$ For 1 , 2 and 3 gear with new synchros Its about 130 to 150$/gear depending of the size Infiniti Gear Assy-1St | Infiniti Part Number 32230-54C14
12-05-2013, 06:14 PM | #44 |
Ill look rockauto.com to compare price
02-08-2014, 09:08 AM | #45 |
My built was dead for a couple of weeks ! I had bills to pay with my new house.
Should be back on track now ! I just bought a adaptor plate sr to vq from Autotech Motorsports Quality is there ! The owner was working at mazworx before , they slip up and he opened up Autotech Here are some pics ( the bellhousing is not machined yet )
02-08-2014, 06:36 PM | #47 |
The house : in the 3**000$ !
02-08-2014, 10:19 PM | #49 |
Idk the auto tech one just seemed sketchy cause the guy wouldn't provide much information. And you only use half the bolts to bolt the trans to the engine... So do you only get half of the bell housing machined or something?
02-09-2014, 10:58 AM | #50 |
We are runing a mazworx sr to gm adaptor for the g-force gsr on dave briggs car and its like my set-up !!!
02-11-2014, 03:22 PM | #53 |
I dont have all the info with me !
My mecanic told me to machined down .500 where the plate is on the bellhousing ! This will bring everhthing flush ! I dont have info yet on the release bearing !
03-02-2014, 11:49 AM | #54 |
03-15-2014, 07:54 PM | #55 |
little up-date guys ... my friend that is doing my bell-housing just got back from a ski vacation in Chamonix ... so my bell-housing should be done real soon
anyway even if its done tomorrow i cant put it on ... i still need to buy gear 1/2and 3 with there syncro since im waiting on my bell-housing ... i decided to check my OS Giken ts2bd clutch to make sure its in good condition ... i bought it used from a friend for 500$ . he did a rebuilt on it before he decided to sale it to me ! the clutch looks like its new , but i wasn't sure if it would slip or not because when you face all those disk in the clutch (not real number just for example) total machining .25inch ... you would need to take that off from the flywheel off too (where the *tower* is bolted down) if you don't you automatically loose clamping force i found a friend on facebook that all ready did rebuilt on those clutch and thats what he had to say from: Alek speedtek: the way to check the flywheel is, put the whole clutch together Then let the top cover sit on the clutch with all the allan key bolts in But dont tighten them Measure the gap between the tower on the flywheel and the cover It should be 2.5/2.75mm or maximum grip Yours might have gone down below 2mm and that is when it starts to slip alittle my clutch was at 2.01mm so i took everything apart and i brought it to a machinist to remove a bit of material from the flywheel ... it's now at 2.90mm he went a bit over 2,75mm but everything looks ok and the bearing should have enough stroke to disengaged the clutch completely ...
03-16-2014, 12:06 AM | #58 |
I hope ill drive it this summer but with the new house ! $$$ money is harder to get for car parts ! I still need ecu (aem ems2) , injectors and fuel systeme , gears and assembly off my transmission , custom intercooler and piping , downpipe , wiring harness ! Lolll im not close to be done yet
03-16-2014, 12:07 AM | #59 |
You bet ! I jumped on it i soon as he told me he had it for sale
03-16-2014, 12:12 PM | #60 | |
