02-20-2017, 12:08 PM | #1 |
S14 FLCA's on S13
Just picked up some S14 FLCA's for S13. How much more negative camber do you think I'll get?
02-20-2017, 12:51 PM | #2 |
8 million degrees
https://www.instagram.com/jdpowersport_/ |
02-20-2017, 12:53 PM | #3 |
Trader Rating: (130)
Feedback Score: 130 reviews
man i miss the rep system
02-20-2017, 01:26 PM | #4 |
quick search on google
"It will increase track by 10mm on each side, which means that if you run the same amount of camber before and after installing the s14 FLCAs then you will have the same wheel fitment as a car with a 10mm lower offset and stock FLCAS. As far as actual wheel clearance is concerned, it will not be affected. So it does not directly change the offset, but it will make the wheels fit the body of the car as if they were a lower offset." |
02-20-2017, 07:18 PM | #7 | |
Functionally, yeah you're probably safe just ballparking 8-10mm less clearance on your fitment, but technically it's not the same as just switching to a wheel with 10mm lower offset. Splitting hairs. |
03-19-2017, 11:53 AM | #10 | |
you should definitely check your toe setting afterwards, since it will have changed |
03-19-2017, 01:06 PM | #11 | |
You'll have so much camber it will be sick. Leave the toe setting and OE ball joints. Car will be MINTY.
/sarcasm
