12-20-2015, 04:09 PM | #18931 |
Im thinking about picking up a purple Bride Brix 1, but there are some tears and fading in the fabric. Does anyone have any suggestions on how to restore the seat?
12-20-2015, 06:50 PM | #18933 |
^oem, autozone ,oreillys. for a daily.
for kade,s13 car not starting, should there be battery voltage at fuel injector pigtails with ignition on? i am using multimeter and there is no voltage when probing pigtails. if i probe 1 socket and negative on battery i get voltage. http://www.geeksoncars.com/how_81912...ire-240sx.html is this right? |
12-20-2015, 09:00 PM | #18934 |
http://www.courtesyparts.com/
Is there a way to get back to the old Courtesy Parts website? The new one isn't as comprehensive in the way you can search for parts. |
12-20-2015, 10:32 PM | #18936 | |
Trader Rating: (26)
Feedback Score: 26 reviews
ಠ_ಠ |
12-21-2015, 12:10 AM | #18938 |
12-21-2015, 11:47 AM | #18939 | |
Just get the Tien tie rod set, though you have to get the inners and outers as they are S14 style and mixing and matching does not work. If you want to pick something up at local auto parts store look into getting S14 inners and outers though I am not sure the price will be much less.
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
12-21-2015, 12:38 PM | #18942 | |
Moog, which ends up being the recommendation for most parts like that if you are staying stock.
12-21-2015, 01:45 PM | #18944 | |
That is your Core Support.
12-21-2015, 02:42 PM | #18945 |
I've been trying to find a ball park ride height for my 1992 240sx that I plan on tracking (lapping at 1st). I'd like to keep good suspension geometry. What I found is that the stock right height from top of the wheel arch to the ground is this:
S13 (assumed 195/60-15 OEM size tire) Front = 694mm Rear = 670mm I then subtracted the OEM tire radius to make it size generic and got this measurement (from center of the wheel to the bottom of the arch): Front = 386.5mm Rear = 362.5mm I was planning on dropping it somewhere around 1-1.5 inch from stock so let's say 30mm drop which would give me measurements of: Front = 356.5mm Rear = 332.5mm Does this sound reasonable? |
12-21-2015, 09:54 PM | #18946 |
Ok i am a little confused about the 4 to 5 lug swap I read somewhere that for an s13 to 5 lug requires uca lca and knuckle, or is it as cut and dry as swapping the hubs and rotors?
I already have 4/5 lug drilled rotors for the 300zx brake up grade (front) so all i would need is s14 rear rotors right? I don't know if my rear brakes are the 300zx how can i find that out?//// Upon fuurther investigation they are not 300zx rears just stock s13 rear breaks. what are my options? i want this swap just to get 5 lug cause the wide array of wheels available. thanks, Last edited by AnonymousBlackX; 12-21-2015 at 10:03 PM.. Reason: I'm an idiot and kinda drunk |
12-22-2015, 03:17 AM | #18947 |
Rear S14 5-lugs bolt right up to S13's. ZERO modifications needed.
Up front there's a couple options. The one I recommend is just buying the Ichiba conversion hubs and buy a set of brand new oem bearings. Press out the Ichiba bearings because it seems a good number of people have been having longevity issues.. |
12-23-2015, 06:51 AM | #18948 | |
http://240sxconversions.com/ BUT, seeing as how NISSAN hubs run 100+000 miles without issue, why not just spend your Christmas and tax return money and get good no bullshit Nissan parts that will last and have no issues
12-23-2015, 10:43 AM | #18951 |
Trader Rating: (24)
Feedback Score: 24 reviews
It's all meh.
Buy the cheap ones and just put in OEM or Timken bearings when they fail within a year or two. For the rear I prefer to run used OEM just because that bearing isn't really serviceable easily and I trust 20 year old OEM vs new chinese whatever. |
12-24-2015, 07:12 AM | #18952 | |
Why do double or triple the work, and screw with your car by taking the brakes and wheels off within a year or so when buying teh good reliable Nissan New hubs will allow you to work on other more important parts and buy more important parts elsewhere for teh car
12-24-2015, 10:41 AM | #18953 |
Turbo replacement for stock s13 sr20:
I'm in a dilemma between a s15 turbo, Tomei ARMS 7960, or Twisted Motions GT2871R (I kinda don't want to run this but if it'll get me by for a few months, then I wouldn't mind. Just need opinions on owners) I'm new to the turbo game and just confused about a few things but to keep it short, I plan to go HMIC, S15 550C injectors, and a tune from JWT. Out of the main 2, TM just for kicks, which turbo would be ideal for my use? Powerwise, I want to make at least 300-350whp without upgrading internals. My engine is stock with 155PSI in all cylinders. I don't plan on buying the turbo soon since I am gathering parts and will purchase it once I have the money for a tune and turbo. Let me know what's the best route!
12-24-2015, 04:09 PM | #18954 |
Clutch in, Key all the way to the start position..... car does nothing but a few seconds later the starter finally kicks in and the car starts. Just started doing it.
prior to this I used to have to push the clutch all the way to the floor as hard as I could before it would start. Ignition switch? Clutch starter safety switch? Starter?
http://www.nissanroadracing.com/ |
12-24-2015, 05:27 PM | #18955 | |
I was at first like "why you pushing in the clutch to start..." You've been her since 2005 and have disabled the clutch switch yet?!! Do that first and continue on if the problem persists. Stupidest shit ever. |
12-24-2015, 07:24 PM | #18956 |
What? I never knew that was a thing. Hah.
12-25-2015, 06:47 PM | #18958 |
z32 with 4 lug??
okay so I bought full used z32 brake setup and I'm still 4 lug I plan on going 5 but just not right now, I know you can have 4 lug rotors that fit without drilling them but I just don't know which rotors it is. If anyone knows please lemme know thanks!
