Old 04-13-2017, 04:57 PM   #1
whatbrokethistime
whatbrokethistime is an unknown quantity at this point
RB Affinis Motor Sports S14 - RB Kouki Caged Air Jacks Widebody - PRICE DROP
Hi guys.
I've owned this car since 2008, and It's been a wonderful project. It's been featured in Superstreet magazine, and countless online blogs. I'm selling it to move on to other things and invest in my new business ventures. Its extremely difficult to part with this car, as its been in my life for the last 9 years. This car spent 6 years of its life in Houston Texas but I recently relocated to NC and finished the paint and body work here, as well as the rest of the build.
It's currently located in Raleigh NC.
Dyno tuned at MA Motorsports.
[B]Makes 466 WHP / 350 WTQ at 18PSI on Dynojet, with a turbo setup, clutch, and drivetrain built for what the EFR 8374 can throw at it.
Recently upgraded to 90mm HYPERTUNE throttle body. Exhaust has been changed to Apexi N1 megaphone (world sport turbo, polished, one piece 3.25". Also replaced all brake pads with brand new Project Mu HC+, XRP Pro Plus fuel lines through out the entire fuel system (inside the tank as well)
Price is set conservatively at 35,000 . Lowered to 30,000 SOLD!!!! Thanks for looking guys.
I've spent over $60,000 in parts & countless undocumented labor hours both paid and personally invested in wiring, plumbing, assembling and fabricating. There are a number of one off parts on this car that CANNOT be replaced, even if money was no object, they simply do not exist. (Apexi one piece Megaphone Exhaust, CSG S14 tail lights, GP sports front Aero, etc)
VIDEO OF DASH DISPLAY IN ACTION
https://business.facebook.com/Affini...5779190541513/
On to the specs:
Motor
1998 Skyline R34 GTT RB25DET Neo
RB26 Valve Covers
Powdercoating for valve covers
HKS Timing Belt
R33 Front Subframe
Syko Performance mount kit.
Transmission & Drivetrain
R34 RB25DET Pull Type Transmission
NISMO R34 GTR G-MAX Twin Disc
KAAZ 2-Way Super LSD
Driveshaft shop aluminum driveshaft
Stainless Steel Braided Clutch line, Brake lines
Billet Differential Bushings
Energy Suspension - Subframe & Steering rack bushings
Peak Performance Poly Transmission Mount
Suspension
Megan Racing - Race Coilovers w/ FEAL camber plates (This was going to get replaced as one of the last things before the car saw track time)
Voodoo13 Billet Front tension rods
Voodoo13 Billet Rear upper control arms
Voodoo13 Rear Toe links
Voodoo13 Billet Rear traction rods
Peak performance inner & GKTECH outer tie rods
SIKKY RB Swap front sway bar
Fuel System
Walbro 400 LPH
Radium walbro pump adaptor fitting to 6an
Holley Hydramat
Injector Dynamics 1000cc Injectors
Radium fuel rail
AEM Fuel Pressure Regulator
-8AN feed / -6AN Return Custom Crimped XRP Race hose with gold fittings
Chassis
BadFish Performance Roll cage
BadFish Performance Rear fender mini-tubs
BadFish Performance Sheet Metal Interior Panels
Pride Motorsports / Robot Racing Dry Carbon Dash
Recaro SPG replica seats
Takata 6 Point Profi harnesses
Street Faction Front & Rear Bash Bars W/ tow strap mount
Street Faction Heel Up Plates
Street Faction Seat Rails
Momo MOD70 steering wheel
Cusco steering wheel Hub
Carbon Radiator Cooling Panel
Aerocatch Hood & Trunk Latches
K-Sport Air Jack System
Wheels & Tires
Rays TE37SL 18x10.5 +15 Front
Rays TE37SL 18x11 +18 Rear
Falken AZENIS RT615K 265/40/18 Front
Falken AZENIS RT615K 315/30/18 Rear
Turbo Setup
Borg Warner EFR 8374 .92 AR IWG Turbo
Turbosmart Internal Wastegate Actuator (2 port)
Turbosmart 4 port wastegate solenoid
Raw Brokerage Billet Twin Scroll EFR Manifold
BMRS / XRP Engine fluid hoses
Greddy Intake Plenum
Hypertune Throttle Body
Custom Core Invert mounted Intercooler
Apexi World Sport Turbo Exhaust
MA Motorsports Oil Catch
Moroso power steering Reservoir
Cooling
MOCAL Oil Cooler
GREX filter housing
Griffin Aluminum Radiator
Flex-a-lite dual 12" Pusher electric fans
