Old 07-15-2022, 03:59 PM   #31
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Originally Posted by TheVinylKingz View Post
Update: forgot to mention the ECU is throwing code 11,12,13. From my research I?ve seen people say the timing on the SR should be 15, others say different.
Is this correct?
Also can I check timing by simply aiming the timing gun at the ?crank case pin??, or do I need to reposition at TDC before checking my timing?
Weird how CTS is throwing a code and I just installed a new one, including an Orilley SOHC Ka24e Maf
11 - Camshaft Position Sensor
12 - Air Flow Meter
13 - Coolant Temperature Sensor
which coolant temp sensor did you replace? there are two. one for the instrument cluster and one for the ecu
ALSO, if you had the key on while replacing those sensors, that may have triggered the code since it would have seen the circuit go open.
Old 07-15-2022, 05:17 PM   #32
TheVinylKingz
TheVinylKingz's Avatar
TheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura about
I replaced the coolant temp sensor that sends the signal to the ECU. I didn?t have key on the ignition turned on.
S13 SR, S14 KA
TheVinylKingz is offline   Reply With Quote
Old 08-18-2022, 01:29 AM   #33
TheVinylKingz
Update !!!! After countless hours testing voltage, and researching. I decided to take it 1 more step further and bought a brand new CAS.
SR started right up, ran it, shut off turned on and so far so good !! Back in business
S13 SR, S14 KA
sr20 240 s13 sr20det
