Old 09-07-2014, 04:51 PM   #1
__natee
__natee's Avatar
__natee is an unknown quantity at this point
Suggestions? Ichiba hubs stripped
Hopefully I can describe my issue clearly... As you may know, the lug bolts are able to be pushed out of ichiba hubs. When they are pushed back in, you have to align the vertical treads of the hub and of the bolt all the way thru when putting back on. Noticed yesterday when taking out my lug nuts that the bolt was spinning with the lug nut, luckily, I had power tool to spin it fast enough to loosen off. Looking at the bolt, the vertical treads were still in good condition. Unfortunately, the vertical treads on the hub for that hole is completely stripped. Now, I'm unable to tighten or loosen the lug nut properly. Bolt spins with the lug nut all the time. I have this issue for both front hubs.. 1/5 holes passenger side hub, 2/5 holes driver side hub..
Any ideas of what I can do? Warranties I don't know about? They are like 3 years old btw so I doubt any warranty can help.. Or do I just buy new ones..
Any suggestions would help..
__natee is offline   Reply With Quote
Old 09-07-2014, 04:57 PM   #2
G-E@Z31P
G-E@Z31P is an unknown quantity at this point
Pull the loose studs out and measure the new hole diameter on the back, it's possible you can find replacement studs from dorman's catalog that have a larger spline size but same thread
Edit: you'll want .008" or .2mm larger spline diameter than the hole for correct fit
G-E@Z31P is offline   Reply With Quote
Old 09-07-2014, 07:05 PM   #3
__natee
__natee's Avatar
Thanks man! That makes sense! I'll give it a try, hopefully a can find a shop with these studs tho :/
Old 09-07-2014, 07:20 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
or tack weld each one in place. (assuming that they're like materials)
Old 09-07-2014, 11:30 PM   #5
__natee
__natee's Avatar
Thanks! I'll definitely consider it
Old 09-08-2014, 12:34 AM   #6
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Was the stud removed and then put back in? I usually oil up the splines and then draw them in all the way with a lug nut and a set of washers when replacing the studs.
om3ga is offline   Reply With Quote
Old 09-08-2014, 02:28 AM   #7
G-E@Z31P
You should always press or hammer them in from the rear
240sx 180sx, 5 lug conversion, hubs, ichiba