Raw Brokerage Silicone Radiator Hoses
Nismo Thermostat
Electronics
AEM Infinity Engine Management
Monitoring of Oil press & Temp, Fuel Press, MAP/boost, Intake air temp, Wideband, Water temp,
AutoSport Labs Race Capture Pro II Telemetry and Race Dash
Modified Wiring Specialties PRO NEO Engine Harness
Custom Chassis Harness With ARC 8000 Touch Switch Panel
Optima Battery + Bracket
Aero
GP Sports G-Four Front bumper cover (Last authentic one in existence)
GP Sports G-Four side skirts
GP Sports rear bumper cover
JDM OEM S14 Kouki headlamps
URAS Type 1 grille
Ganador powered side mirrors
Yashio Factory Carbon Hood - Kouki
ChargeSpeed Front Wide Fenders +20mm
ChargeSpeed Rear Wide Over Fenders +50mm
CAR SHOP GLOW - Hand Made LED Tail lights
SARD GT 1700mm Wing
Annointed Aero Carbon fiber front splitter
RIZE JAPAN carbon fiber canards
New Windshield
Brakes
Project Mu 355mm SCR two piece slotted rotors
Project Mu 4 piston forged calipers with brackets
Project Mu Teflon brake lines
Project Mu B-Spec racing brake pads x8
300zx 2 piston rear calipers and rotors
300zx Z32 Brake Master Cylinder
Project Mu HC+ brake pads front and rear
whatbrokethistime is offline   Reply With Quote
Old 04-13-2017, 05:48 PM   #2
661♡Silvia
661♡Silvia is an unknown quantity at this point
Originally Posted by whatbrokethistime View Post
DON'T QUOTE THE WHOLE AD IDIOT
Very Impressive! Nice
Sent from my SM-N910V using Tapatalk
661♡Silvia is offline   Reply With Quote
Old 04-13-2017, 05:59 PM   #3
Z32TwinTurbo
Z32TwinTurbo can only hope to improve
- quotes the whole fucking add
Z32TwinTurbo is offline   Reply With Quote
Old 04-13-2017, 07:34 PM   #4
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
Top build mate but why rb25 and not 26
turboshoebox is offline   Reply With Quote
Old 04-13-2017, 07:43 PM   #5
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
gtfoh quoting every pic.
Tuners are big bullies
feito is offline   Reply With Quote
Old 04-13-2017, 08:09 PM   #6
661♡Silvia
Ok ok my bad
Old 04-13-2017, 08:16 PM   #7
RHD*bro
RHD*bro's Avatar
RHD*bro is on the path to ruinRHD*bro is on the path to ruinRHD*bro is on the path to ruin
Beautiful car but 40k wow I hope u get close to it
RHD*bro is offline   Reply With Quote
Old 04-13-2017, 09:00 PM   #8
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
I must've scrolled up and down this page 30 times lol. Amazing car!
spooled240 is offline   Reply With Quote
Old 04-14-2017, 04:11 AM   #9
serah31500
Trader Rating: (18)
serah31500 is an unknown quantity at this point
Feedback Score: 18 reviews
I almost fell out of my chair laughing when I saw 40k but then I scrolled down further saw the car and parts list. Well done sir!
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO.
serah31500 is offline   Reply With Quote
Old 04-14-2017, 07:23 AM   #10
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
Your car is amazing, hope it goes to a good home . such a great build.
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 04-14-2017, 07:40 AM   #11
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
its been a long time since i saw an s-chassis that justified a price north of $30k.
this one would be a steal for $40k.
Old 04-14-2017, 08:20 AM   #12
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
Best car ever posted on zilvia
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 04-14-2017, 08:23 AM   #13
imotion s14
imotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to behold
Just can't get over the Megan coilovers... like wearing a Zegna suit with kenneth cole shoes.
imotion s14 is offline   Reply With Quote
Old 04-14-2017, 10:08 AM   #14
s1421
s1421's Avatar
s1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the roughs1421 is a jewel in the rough
Super nice build!! Its great seeing a car build this way i love the style!
Those tailights are badass one day ill try to get me some of those!
Glws worth every penny.
s1421 is offline   Reply With Quote
Old 04-14-2017, 10:22 AM   #15
brndck
brndck's Avatar
I was thinking the same thing, but it does say FEAL/ Megan, so I'm assuming they've been reworked by Odi?
Old 04-14-2017, 10:24 AM   #16
travon47
travon47 is an unknown quantity at this point
very nice build, wasn't this forsale for $35k a couple weeks ago? What made it go up another $5k now?
travon47 is offline   Reply With Quote
Old 04-14-2017, 12:09 PM   #17
Lt8Che
Lt8Che is an unknown quantity at this point
Amazing looking build. GLWS!!!
Lt8Che is offline   Reply With Quote
Old 04-14-2017, 12:23 PM   #18
Extreme Dimensions
Extreme Dimensions's Avatar
Extreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to behold
Great build and will make someone really happy when they get it.
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Extreme Dimensions is offline   Reply With Quote
Old 04-14-2017, 05:33 PM   #19
turboshoebox
Fd or a guy named odi isnt exactly something demanding merit...
Old 04-14-2017, 06:49 PM   #20
g_mac530
g_mac530's Avatar
g_mac530 is an unknown quantity at this point
Send a message via AIM to g_mac530
Glws John! Hope you get your asking price for it
Sent from my LG-H820 using Tapatalk
Originally Posted by RoXiE.S14 View Post
Because Jesus himself made the nissan 240, true story
g_mac530 is offline   Reply With Quote
Old 04-14-2017, 07:07 PM   #21
brndck
brndck's Avatar
That's great that you have an opinion, but Odi Bakchis has taken the Feal brand from being unknown to being very reputable in the suspension/coilovers business.
Just because you are unaware of it, takes nothing away from his quality.
Old 04-14-2017, 07:12 PM   #22
turboshoebox
Feal is just some sub par chinese coilovers that some American driver put on his horribly styled 4x4, front wheels sticking out American looking s14 that only fd fan boys think are cool.
Let alone copying zeal name to feals good man
Old 04-15-2017, 04:45 PM   #23
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
lol....
anyway back to thread topic. Your car is awesome. Really doubt you will get 40k for it though.... S Chassis just don't get that kind of love by gen pop.
I wish you the best!
Old 04-16-2017, 12:12 AM   #24
dr_
dr_ is an unknown quantity at this point
I've seen a few pics of this car before and always loved it, but I have to ask: for $40k, where's the motor work? Rods, pistons, oil pump.. anything? I have an 8374 as well, and you're holding that thing back!
dr_ is offline   Reply With Quote
Old 04-16-2017, 01:22 AM   #25
jordang328is
jordang328is is an unknown quantity at this point
Savage car but it has to have a fully built motor for that price, right...?
jordang328is is offline   Reply With Quote
Old 04-16-2017, 07:44 PM   #26
whatbrokethistime
More Photos:
Old 04-16-2017, 07:47 PM   #27
whatbrokethistime
motor is internally stock aside from gaskets, belts and the external upgrades. I've had built motors in this car years ago and for 500whp there's not a need to go into the motor.
The car violently spins it's 315's with the onset of boost using the 8374 and with the weight of the car more power really isn't needed. It's not a highway car, and I really enjoy its current drivability thought the twisties.
Old 04-16-2017, 07:48 PM   #28
whatbrokethistime
After I sat and looked at what I've spend on it even just in the last couple of years, it far exceeds my original asking price so i decided to raise the price.
Old 04-16-2017, 07:59 PM   #29
SpeedSeeker
SpeedSeeker is an unknown quantity at this point
Please show us those air jacks in action. This car is so good.
Fuck if you have ANY video please share. Such a good example of doing it right.
SpeedSeeker is offline   Reply With Quote
Old 04-16-2017, 08:03 PM   #30
whatbrokethistime
Not sure why this video will not show up properly... Can anyone see it?
https://youtu.be/dV04OevYvY8
https://www.youtube.com/watch?v=dV04...ature=youtu.be
https://www.youtube.com/watch?v=dV04...ature=youtu.be&fs=1" width="644" height="390">https://www.youtube.com/watch?v=dV04...ature=youtu.be&fs=1" />https://www.youtube.com/watch?v=dV04...ature=youtu.be">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=dV04...ature=youtu.be
